Old 12-08-2011, 06:21 PM   #1
Mess11
Drives: Miata
Thumbs up Finally! First Scion FR-S test drive review (Automobile)
First Drive: 2013 Scion FR-S
December 08, 2011 / By Joe DeMatio
from Automobile - http://www.automobilemag.com/reviews...ive/index.html
Slide behind the wheel of the first-ever rear-wheel-drive Scion and settle into the Recaro-style seats. Severely sculpted, with black fabric, red stitching, and prominent bolsters, they immediately telegraph the performance intentions of this 2+2-seat coupe. Drop your left leg onto the clutch pedal. The travel is short but fluid, with a discernible engagement point just short of the floor. The gearshift has short throws and positive action. The steering wheel is all business, exactly the right thickness and with minimal padding. So far, everything feels just right to the soles of your feet and the palms of your hands, and the car isn't even moving yet.
We're at Sodegaura Forest Raceway, a 1.5-mile road course tucked into a forest in Chiba Prefecture, across Tokyo Bay from Tokyo. This is our first drive of Toyota's version of the all-new, front-engine rear-wheel-drive coupe it co-developed with Subaru. We drove the Subaru BRZ last week, and the Scion FR-S (Front engine, Rear-wheel drive, Sport) is virtually the same car, with some minor tuning and trim differences. Toyota will sell the FR-S as the Toyota 86 in Japan and as the Toyota GT86 in Europe, but only as the Scion FR-S in North America.
More on the Subaru connection shortly. Turn the key (other markets get push-button start) and the 200-hp, 2.0-liter Subaru flat-four engine, code-named 4U-GSE for those who care about such things, sparks immediately to life and settles into a quiet hum. Engage the clutch, select first gear, and we are off with a chirp of the rear tires, heading quickly into the tight right-hander that is Turn One at Sodegaura. Oh, wow, does this car turn in. The steering is super precise, and you have a good sense of the front of the car, even if there's not the sort of steering feel you get in a Lotus Elise or Porsche Cayman. The FR-S feels flat, balanced, neutral, natural.
"Natural" is the operative word with the FR-S, as every action and reaction feels like you expect it to. The car's chief virtue is its simplicity. It's a small, short-wheelbase, relatively light (curb weight is still unknown) car that does without turbocharging, large-displacement engines, all-wheel drive, trick transaxles, or big rubber. In fact, the Michelin Primacy HP tires are only 215/45R17's, in an era when 20-inch tires are commonplace. Yet the FR-S is a better and more rewarding car to drive -- at least on a handling course; we haven't driven it or the BRZ on public roads yet -- than many cars that have turbos, large-displacement engines, transaxles, big rubber, or all-wheel drive. Funny how that works.
The FR-S works very well indeed. A key technical achievement is the low center of gravity afforded by the compact horizontally opposed four-cylinder, which nestles deep down in the engine bay. Like the Subaru BRZ, the FR-S is offered either with a six-speed manual or a six-speed automatic that locks up its torque converter with the goal, says chief engineer Tetsuya Tada, of "exceeding DSG gearboxes" in shift times. Although there is a manual shift gate for the automatic, plus shift paddles, we found it worked best on the track when it's simply left in drive; try to use the paddles and you'll likely have downshifts denied even when there seems to be plenty of space left on the tach. That complaint aside, this appears to be a very nice automatic, but why would you want one in this pure sports car?
Back to the track. The FR-S moves fluidly among Sodegaura's fourteen corners, and it's very forgiving if you misread a line and dive abruptly toward the apex. Oversteer is easily achieved and easily controlled, and if you don't have the nerve or skill to turn off the stability control entirely, the "VSC Sport" button gives you a lot of rear-end-out fun before the stability cuts in. On a wet track, this was a swell, giggle-inducing experience. The engine, which is fitted with Toyota's D4-S combined port injection and direct injection, isn't raspy like most Subaru fours nor a high-RPM screamer like, say, the Honda S2000's four. Yet it heads readily to its 7400-RPM redline and never seems short of breath. The redline itself is pretty forgiving, but the window between 7000 RPM and redline is exceedingly short, and an upshift-alert light blinks furiously if you're not efficient with your upshifting.
