Old 01-26-2013, 09:36 PM   #1
Vanga
Vanga's Avatar
Drives: 07 Hyundai Tiburon SE
DIY: FR-S/BRZ Illuminated Door Speakers
DESCRIPTION: This DIY will give you a step by step instruction on how to place LED strips inside the door speaker and wire it into your already installed footwell kit.
DIFFICULTY (0-10): 3
TIME REQUIRED: About 1 - 1.5 hours per door
TOOLS NEEDED:
-4 x RGB LED strips (I used the Diode Dynamics footwell kit with the rear footwell add-on)
-RGB controller
-2 x 3 meter RGB extensions
-Phillips screwdriver
-flat head screwdriver
-extra zip ties
-3m adhesive tape
-knife
INSTRUCTIONS: (assuming you already have the front footwell kit installed)
1. Remove plastic tab and screw highlighted by red circle.
2. Remove silver accent piece on door handle. Use a flathead screwdrive to pry it off from the bottom. Once you get the bottom clip off, it will be very easy to get off.
3. Remove the two screws highlighted by red circles.
4. There are several plastic tabs holding the door in place, Use your hand starting at the inside part of the door and make your way down the bottom to the outer part of the door.
5. Now, remove the rest of the door panel by lifting the entire panel up.
6. There are two cables (Make a mental note on how these are hooked up) and a wire coupling still holding the panel to the rest of the door (highlighted in red). Remove these.
7. Flip the separated door panel over. Use a microfiber or towel to wipe off any dust or other debris inside the speaker vent and use the adhesive backing to stick the LED strip around the perimeter of the housing.
8. Use some 3m tape to hold the excess wiring in place above the vent.
9. Back to the door frame. You need to access inside the door frame to feed the wiring, use a knife to cut into the plastic along the dotted red line.
10. Inside the door frame you will see a rubber gromit used to chanel wiring from the door frame into the cabin. Use your knife to cut a hole into this gromit. You need to cut this hole so you can feed the extension wire through into the cabin.
11. Now we need to be able to access the other side of that rubber hose inside the cabin. Pry the door sill off using a flat head screwdriver, this is held in only plastic clips.
12. Remove the corner piece underneath the dash, this is held in place by 1 plastic clip highlighted in red.
13. Once you can access the rubber gromit that leads into the cabin, poke a hole in it. Now comes the tricky part, you have to feed the extension wire through the two rubber gromits so that the female end will be in the door frame and the male end will be inside the cabin. This is the most difficult part of the DIY because its not easy feeding the wire through the gromits. I would recommend using a screwdriver or something with a hook on it to help pull the wire through the gromits. There isn't a whole lot of room to work with your hands. If you need to make the hole in the gromit larger, that is also acceptable.
14. On the door frame, Use some 3m tape to hold the plastic insulation back into place.
15. Hold the door panel back up to the door frame and re connect the two cables that actuates the locking mechanism. Test the door handle and lock before mounting to ensure the cables are connected correctly.
16. Re-attach the wire coupling for the electronic window and lock panel.
17. Hang the door panel back onto the window pane. Crawl underneath the door. Lift slightly to connect the extension wire to the LED strip.
18. Hold the door panel back into place and press firmly all over the panel to push in the plastic tabs.
19. Re-attach the three screws and plastic tab. Then snap the silver accent piece back into the handle.
20. Re-assemble the plastic corner piece and door sill.
21. Feed the extension wire underneath the glove box (use zip ties to hold the wire up) and through the center console. The shift boot frame is just held in my plastic clips, It can be removed by prying it off with a flat head screwdriver.
22. Attach the RGB ends into the supplied splitters, then into the RGB controller.
23. Stuff all the excess wiring into the center console pocket above the cigarette lighter but below the shifter. Re assemble the shifter.
24. Repeat steps for opposite door!
Enjoy your new illuminated door speakers! If you have any questions, just ask!
Vanga is offline   Reply With Quote
Old 01-26-2013, 09:49 PM   #2
Mo707
Mo707's Avatar
Do you hear any tapping noise from the wires when you play music?
