Old 12-22-2012, 11:17 PM   #1
Accurate Race Shop
Accurate Race Shop's Avatar
Drives: Scion FR-S
Goodyear Eagle F1 tires
My local tire guy told me he was invited to a track event to test tires and these really stood out to him. They are a little pricy so I wanted some opinions before I went for it. Also what do you think about having them on as a daily tire. With the price of these tires I might not have money for new rims so they might have to sit on the stock rims for a little bit.
Old 12-22-2012, 11:28 PM   #2
mashal
DADA
mashal's Avatar
Drives: 2013
I had some f1-gs2 I believe on my trans am .. They were very good tires .
That is until I floored her and there was no such thing as good tires then.
I would run them on my frs if I was FI.
mashal is offline   Reply With Quote
Old 12-23-2012, 09:01 AM   #3
wparsons
wparsons's Avatar
Depends on what you want out of them? How much do you care about treadwear? How much do you car about road noise? Are you upgrading from the stock tires because you want more grip? Even the stickiest version (Eagle F1 Supercar G: 2, not available in anything close to a good size for these cars) is a 220 treadwear rating so it's probably not going to be the grippiest option out there. The Hankook RS3's are 140.
There's also about a dozen different Eagle F1 tires... a couple are even all seasons.
https://www.tirerack.com/tires/goody...year-tires.jsp
flickr
Old 12-23-2012, 09:47 AM   #4
Accurate Race Shop
Drives: Scion FR-S
I was looking at the eagle f1 asymmetric I do want a larger than 200 tread wear to qualify for stock tires in Auto cross and so they last a little longer I'm looking for more grip than stock but not so much I can't kick the back end out. I thought these sounded like all that from what the guy was saying.
Sent from my SGH-T989 using Tapatalk 2
Old 12-23-2012, 12:46 PM   #5
ZDan
ZDan's Avatar
Drives: '23 BRZ
Eagle F1 Asymmetric or Asymmetric 2?
Go to Tire Rack, read test results:
http://www.tirerack.com/tires/tests/...y.jsp?ttid=140
http://www.tirerack.com/tires/tests/...y.jsp?ttid=162
Best (only?) direct objective comparisons you're likely to find.
I went with Michelin Pilot Super Sports for the FD, no regrets
Old 12-23-2012, 10:35 PM   #6
Accurate Race Shop
Drives: Scion FR-S
Thanks for finding this!
Old 12-23-2012, 11:09 PM   #7
Blue86
Drives: Sonic Blue 86GT Manual
I was going to get the Eagle F1 Asymmetric 2 until I found out about the Continental Extreme Contact DW. Similar performance, very light, better tread wear rating than the Eagles
VERY HAPPY overall!
Blue86 is offline   Reply With Quote
Old 12-23-2012, 11:37 PM   #8
ravenblackfrs
ravenblackfrs's Avatar
Drives: 2013 Raven Black FRS
Dunlop Direzza's? I've heard about those on the Road and Track magazine or whatever... said it shaves a second off 0-60... not sure if thats true.
ravenblackfrs is offline   Reply With Quote
Old 12-24-2012, 02:58 AM   #9
Accurate Race Shop
Drives: Scion FR-S
The more I read online the more confused I get lol. I really just want a good AutoX tire I can leave on the car and use daily I have coil overs on the car and I can adjust camber if needed for any future comments. Thanks everyone you are all giving me a lot to look into before I make my final choice.
Old 12-26-2012, 01:56 PM   #10
wparsons
wparsons's Avatar
The Star Spec Z1's (TW rating of 200) are about the best you can get that are rated >= 200.
flickr
Old 12-26-2012, 02:05 PM   #11
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
You're automatically ineligible w/ coilovers for stock--you have an STX car @ the very least.
So, treadware won't be of concern for a streetie--so, your best tire choice is the Hankook R-S3 (previously mentioned by wparsons). It's the best dry-grip tire out there, IMO. It's not the best in the wet, but seeing you live in PHX, I don't think rain will be much of an issue for you.
The GY tire can't come close to the dry performance of the R-S3s--and they should be much cheaper...
GTB/ZR-1 is offline   Reply With Quote
Old 12-26-2012, 06:29 PM   #12
Accurate Race Shop
Drives: Scion FR-S
I meant street tires not stock and that is something new in the works I hear anyone with less than 200 tread wear isn't considered on a street tire even if dot approved. Do you know if the rs-3 are good in extreme heat like the over 120 degree pavement in Phoenix.
Old 12-26-2012, 07:39 PM   #13
Red5
Drives: FRS
The RS3s have been pretty much dominating SCCA solo for awhile now, at least as far as non-slick tires are concerned. They don't last very long though, and wet performance could be an issue here (southern AZ) in monsoon season, so you'll have to keep that in mind. the RS3s are pretty amazing tires, though a lot of FRS AutoX-ers seem to be using star specs.
The 2013 SCCA rulebook hasn't been released yet AFAIK, but there HAS been word of a minimum treadwear increase for this year, but if you know how the treadwear number is decided, I don't doubt Hankook will just make a "new" RS3 (RS4 maybe?) and raise the treadwear to make them legal.
Red5 is offline   Reply With Quote
Old 12-27-2012, 12:52 AM   #14
Accurate Race Shop
Drives: Scion FR-S
Yeah it is always good knowing guys like you with knowledge in areas I don't have. I wanted the good year because they last a little longer as a daily tire and are great in water. I know they are not as good as others but running them daily I can't really expect them to be the best. But from the sounds of things I need to suck it up and buy a second set of rims because good on the skid pad and good on the street just don't seem to come in the same package.
goodyear, rims, tires
What tires came on your FRS? hislargeness Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 36 01-11-2013 11:30 AM
FS: Gramlights 57d 17x9 +38 5x114.3 w/ tires 1500 miles on tires, $1800 shipped apexsti46 Wheels and Tires 6 09-05-2012 02:54 AM
So what non-OEM tires have been tried so far on BRZ/FRS? suzuka Scion FR-S / Toyota 86 GT86 General Forum 20 05-07-2012 10:33 AM
What tires do you want? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 123 12-12-2011 02:15 PM
