Old 01-28-2013, 10:46 PM   #1
AlexTheGreek
AlexTheGreek's Avatar
Drives: BRZ Premium Black
VSS Connector
I'm trying to:
1) Locate the VSS connector
2) Identify the connector make and model
I've assumed that it may be one of these two:
AlexTheGreek is offline   Reply With Quote
Old 01-29-2013, 09:19 AM   #2
AlexTheGreek
OK I answered #2 myself.
They are Yazaki 62 Z connectors.
available from www.eaternbeaver.com
or www.newunitedracingtech.com
Old 01-29-2013, 11:37 AM   #3
AlexTheGreek
To be more precise here are the part numbers
Housing 62 Connectors Z Type Sealed Female 2 Light Gray 7123-8520-40
Housing 62 Connectors Z Type Sealed Female 2 Brown 7123-8521-80
Housing 62 Connectors Z Type Sealed Male 2 Light Gray 7222-8520-40
Housing 62 Connectors Z Type Sealed Male 2 Brown 7222-8521-80
The Following User Says Thank You to AlexTheGreek For This Useful Post:
Sportsguy83 (01-29-2013)
Old 01-29-2013, 11:43 AM   #4
Visconti
Drives: 05 STi
Why?
Visconti is offline   Reply With Quote
Old 01-29-2013, 11:49 AM   #5
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
Why?
wondering this also. I know where the vss wire is behind the radio and depending on what you need it for that may be of use.
Flat Black VW is offline   Reply With Quote
Old 01-29-2013, 01:34 PM   #6
AlexTheGreek
Why?
Reasons:
1) VSS mod for the GPS unit
2) Speedometer calibration
To elaborate on #2, when changing final drive ratio or tire diameter, the speedometer needs recalibrating. This can be achieved with a correction unit (http://12oclocklabs.com/).
Do you know which of the two connectors in the picture is the VSS. The grey or the brown? Neither? They are located just above the bell housing.
Old 01-29-2013, 01:39 PM   #7
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Originally Posted by AlexTheGreek View Post
Reasons:
If I recall correctly, the BRZ senses it's wheel speed from the ABS sensors on each wheel, not a sensor in the transmission. Changing the final drive ratio shouldn't affect your speedometer, only the diameter of your tires will affect it. It does it this way because it has to sense wheel speed from each tire anyways for traction control system purposes so it might as well use the wheel speeds sensors for the speedometer anyways.
Most likely those two connectors you have are an engine RPM sensor and some other sensor like a clutch position sensor or something. Speed sensors are not usually located on the bell housing, they are usually located on the back of the transmission near the output shaft to measure the rotational speed of the drive shaft which is directly related to the speed of the car.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 01-29-2013, 02:18 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
http://www.ft86club.com/files/BRZwiringi.pdf
AlexTheGreek (01-29-2013)
Old 01-29-2013, 05:34 PM   #9
xwd
Yeah you do not need to change anything when changing the final drive. Racecomp Engineering installed the Cusco 4.51 FD and did no changes, the speedometer is fine.
The Following User Says Thank You to xwd For This Useful Post:
Old 01-29-2013, 05:45 PM   #10
wparsons
wparsons's Avatar
Since the speed is determined from the wheel speed sensors a final drive won't effect it, but a tire size change will.
flickr
Old 01-29-2013, 05:51 PM   #11
AlexTheGreek
Thats where the connectors sit, but the wiring goes down to the transmission area. I assume the BRZ does still have a speed sensor at the Transmission output shaft?
Old 01-29-2013, 05:53 PM   #12
AlexTheGreek
So how do you calibrate the speedo if you change tire rollout? Techstream software?
Old 01-29-2013, 09:31 PM   #13
Sony
Sony's Avatar
Yes
Old 01-30-2013, 08:16 AM   #14
AlexTheGreek
10-4. Thanks for setting me straight people. I'm coming from the motorcycle world which is much simpler!
OBDII Connector nzer AUSTRALIA 64 05-09-2013 03:44 PM
OBDII (OBD2) Connector nzer Electronics | Audio | NAV | Infotainment 35 04-21-2013 01:36 AM
What type of connector is this? boredom.is.me Electronics | Audio | NAV | Infotainment 1 01-20-2013 01:28 PM
brake light connector kask2_6.0 Cosmetic Modification (Interior/Exterior/Lighting) 0 10-28-2012 06:18 PM
iPhone 5 new connector & BeSpoke?!?!? Davyator Electronics | Audio | NAV | Infotainment 14 09-19-2012 12:39 AM
