Old 12-20-2012, 10:37 AM   #1
MI FR-S
MI FR-S's Avatar
Drives: Ultramarine FR-S MT
Center Stack Rattle anyone?
I've been getting a rattle from the center stack area
It only wants to show up after about 20 - 30 minutes of driving. The days have been cold around here so it could be cabin temperature related.
Once it starts to rattle it will continue at any speed I can manage during my commute (2-3 mph up to 55mph) It disappears when the car is stationary and usually reappears once I start moving.
The rattle seems to be coming from the trim around the HVAC vents above the radio head unit.
If I press firmly on the trim the rattle stops until I release the pressure.
Pressing down hard on the top of the dash will also stop the rattle but pressing on the trim seems to need less force.
Anyone else have this?
Anyone removed trim pieces in this area and can point me at a "how to" so I don't break anything when I try?
Thanks.
MI FR-S is offline   Reply With Quote
Old 12-20-2012, 11:10 AM   #2
deucethemoose
Functionally Retarded
deucethemoose's Avatar
Drives: LinkECU V6 MR2 - MKVII Golf R
I have this. I press up on the faux carbon trim just above the HVAC and it stops, only to return a minute or so after I let go.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
I'm not really an asshole, but I play one on the internet.
deucethemoose is offline   Reply With Quote
Old 02-13-2013, 07:54 PM   #3
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
I have the same issue on my BRZ, any luck?
microbionic is offline   Reply With Quote
Old 02-14-2013, 03:57 PM   #4
sdshores08
sdshores08's Avatar
Drives: 2013 Ultramarine FR-S, AT
I had a rattle up there. The tops of the center AC vents have loosely fitting pieces of plastic that need to be taped down. There was a thread on it, but I can't find it now.
Just remove the trim around the radio and there should be a couple of screws holding the vents in place. Remove them, and pull out the vents. You'll notice what needs to be taped down on top of the vent assembly.
sdshores08 is offline   Reply With Quote
The Following User Says Thank You to sdshores08 For This Useful Post:
tripjammer (03-12-2013)
Old 02-28-2013, 11:57 PM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I got this problem .. Will look to remedy it soon ...
Old 03-01-2013, 09:39 AM   #6
infinite012
Drives: 13 DGM BRZ Ltd
Try to use that felt tape stuff that some car companies use.
infinite012 is offline   Reply With Quote
Old 03-02-2013, 11:43 AM   #7
Jlin
Drives: FRS
m.youtube.com/watch?v=ZTMstHBsfV4
i made a vid. i dunno if it's the same thing you guys are experiencing. it's driving me nuts
Jlin is offline   Reply With Quote
Old 03-03-2013, 01:31 AM   #8
Jlin
Drives: FRS
sorry, wrong link
[ame="http://www.youtube.com/watch?v=ZTMstHBsfV4&list=UUGaxin-6IjN6zfYYIQmfdmQ&index=1"]center rattle - YouTube[/ame]
In the video you can hear the tick tick tick. That's the sound i'm hearing. Anyone else experience the same thing?
Old 03-03-2013, 02:14 AM   #9
sdshores08
sdshores08's Avatar
I had it and fixed it. I really think it's the top of the AC vent in your case as well. Definitely worth checking out
Old 03-03-2013, 10:31 AM   #10
Jlin
Drives: FRS
Alright, will be taking a look at it today, so it's clearly visible when i pull off the trim piece?
Old 03-03-2013, 11:36 AM   #11
Turbowned
Turbowned's Avatar
Someone post a DIY!
Old 03-03-2013, 01:34 PM   #12
Jlin
Drives: FRS
i took the vents out and taped the top part that's loose and the rattle is still there it sounds like it's coming from below the audio deck and behind the hvac knobs.....
Old 03-03-2013, 03:57 PM   #13
sdshores08
sdshores08's Avatar
Ah bummer. Maybe it's some wires tapping around back there
Old 03-03-2013, 11:20 PM   #14
Jlin
Drives: FRS
that's what I'm thinking, gonna have to wait until i have more free time on my hands to pin point this, might even tell the people at the dealership to do it. I'll have to live with it for now.
The Following User Says Thank You to Jlin For This Useful Post:
FS/FT: OEM FRS Center Caps (Trade for Subaru Center Caps) Meeners Wheels and Tires 4 11-20-2012 04:47 PM
Rattle from the middle of the car brichard0625 Issues | Warranty | Recalls / TSB 11 10-05-2012 07:04 PM
Does anyone have a rattle coming from the center dash? Liquidsnake Scion FR-S / Toyota 86 GT86 General Forum 29 09-30-2012 10:09 AM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
FR-S center stack blk Scion FR-S / Toyota 86 GT86 General Forum 81 02-29-2012 01:03 AM