Mo707 is offline   Reply With Quote
Old 01-26-2013, 09:52 PM   #3
Vanga
Vanga's Avatar
No, I don't but I made sure to make the excess wires really secure using that 3m tape. But there aren't any rattles, taps, or anything of the sort.
Old 01-26-2013, 09:56 PM   #4
Mo707
Mo707's Avatar
Well it looks really good! I dont know if i missed anything but what did you tap into for power?
Old 01-26-2013, 10:12 PM   #5
Vanga
Vanga's Avatar
Thanks for the compliment! I kind of skipped that part. I wrote this under the assumption people already had a footwell kit installed. And since there are other DIYs out there for footwell kits, I did not want to become redundant. As I posted before, I used the Diode Dynamics kit. That comes with a wiring harness that uses T-taps to splice into the cigarette lighter on the center console. He has a youtube video on how to install the footwell kit, and then you can use this DIY to add the door illumination.
The Following User Says Thank You to Vanga For This Useful Post:
Mo707 (01-26-2013)
Old 01-26-2013, 10:17 PM   #6
Asphalt~86
Drives: Asphalt AT
Do you work for Diode? What would it cost me to drop my car off at your shop and have this installed along with footwells?
Asphalt~86 is offline   Reply With Quote
Old 01-26-2013, 10:24 PM   #7
Vanga
Vanga's Avatar
I'm good friends with Paul (General Manager at Diode). The kit itself cost me around $100 for both the footwell and the extra strips I used to put in the speakers. I'm sure you could PM Diode Dynamics and see what they quote you. Tell them I referred you. Maybe I'll get a discount next time I shop there.
Old 01-27-2013, 12:38 AM   #8
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
i like this kit, jus wish i didnt have to splice my lighter plug for it
lbroskee is offline   Reply With Quote
Old 01-27-2013, 01:08 AM   #9
Vanga
Vanga's Avatar
You don't have to cut any wires. Just use a quick splice or a t tap. Really easy, really simple, nothing is permanent. Or, if you want, you can run a power wire to the fuse panel and just wrap the bare end around the fuse. However I wouldn't recommend it because its not exactly the safest option.
Old 02-28-2013, 04:05 PM   #10
Deathkaos
Drives: GT86 (Aero Kit)
You are the man! I have been waiting for someone to post something like this for a few months now!
Can you please give me more information about the RGB strips and RGB controller? Links to the items please??? Thanks heaps!!!
Deathkaos is offline   Reply With Quote
Old 03-01-2013, 08:20 PM   #11
Vanga
Vanga's Avatar
Thank you! I sent you a pm. If you have anymore questions just ask. I'd be glad to help you out
Old 03-01-2013, 09:05 PM   #12
Xdragonxb0i
Drives: ex500r
Do you think you we can make that little reflector functional on the door?.
Xdragonxb0i is offline   Reply With Quote
Old 03-02-2013, 12:11 PM   #13
infinite012
Drives: 13 DGM BRZ Ltd
You didn't have to cut the moisture barrier... it has that black goop/gummy stuff that will allow you to pull off the moisture barrier and stick it back on.
infinite012 is offline   Reply With Quote
Old 03-03-2013, 09:38 PM   #14
Vanga
Vanga's Avatar
Its definately functionable, however there is no wiring or fuse currently present. The only thing there is the plastic, so you would have to find a festoon style bulb holder, then wire into the cabin and splice into the currently existing map lights. Should be fun! I'll look into it, I'm currently working on another DIY so my time is limited, but I will look into it.
door speakers not working number1Tango Electronics | Audio | NAV | Infotainment 23 04-03-2022 07:03 PM
wire routing for door speakers derka-derka Electronics | Audio | NAV | Infotainment 6 12-13-2012 09:49 PM
Front door speakers. Calum Electronics | Audio | NAV | Infotainment 5 08-11-2012 04:49 PM
Just replace door speakers? industrial Electronics | Audio | NAV | Infotainment 0 08-02-2012 02:57 PM
Installed new in-dash, lost sound from door speakers Nitro Electronics | Audio | NAV | Infotainment 2 06-04-2012 08:53 PM
