Old 12-21-2012, 09:56 AM   #1
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Arrow Holy Shift Knob!
http://www.ebay.com/itm/BRZ-Delrin-R...f087fa&vxp=mtr
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 12-21-2012, 09:59 AM   #2
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
In case you miss that Semi truck feel?
microbionic is offline   Reply With Quote
The Following 3 Users Say Thank You to microbionic For This Useful Post:
Ingen (12-21-2012), SkAsphalt (12-21-2012), Turbowned (12-21-2012)
Old 12-21-2012, 10:02 AM   #3
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
Holy Frankenshifter!
Looks like it was recycled from ROBOCOPS Achilles Tendon!
13 FR-S Veteran is offline   Reply With Quote
Old 12-21-2012, 10:09 AM   #4
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
Now get your girlfriend to sit on it..
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
The Following 5 Users Say Thank You to enjoi23 For This Useful Post:
flippy (12-21-2012), GaN-MaN (12-21-2012), JoeBoxer (12-21-2012), lbroskee (12-23-2012), powerj2 (12-21-2012)
Old 12-21-2012, 10:11 AM   #5
Burrcold
Drives: Subaru BRZ Limited
Maybe the owner has REALLY short arms?
Old 12-21-2012, 10:20 AM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
It's not my thing, but maybe the owner just appreciates steering with 2 hands (the proper way). The farther you move your hand from the wheel when shifting, the less time you spend in true control of the car.
Those of you who think the shift knob is a handrest won't understand.
Here is a picture of a modern WRC car. Big truck shifters aren't slow.
celica73 is offline   Reply With Quote
Old 12-21-2012, 10:32 AM   #7
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
This is true!
My only concern is for those that currently put their thumb on top of the shifter knob when putting the car in reverse. Good luck with that
2URGSE
Old 12-21-2012, 10:35 AM   #8
ZC6BRZ
Wannabe JDM Type S
ZC6BRZ's Avatar
Drives: 2013 BRZ Limited
I dig it. but 150 bucks? Whoa.
ZC6BRZ is offline   Reply With Quote
Old 12-21-2012, 10:54 AM   #9
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
I get the concept, but the WRC cars are using a sequential gearbox. It's always just forward or back not through a gated pattern like our cars.
Edit:
Also kind of defeats the purpose of a short throw shifter which is also all about spending less time shifting.
Old 12-21-2012, 10:57 AM   #10
gmookher
I'm not allowed to say it
gmookher is offline   Reply With Quote
Old 12-21-2012, 11:05 AM   #11
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Edit:
You combine them with a short shifter to get shifts the same as the stock car. Having the shifter as close as possible to the steering wheel is more important (on the track at least) then a notchy short shift is.
@gmookher : Yes you can, the only moderating that's happened to you has been you not seeing your own posts and thinking they've been deleted.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 12-21-2012, 11:10 AM   #12
Mitch
form follows function
Drives: RIP '13 BRZ
Edit:
Right, the point on the rally cars is to have the sequential shifter as close to the wheel as possible to minimize time with a hand off the wheel. It's extremely fast when you're operating a sequential box. It'd be a nightmare for an H pattern.
Mitch is offline   Reply With Quote
Old 12-21-2012, 11:47 AM   #13
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
One thing to consider is just a little bit of pressure puts x times more ft. lbs. of tension on the stock gearshift bushings and maybe other components compared to the stock lever. Whereas that WRC shifter has a shifter completely built to take abuse.
I used this custom shifter in my MR2 for like... a week... but took it off because every time I shifted it felt like I was going to rip the linkage apart. It completely does away with whatever sensitivity you normally feel of the gears through the shifter and numbs the feeling of oneness with your car.
Old 12-21-2012, 12:29 PM   #14
JACK 8URT0N
Black Blood of the Earth
JACK 8URT0N's Avatar
Drives: The Porkchop Express
Well, I like it. Plus, a higher knob means more leverage, which makes getting into notchy 2nd gear much easier. The price is a bit much though. It would be better to get a normal knob with an 2-3" extension instead.
It's all in the reflexes.
JACK 8URT0N is offline   Reply With Quote
Shift Knob Jwong FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 29 12-12-2014 01:33 AM
TRD Shift Knob NG86 AUSTRALIA 21 12-13-2012 06:30 PM
Shift Knob yomchi1989 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-07-2012 09:19 PM
Shift Knob yomchi1989 AUSTRALIA 0 12-07-2012 09:00 PM