Furious track activity is clearly what the FR-S is for, as evidenced by a series of hot laps conducted at Sodegaura by Scion Formula Drift star Ken Gushi, who drove the car for the first time today just like us. "Drove" is perhaps the wrong verb, because Gushi launched, hammered, battered, finessed, coaxed, directed, and manipulated the Scion around the rain-swept road course in a nearly nonstop drift that was an equally violent and controlled maneuver, a dramatic display of this car's potential. Okay, so he did a complete spinout in one corner, prompting him to observe wryly, "It's a little snappy when you're driving it stock." Indeed. "And how will the drift FR-S differ from the production version?" we asked. "Well, of course we will put on huge rubber, and 200 hp isn't nearly enough for competition, so we'll have to turbocharge it," the California Drifter replied.
"Where will you wedge in the turbocharger?"
"That's the problem," came Gushi's grinning reply. "We don't know yet!" Rest assured, the Scion Formula Drift shop, among myriad other tuners, will be figuring this out soon.
Even with a far, far less talented driver behind the wheel, the FR-S dives into corners with enthusiasm and a minimum of understeer. We haven't had the same editor in both the Subaru and the Scion, but comparing notes, it appears that the Scion is less susceptible to understeer than the BRZ. Chief engineer Tada-San says that his goal in tuning the FR-S was agility, whereas Subaru focused more on stability, so this makes sense. "We have softer springs and stiffer dampers in front than Subaru does," Tada-San tells us. "At the rear, I chose the same spring rates as Subaru but different valves in the dampers."
Which brings us to the whole notion of this Subaru/Toyota partnership. How did this happen? Well, it's difficult to get the entire story from either side, but this is what we've managed to piece together:
By the middle of last decade, Fuji Heavy Industries, Subaru's parent company, was no longer associated with General Motors. (You remember that association; it produced the Subaru WRX-based Saab 9-2. So you can see why the association ended.) Through some combination of national pride, Japanese government prodding, and goodwill, Toyota Motor Corporation (TMC) began a relationship with Fuji Heavy Industries (FHI) after Fuji's divorce from GM. At about the same time, Toyoda family patriarch Akio Toyoda, who is now president, asked, "where is the passion in our lineup? I want to build a sports car." TMC established a sports car planning division, which quickly decided on a brief for the new car. Its styling would be inspired by the Toyota 2000GT supercar of the 1960s, its engine would follow in the footsteps of the flat-two-cylinder engine in the diminutive Toyota 800 (a.k.a. Yotahachi), and it would be conceived in the spirit of the famous mid-1980s Toyota Corolla GT-S, known to aficionadoes by its internal Toyota code name, AE86. (In Toyota nomenclature, the A referred to the 4AGEV engine, the E to the Corolla model line, and the 86 was a sequential number. "86," or "Hachi-Roku" in Japanese, has taken on legendary status among Toyota fans; hence the use of the two digits in non-USA models and even on a little fender badge on the FR-S.)
The project progressed for about a year, but Subaru rejected the first proposal. Here's where things get murky, but it's fairly apparent that Subaru was having a hard time stomaching the thought of a rear-wheel-drive car, since their entire brand identity is predicated on all-wheel drive. Subaru walked away from the table and the entire project was in limbo for about half a year. Subaru finally decided to make a prototype car with a very low center of gravity, which eliminated the possibility of all-wheel drive. That prototype both surprised and amazed Toyota, which enthusiastically supported its development. The joint project proceeded in late 2007 and now, four years later, we see the fruits of the two companies' work. Styling is by Toyota, development and manufacturing are by FHI, and each company, obviously, will be in charge of marketing and sales for their respective products.
At this juncture, it seems like Toyota might have gotten the better end of the deal. After all, the FR-S falls neatly into a historic lineup of rear-wheel-drive Toyota sports cars and should give the Scion brand a huge dosage of street cred. Subaru, for its part, has staked its entire brand on the concept of all-wheel drive, so it's not clear how the BRZ fits into the Subaru lineup. That said, these cars just feel right to us and are destined to shake up the world of affordable sports cars in a big way.
2013 Scion FR-S
On sale: spring
Base price (estimated): $24,500
Engine: 2.0L DOHC H-4; 200 hp @ 7000 rpm, 150 lb-ft @ 6400-6600 rpm
Transmissions: 6-speed manual, 6-speed automatic
Mess11 is offline   Reply With Quote
Old 12-08-2011, 06:23 PM   #2
Mess11
Drives: Miata
Found these interesting:
Old 12-08-2011, 06:25 PM   #3
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
"Base price (estimated): $24,500" lol if the case. Scion is screwed then.
tranzformer is offline   Reply With Quote
Old 12-08-2011, 06:36 PM   #4
Dark
Elite Padawan
Dark's Avatar
I hope they are wrong. 23K is more acceptable.
