Old 01-06-2013, 04:04 PM   #1
GhostofAkina
Drives: 2013 Scion FR-S Raven
Does Vinyl Wrap Damage Paint?
I'm considering vinyl wrapping my FR-S but can't find good info as to whether or not it damages the paint underneath. Most of the articles I've found online are written by vendors. Does anybody on here know if vinyl wrapping your car damages the paint?
GhostofAkina is offline   Reply With Quote
Old 01-06-2013, 04:44 PM   #2
dorifuto
If in doubt,flat out
dorifuto's Avatar
Drives: 2013 brz
I've used vinyl to wrap logos on work trucks and I've never damaged paint during removal. Just take your time removing and use a heat gun or remove it on a hot day.
dorifuto is offline   Reply With Quote
Old 01-06-2013, 05:55 PM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Vinyl is big business and has been around for a long time. It doesn't damage paint if it's been applied and removed properly. The paint will fade on the uncovered parts obviously so if someone has say, just the hood done up for a loong time (years!) the hood paint would be in better condition than the rest of the car.
Rayme is offline   Reply With Quote
Old 01-06-2013, 06:55 PM   #4
encity5
encity5's Avatar
what they said, from what i hear, it essentially does the opposite of what your worried about, it protects the paint and your car.
encity5 is offline   Reply With Quote
Old 01-06-2013, 08:24 PM   #5
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
The quality of vinyl is important as well. You want to make sure to use a film that is meant for vehicle wraps to prevent damaging the paint when removing the wrap. If you are looking to do a solid color change than I would recommend using 3M 1080 series wrap film or Avery Supreme wrap film. Here are some links for more info on these films.
http://solutions.3m.com/wps/portal/3...ts/Series1080/
http://na.averygraphics.com/AvGrNA_SupremeWrap.asp
Area86 is offline   Reply With Quote
Old 01-06-2013, 08:26 PM   #6
636
636's Avatar
Drives: '23 CWP BRZ
My local shop stands by "No damage done for up to 5 years, leaving it on longer than 5 years MAY cause paint damage."
636 is offline   Reply With Quote
Old 01-06-2013, 08:35 PM   #7
GhostofAkina
Where's your shop? So cal by any chance? If anyone know of somewhere I'm Southern California please let me know. Thanks for all the input guys.
Old 01-08-2013, 12:03 PM   #8
gily25
Drives: Silica BRZ 6MT
Did you have the white vinyl wraps (for transport) on the car when you picked it up? I think most of us unwrapped our cars and there was a thread here for taking it off in a way that doesn't damage the paint (maybe it's in the dealer pick-up thread). Basically it's the same difference.
Not only do you want to keep an eye on UV damage to areas not covered but keep an eye out for rock chipping, scratching, etc through the wrap. There's a radio station here in CT (WCCC) that showed pics of their unwrapped Hummer and all the spots where the wrap was damaged had made a mess of the paint underneath.
gily25 is offline   Reply With Quote
Old 01-09-2013, 01:54 AM   #9
kchkwan
Drives: Subaru BRZ
are vinyl wraps for interior btr or plasti dip?!?!
kchkwan is offline   Reply With Quote
Vinyl Wrap? trinitron Cosmetic Modification (Interior/Exterior/Lighting) 54 07-11-2013 06:16 PM
Vinyl wrap CF lip? finch1750 Cosmetic Modification (Interior/Exterior/Lighting) 0 11-18-2012 10:54 PM
Paint or vinyl wrap b1pkkf26 CANADA 6 10-21-2012 03:29 PM
Best 3d Vinyl wrap CharlieChaos Cosmetic Modification (Interior/Exterior/Lighting) 2 07-25-2012 02:59 PM
Minor paint damage Double4Free Great Lakes 8 07-23-2012 07:35 PM
