Old 02-01-2013, 10:55 AM   #1
YourFearlessLeader
Team ScioNRG President
YourFearlessLeader's Avatar
Drives: 2017 WRB BRZ
Car was dead, and revived this morning...
So this morning I went to start the car, it wouldn't crank. No lights on the dash board except a very dim oil light on the dash, and a barely noticeable battery light.
I put the car in the acc position, and i slowly see the clock on hvac light up. I pull the high beam lever and I hear a very strange intermittent clicking. I pop the hood to check whats up, disconnect the HIDs, get in the car and it starts right up, no problem at all. Might I add, last night driving home by passenger side HID was flickering.
Needless to say, HIDs are coming out!!! This is the 2nd set that has caused problems for me on this car. Halogens from here on out.
2017 Subaru WRB Limited BRZ w/ PP
YourFearlessLeader is offline   Reply With Quote
Old 02-01-2013, 11:01 AM   #2
beesmiff07
beesmiff07's Avatar
Drives: Trailblazer
Do you have a sound system installed or any other devices that could be draining you battery?
Sent from my SGH-T999 using Tapatalk 2
beesmiff07 is offline   Reply With Quote
Old 02-01-2013, 11:03 AM   #3
SanDiegoFRS
SanDiegoFRS's Avatar
Drives: 86, Santa Fe, bicycle, sailboat
That's weird. You get them professionally installed? Sounds like a grounding issue or loose connection on battery terminal. I had exact symtoms on my wife's Mini Cooper.
SanDiegoFRS is offline   Reply With Quote
Old 02-01-2013, 11:08 AM   #4
YourFearlessLeader
Car is 100% stock besides this
Old 02-01-2013, 11:09 AM   #5
YourFearlessLeader
HIDs professionally installed? They are as easy to install as plugging in a new light bulb.
Funny thing is, the HIDs would fire up no problem without the key in the ignition. Battery terminals look and feel good too.
Old 02-01-2013, 12:00 PM   #6
engee
Drives: Subaru
Your battery is probably fine.
I would probably blame the PnP kit. I've seen PnP kits with bad grounds, wires, ballasts, etc. If your car is 100% stock, then this is the only logical reason. During start-up, the kit is probably sucking up too much juice.
I hope that you might want to invest in a full retro-fit in the future. But that is another discussion/topic all together.
engee is offline   Reply With Quote
The Following User Says Thank You to engee For This Useful Post:
beesmiff07 (02-01-2013)
Old 02-01-2013, 12:31 PM   #7
YourFearlessLeader
well for right now, i spent $13.50 investing in a set of philips h11 bulbs.
im not too concerned with finding the exact reason why this happened. just wanted to share in case anyone else has the same issues.
Old 02-06-2013, 12:13 PM   #8
YourFearlessLeader
FWIW, this happened again to me this morning. However the HIDs are out and the stock bulbs are in. I noticed that the negative battery terminal was covered in blue corrosive foam. I cleaned the battery and the terminal and no more issues. In fact, the car runs much smoother now, smoother idle and the dip is gone even with the AC/Heater on, and better throttle response.
Cold morning starts coldy CANADA 43 04-23-2013 02:30 PM
Morning Sun, Whiteout FR-S iaclimber4 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 12-19-2012 11:48 PM
I was spotted 401 West this morning KingRohan CANADA 5 12-14-2012 08:55 PM
Now that the FRS/BRZ is out, what other models would you like revived? steeloyangster Other Vehicles & General Automotive Discussions 31 09-13-2012 07:33 PM
Early morning fun run 6/10? blalor New England 8 06-11-2012 10:09 AM
