Old 01-13-2013, 10:11 PM   #1
tech4pdx
Make love
tech4pdx's Avatar
Drives: H8R.. Not really
Rubberize/Coat trunk area
Guys.. I removed my spare and all the tools from the back of my fr-s. I have no need for them. I would like to coat the rear sheet metal with material akin to that you would use with spray-on bedliners for a truck. Anybody have any ideas or suggestions? My goal is to protect the sheet metal and not add much weight.
tech4pdx is offline   Reply With Quote
Old 01-13-2013, 10:26 PM   #2
gmookher
protect from what?
gmookher is offline   Reply With Quote
Old 01-13-2013, 10:30 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
Don't laugh, that stuff as seen on TV looks good. Normally I'm skeptical but I see it for $15 per can in the mall right next to the NO! NO! and Stompeez.
Old 01-13-2013, 10:35 PM   #4
DIM
Plasti-dip.
DIM is offline   Reply With Quote
Old 01-13-2013, 11:47 PM   #5
tech4pdx
Make love
tech4pdx's Avatar
Originally Posted by gmookher View Post
protect from what?
Just normal wear and tear from transporting things. Also, I think it would look cleaner if it was all blacked out in there. The point was to remove the weight of the spare, tools, carpet mat, etc and still leave something behind that was somewhat protective, hence the spray-on rubberized coating idea.
Any thoughts on that?
Evan
Old 01-13-2013, 11:50 PM   #6
tech4pdx
Make love
tech4pdx's Avatar
That's what initially came to mind. Hoping others had good ideas. I want the job to be clean and look OEM, so I will probably be masking off quite a bit to protect from overspray.
Evan
Old 01-14-2013, 12:02 AM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
You want a Rhino liner type coating. Maybe fit 3 wheels/tires in the trunk afterward.
Old 01-14-2013, 12:07 AM   #8
whaap
whaap's Avatar
It would look a lot more OEM if you took out the trunk floor, removed the spare and all the tools, etc. and put the factory trunk floor back in. I'm sure by itself it weighs very little and it really would look factory finished instead of a plasti-dip or painted hole.
whaap is offline   Reply With Quote
Old 01-14-2013, 12:11 AM   #9
tech4pdx
Make love
tech4pdx's Avatar
The only problem is that the trunk carpeted mat will collapse under any kind of weight (like wheels/tires). It's not very rigid.
Old 01-14-2013, 12:12 AM   #10
tech4pdx
Make love
tech4pdx's Avatar
Bingo. I was envisioning something like this:
http://www.linex.com/pages/2010/bedl...ts_sprayed.php
Evan
Old 01-14-2013, 12:16 AM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
My friend Raptor Lined his Jeep and it seems to be a very good product. It's probably too rugged for this application though.
Stock Nav swap from BRZ to FR-S & Five Axis trunk spoiler install on BRZ trunk? 07stealth350z DIY (Do-It-Yourself) Guides 8 08-27-2020 03:27 PM
OC area FRS/BRZ trunk swap Chiknscrach Southern California 1 07-23-2014 11:24 AM
WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk R0ME0 Exterior Parts (Aero, Lighting, Etc.) 3 01-07-2014 09:36 PM
OPTI-Coat in LA / Valley Area DaveFTW Southern California 4 08-27-2012 10:25 AM
Atlanta-area Opti-coat group buy Erroneous Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-25-2012 09:08 PM
