Old 01-15-2013, 01:09 AM   #1
ayau
Drives: Some rust bucket
Rear camber plates?
I haven't found anything about rear camber plates for these cars? Is there a thing for rear multilink suspension?
Old 01-15-2013, 01:55 AM   #2
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
No. The damper doesn't have squat to do with camber in the rear of this car, or on any end of a car that doesn't use an actual strut (the spring over the damper is not the definition of a strut even though most struts are that way).
However, I can help: http://www.stranoparts.com/partdetai...258&ModelID=36 along with http://www.stranoparts.com/partdetai...258&ModelID=36 will give you camber adjustment. Note you can't run the camber adjusting bushings without the other set.....
Sam Strano is offline   Reply With Quote
Old 01-17-2013, 09:46 AM   #3
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
i think it would actually be impossible to adjust any upper plates in the rear if you have seen the little hole they're mounted in
IG-Joey_Soul
Old 01-17-2013, 03:46 PM   #4
wparsons
wparsons's Avatar
^^ Impossible or not, adjusting the angle of the shock wouldn't change the camber at all. Rear camber is dictated by the relative lengths of the upper control arm and lower control arm. If you want to change camber you have to lengthen or shorten one of the two arms.
flickr
Old 01-17-2013, 04:05 PM   #5
ayau
After looking at the rear suspension geometry, this makes more sense. The damper is mounted in a way where the wheel hub angle wouldn't change.
Rear suspension geometry:
If you look at the front strut, moving the damper will change the angle of the wheel hub.
Front suspension geometry
Which camber plates are you running? Coastermikey Suspension | Chassis | Brakes -- Sponsored by 949 Racing 43 02-15-2014 10:26 AM
MSI Camber plates wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-29-2012 07:16 AM
Camber Plates delusional Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-30-2012 08:17 PM
Camber plates Captain Snooze AUSTRALIA 7 07-02-2012 06:51 PM
