Old 01-20-2013, 02:41 PM   #1
Hanakuso
Help me pick the best material for underbody panels.
I want to replicate a similar underbody panel like the TRD Griffon but i'm stumped on which material to go with. Just looking on McMaster, Alloy 5052 or Titanium (grade 2) would be under $60 for a sheet that should be good enough. Only bad thing with titanium it seems is cutting and drilling it would be hard. I would have to drill holes for the screws/caps to fit and also I would have to cut a small area for the cat. Taking it to a professional with proper tools is possible but i'm not sure how many pros deal with titanium.
Hanakuso is offline   Reply With Quote
Old 01-20-2013, 07:08 PM   #2
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
What about cooling?
Old 01-20-2013, 07:20 PM   #3
Xdragonxb0i
Drives: ex500r
I say go with a durable plastic. Rust proof and probably lighter then metal. A plastic like what you find in truck liner
Xdragonxb0i is offline   Reply With Quote
Old 01-21-2013, 01:23 AM   #4
Hanakuso
Originally Posted by boredom.is.me View Post
What about cooling?
It will only cover the cat and res. Actually it will need to be cut around the cat since it drops low or I will have to hope a HFC will clear it.
I was thinking of some sort of plastic but I'm not sure which one would be able to handle very high temps since the exhaust tubbing and car could melt the plastic if its not up to the task
Old 01-21-2013, 01:39 AM   #5
boredom.is.me
Custom User Title
Delrin may qualify.
Old 01-21-2013, 07:45 AM   #6
Ingen
Drives: Ultramarine FR-S 6MT
If I were going to go with a sheet metal it would probably be aluminum. Honestly, titanium is going to be a huge hassle to work with. If you insist on it, by all means make the aluminum one first. Once you're done massaging the dimensions and such, take the aluminum pattern and a sheet of Ti to a fabricator who can work with it and have them do the final build.
Then get a vendor account! :P
I would love to have something like these if only to keep all the salt away from the undercarriage. I would say that a plastic could certainly work, but the heat would be a factor... Hell, figure out what the JDM ones are made of and copy off them. Probably a fiberglass or glass reinforced plastic?
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 01-21-2013, 07:54 AM   #7
CaptainSlow
CaptainSlow's Avatar
Use plastic if you can. Cheap, easy to work with, effective, and lightweight. Just keep it away from heat sources and you'll be fine. If you want to go a more expensive route, I'd use basic sheet metal or aluminum. Titanium would be a waste of money, unless you're just trying to have something to impress people with (which it probably won't...people would be more impressed with the fact that you made it yourself than the material you chose to use)
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-21-2013, 08:33 AM   #8
cslntuee
Drives: Subaru BRZ Limited
What’s the material of the JDM under panel (black one)?
Thanks.
cslntuee is offline   Reply With Quote
Old 01-21-2013, 08:55 AM   #9
CaptainSlow
Probably injection molded plastic.
Old 01-21-2013, 09:58 AM   #10
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
I'd go with Ti, if it's available and as/close to affordable as aluminum. If it's significantly more, I'd go with aluminum.
This is a pretty straight forward affair. It shouldn't be as hard as everyone is making it.
1. Get under the car and make a card board template.
2. Take cardboard template to a sheet metal fabricator.
3. Crack a beer and profit?
You should be able to locate a sheet metal fabricator by contatcing any HVAC construction company. Either they will have one in-house or a vendor they can reccomend.
This looks to be a fairly straight piece(s) with only a few holes in it.
Beyer Subaru is offline   Reply With Quote
Old 01-21-2013, 11:11 AM   #11
swift996
swift996's Avatar
Hmm..I know someone in plastics manufacturing who has mad some one off things for his home. I wonder if he could make a run if I got some specs. I'll see, because I could make a mock up with vent/cooling.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 01-21-2013, 11:34 AM   #12
CaptainSlow
You want something stiff enough (or something that is mounted securely enough) to not start to resonate with airflow, otherwise you're really taking a step backwards. Just be aware of that when you're going through the process.
Old 01-21-2013, 12:03 PM   #13
Turbowned
Turbowned's Avatar
This needs to happen. Full flat underbelly - because race car!
Old 01-21-2013, 12:51 PM   #14
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
I was thinking about using dibond or alumalite. I just don't know how much of an air gap I'll have between my exhaust components and the panel.
industrial is offline   Reply With Quote
Alcantara material? ubersoph Cosmetic Modification (Interior/Exterior/Lighting) 13 06-03-2015 04:24 PM
Small Philly area GB on Underbody Panels? Phaedrus29 NY / NJ / CT / PA 35 02-24-2013 12:16 AM
GTA - JDM underbody panels? wparsons CANADA 7 11-24-2012 12:18 AM
My 5 piece TRD kit is coming.. question about material brianlo622 Cosmetic Modification (Interior/Exterior/Lighting) 5 10-19-2012 01:18 AM
Noise generator plug material? jm1681 DIY (Do-It-Yourself) Guides 28 10-13-2012 07:58 PM
