Old 12-09-2012, 07:39 PM   #1
SupMate
Drives: FRS ASPHALT AT
blizzak ws70 tire pressure
i recently had a set of 205/55R16 ws70 mounted with the tpms all set up. While driving the past Friday, the tpms indicator went off and so I went ahead and add the pressure to the recommended 35 psi. The tpms light was still on.. so i checked online at tirerack and it says the max pressure is 44 psi and so i added it to 44 psi, yet the light was still on. Anyone with similar problems? Maybe I need to have the tpms reset?
SupMate is offline   Reply With Quote
Old 12-09-2012, 08:17 PM   #2
RazorHawk
Drives: 2013 Scion FR-S 6AT Firestor
New TPMS sensors need to be learned to the car, and it will forget the old ones. They will have to dismount the new tires to get to the codes on the sensors, then remount and rebalance them, and MAKE SURE THEY TAKE DOWN THE OLD CODES BEFORE THEY CLEAR THEM! because if they are not written down, they will have to dismount, remount, and balance the summer tires as well when they put them back on.
2013 FR-S #04790 Firestorm, AT with:
Beatsonic Shark Fin Antenna
5AD Spoiler
205/55R16 Michelin X-Ice3 winter tires on Motegi MR 107 x 16 Rims (winter only)
Rally Armor mudflaps in black with red logos
RazorHawk is offline   Reply With Quote
Old 12-09-2012, 09:06 PM   #3
OrbitalEllipses
Drives: Attitude
What he said. Sensors need to be programmed. Also let some air out...a few psi on winter tires shouldn't be a problem (recommended depending on who you talk to), but 9 psi over is pushing it.
Tire pressure of all-seasons Scoob Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-12-2012 12:49 AM
Tire pressure warning on sa1126 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-27-2012 08:26 PM
Prefered tire pressure guage? diirk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-26-2012 03:48 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 05:32 PM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 09:04 AM
