Drives: 2013 Subaru BR-Z Limited
3 wheelin...or dog leggin.
Ok guys, I'm not talking bout hydraulics or air ride tricks here...they used to call picking up the inside rear wheel around a corner. I'm having a small issue with "dog leggin" my BRZ and it has nothing to do with air ride/hydraulics.
I installed the Eibach sway bars front and rear. I love the performance gains felt as the car has zero body roll and stays flat as can be in corners. My issue is entering or exiting driveways with small ramps either coming or going... The 22mm bar is so stiff that at times I get stuck with one wheel hanging, no drive capabilities due to rear diff, and a flashing traction control light. Luckily in south Florida its really flat and there's not too many of these entrances/exits of businesses with a rise that causes this. In SoCal there's tons of steep driveways as well as many other states with mountains/hills/elevation changes... Is anyone else having these issues with either the factory sway bar or aftermarket sway bar? There's two adjustment points on the rear bar and I don't even have it set to the tightest setting. It can be amusing at times but when there's cars behind me and I can't move its not so amusing.
Drives: Skoda Yeti DSG diesel 4x4
Apparently if you apply the handbrake a bit it will cause the other wheel to get some drive through the diff by locking up the spinning wheel.
Try that next time. |
| The Following 3 Users Say Thank You to sierra For This Useful Post: |
Sounds logical.. I'll give it a shot next time I'm just "hanging around"
Drives: Attitude
Cause and effect of making the rear suspension less independent. Some people will track cars without rear swaybars to prevent lifting. Wheel in the air getting all the torque is natural form from a Torsen LSD. Try the handbrake, but the true solution to getting no power with a wheel in the air is a mechanical LSD (clutch-type). A much cheaper and more proper solution is to not lift a rear wheel at all, which you accomplish by not having such a huge swaybar.
I would think that getting a rear wheel to life off the ground in a rwd car would be difficult. I'd imagine that the easiest way to do this is with a fwd car because the rear end isn't squatting during acceleration thru a turn.
Drives: FRS
If the rear is too stiff, on turn-in lifting the rear wheel isn't too hard. That being said, its usually because your braking a turning hard at the same time, which is generally a bad idea anyways. Try braking sooner and let off the brakes before your turn-in so the front tires are loaded that much. Also, a 22mm bar is enormous for this car unless you've got some impressive rear springs to resist the lift applied to the inside wheel.
All of this is a moot point on an autoX course, though I've seen people put a bigger front bar on instead of a rear bar to tame the understeer present from having to load the front tires so hard all the time. So, cliff notes: brake sooner, don't overload the front suspension and lighten the rear end, smaller rear bar/stiffer rear springs. |
No, guys...you're getting a little confused. While cornering the car is perfect with no ill handling characteristics. It's only entering/exiting steep driveways at 2-3 mph that the rear wheel will hang. If I were having this issue at the track I'd back off the size of the rear sway bar or if it was really a prob I'd just buy the mech LSD.
It's not a handling problem or issue...it's a "leaving starbucks drive thru" issue
#9 | |
Drives: FRS
Sent from...somewhere? |
#10 |
Site Moderator
Drives: Stuff
This. Once there's load on the lifted wheel the diff will start working again.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| The Following User Says Thank You to Dave-ROR For This Useful Post: | chadstyle (12-31-2012) |
#11 |
This happens all the time to us; full droop on our car is about what stock height looks like when its sitting on the ground.
Just leave TC on and it'll automatically apply rear brake for you, or go with handbrake on a little. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | chadstyle (12-31-2012) |
#12 | |
Overall I'm extremely happy with the sway bars and strut brace combination..my car is super stiff and handles amazing under all driving conditions...except leaving the drive thru lol. Someone mentioned to just go a little faster but I'd def scrape up the front end and undercarriage if I did so hopefully the handbrake is my saving grace. It would be a little embarrassing to have to open the door and give a little Fred flintstone push
#13 |
Drives: pinto power
ha, nevermind, you already shot down the flintstone impression.. :rofl:
handbrake, pro status.. |
#14 |
The old Peeing Dog as we call it! Although we usually notice it more on track with FWD cars.
It is odd to see it happening at slow speeds in driveways though. ![]() -Mike Paisan ![]() 11+ Years Maintaining, Modifying and Educating TriState Subaru Enthusiasts. Call directly as We carry almost every manufacturer now, so before you buy parts call us. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) | T-1 Certified Amsoil Direct Jobber |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
