Old 10-27-2012, 04:19 PM   #1
sa1126
Drives: n/a
Tire pressure warning on
I took the car to the dealer this morning (for them to run diagnostics on crickets issue) and now the light is on. Is there something I can do or should I just wait until they get my parts?
Raven MT as of 07-09-2012
'01 Taco prerunner
sa1126 is offline   Reply With Quote
Old 10-27-2012, 04:24 PM   #2
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
Do you have OEM wheels with the sensors? If so, I would start by checking tire pressures. Nothing says you didn't run over a nail on the way home.
celica73 is offline   Reply With Quote
Old 10-27-2012, 04:28 PM   #3
sa1126
Drives: n/a
Stock wheels/tires, never been removed from the vehicle.
I checked the pressure--all set the same around 30 psi.
It was fine this morning on the way to the dealer, it just came on when I turned the car on after leaving.
'01 Taco prerunner
Old 10-27-2012, 07:22 PM   #4
wparsons
wparsons's Avatar
IIRC, stock pressure is 35psi all around? I also think the sensors stock will go off if the pressure is +/- 3 psi from what they want for pressure.
Check the manual or door sticker, it'll tell you what the pressure should be for sure.
flickr
Old 10-27-2012, 07:30 PM   #5
mugen79
mugen79's Avatar
Drives: Ultramarine FRS(MT), IS350(sold)
My tires were at 32 psi and tire pressure light came on occasionally. So I took my car to the dealer and they said tires should be at 35psi so they filled it up and reset the sensor and lights are off now.
But it is strange how at 32psi, the light would come on.
mugen79 is offline   Reply With Quote
Old 10-27-2012, 07:32 PM   #6
sa1126
Drives: n/a
I filled them up to 35 and the light was on for about 10 minutes before going out. Strange but crisis averted. Sorry for the waste of the post, I guess the cold front that blew through had an effect on the tire pressure.
'01 Taco prerunner
Old 10-27-2012, 07:45 PM   #7
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Your tire pressure changes roughly 1 PSI for every 10 degrees of temperature. It is probably colder now than when the tires were originally inflated. If they were originally inflated to 32psi @ 80F and now it's 50F outside guess what... they're probably at 29psi or close to it. Voila, TPMS light will come.
I'm sure it's in the manual but does anyone know if the spare tire has a TPMS sensor it in? My dad's CRV did this. His TPMS light was on and it was caused by the spare tire being too low.
Old 10-27-2012, 08:26 PM   #8
dsgerbc
Drives: BRZ(sold), STI
Rule of the obvious: "XYZ warning light on" -> bring XYZ to correct specs.
30 psi will trigger the light.
dsgerbc is offline   Reply With Quote
oil pressure gauge onemorelap Engine, Exhaust, Transmission 69 03-04-2023 05:46 PM
Prefered tire pressure guage? diirk Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-26-2012 03:48 PM
BEST TIRE PRESSURE TO RUN TRACK karma003 Tracking / Autocross / HPDE / Drifting 13 10-24-2012 05:32 PM
WTB: Tire Pressure Monitoring Sensors (TPMS) RYU Wheels and Tires 6 09-18-2012 12:52 PM
phantom tire pressure warning eikond Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-04-2012 09:04 AM
