Old 01-24-2013, 05:54 PM   #1
WoRMeaT
WoRMeaT's Avatar
Drives: Scion FR-S Whiteout
Perrin 19mm or 22mm front sway bar?
Im going to do some AutoX this spring, with staying in stock, should I get the 19mm or 22mm front sway bar? I want to get less oversteer.
WoRMeaT is offline   Reply With Quote
Old 01-24-2013, 05:58 PM   #2
shu5892001
Ontario's FT86
Drives: 2016 Lexus GS-F
If you want less oversteer you would want to use stiffer front fsb and softer rsb
shu5892001 is offline   Reply With Quote
Old 01-24-2013, 06:06 PM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
SAVE YOUR MONEY
LIMITED TIME OFFER
Want less oversteer? Follow these easy steps in any order!
1. don't pendulum into a corner, you know that thing where you lead in the opposite direction of a turn before yanking the wheel, don't do that!
2. don't lift mid corner or lift aggressively, if you need to lift because you're going too fast, go in slower next time so you don't have to lift!
3. check your tire pressures, it may very well be that you don't have the front-rear balance set right
4. don't hammer down! Remember a swaybar isn't going to prevent oversteer if that oversteer is from putting down power!
Old 01-24-2013, 06:29 PM   #4
Pete156
I like to eat!
Damn! Feels like I'm in driving school. Good stuff
Pete156 is offline   Reply With Quote
Strano Performance Parts 22mm Tubular front swaybar Sam Strano Tracking / Autocross / HPDE / Drifting 276 05-20-2014 02:54 PM
Sway Bars: Hotchkis vs Perrin? swift996 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 12-15-2012 12:09 PM
FS: Brand New Starno 22mm Front Sway Bar cityhugo Engine, Exhaust, Bolt-Ons 11 12-14-2012 09:30 PM
Front Sway Bar endlinks D1cker Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 10-30-2012 04:14 PM
Perrin Rear Sway Bars at Redline360 Redline360 Brakes, Suspension, Chassis 0 06-28-2012 10:38 PM