Toyota FR-S? WIN
Dark
Dark is offline   Reply With Quote
Old 12-08-2011, 06:39 PM   #5
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
LOL I knew it was Subaru colors or the 86 colors just renamed, now it's confirmed. Still I love Lighting red and Satin white pearl. I'm glad about the colors... and looks a white tach.... an option? not so much on the price lol if they're at 24.5K then I expect BRZ to be close to 30K out of the lot. At that prize I rather go for a used 370z or save a huge load of money and get an S2000. I hope that this is not the case. SCION give use 21k! and Subaru Give us 24K and well give you lots of business.
Then again at 24.5K.... they'll still sell.
Old 12-08-2011, 06:40 PM   #6
tranzformer
Drives: Zoom Zoom
All Scion fans better hope that is a wrong number and that it is closer to $22k. Imagine paying $24,500 for the FRS? That will not work.
Old 12-08-2011, 06:40 PM   #7
Zgrinch
Zgrinch's Avatar
Drives: 2013 Limited DGM BRZ
+1. Also, "Turn the key (other markets get push-button start)"
Ouch...not sounding good for those who are looking for that upgrade.
Zgrinch is offline   Reply With Quote
Old 12-08-2011, 06:41 PM   #8
Syldrin
Troll Feeder
Syldrin's Avatar
Drives: boosted scion tc.
24K for the scion. hmmmmmmmmmm you can get the subaru for the same price with better interior trim.... assuming the brz comes out at 24 like expected.
Syldrin is offline   Reply With Quote
Old 12-08-2011, 06:42 PM   #9
KevinDuMa
Drives: 2004 Honda S2000
It comes with a white tach...those Scion promo photos made it look grey. But yeah $24,500? I'd be going with the Subaru for sure
KevinDuMa is offline   Reply With Quote
Old 12-08-2011, 06:44 PM   #10
Dark
Elite Padawan
Dark's Avatar
Yeah. I wanted to write 22K. Didn't know I typed 3 instead.
Dark
Old 12-08-2011, 06:46 PM   #11
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
Yeah the 24.5k is a bit intimidating. It could be a premium version equivalent to the BRZ. Maybe there base price will be cheaper to 22-23k.
Old 12-08-2011, 06:49 PM   #12
Zaku
Zaku's Avatar
Scion is going to Die at that price point, they'll be crushed under the weight that everyone would buy the BRZ over the FRS. If the BRZ isn't priced much higher, I mean most people in America ( From differnt Polls other then here I.E. Autoblog) and responses from different magazines all point to the BRZ being better. The only thing the FRS had was it's style and better front and that expected lower price point. If that's gone... well.. I'm sorry Scion it's not going to help your case. again a what if....
Hmm here's a good question. How many of you would still buy the BRZ if the Scion was 24k and the BRZ came close to 30?
I dunno about you guys but I would buy the FRS. I mean I never really had a problem with the interior and those things.
I mean 21K start (21,995) and (24,500) for the best equipped version, we're all Ok with, 24.5 base no bueno people go buy BRZ instead
Old 12-08-2011, 06:51 PM   #13
Syldrin
Troll Feeder
Syldrin's Avatar
subaru and scion both offer rebates but you can haggle the brz and the scion is 24 as is.
Old 12-08-2011, 06:53 PM   #14
Mari0
Car Enthusiast
Mari0's Avatar
Drives: tC 05 & 07, Rav4
highly doubt this price is accurate for a base model
Mari0 is offline   Reply With Quote
fr-s forum, fr-s forums, fr-s reviews, frs forum, frs forums, frs review, scion fr-s forum, scion fr-s forums, scion fr-s review, scion fr-s reviews, scion frs forum, scion frs forums, scion frs review, scion frs reviews
First Production FT-86 Test Drive/Review on Youtube gaijin0223 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 02-13-2012 09:23 PM
Subaru BRZ First Drive Review by Automobile Magazine - "A Great Drive" Sport-Tech BRZ First-Gen (2012+) — General Topics 36 12-07-2011 03:13 PM
EVO's Subaru BRZ test drive review - 5 Stars JrunkenC BRZ First-Gen (2012+) — General Topics 2 12-05-2011 01:22 AM
Jalopnik Test Drive Review of BRZ (oh wait...) Quantum BRZ First-Gen (2012+) — General Topics 8 12-03-2011 02:45 PM
2012 Subaru BRZ Test Drive Review by Autoweek Sport-Tech BRZ First-Gen (2012+) — General Topics 1 12-02-2011 06:34 PM
