Old 11-29-2012, 09:33 PM   #1
pr086
Drives: fast
check your airboxes
is everyone's like this? you have to kneel down at the bumper to get this view. see how it looks like it isn't closed flush?
pr086 is offline   Reply With Quote
Old 11-29-2012, 09:39 PM   #2
CrazyWookiee
Drives: Whiteout FR-S
No, your airbox is not closed tight.
I think they probably rushed to get your filter in either during PDI or when they were installing it. Just unlatch it, pull out the filter and check it isn't pinched or damaged. Chances are they either flipped the filter around, or the tabs on the bottom side of the plastic cap aren't in the proper holes.
For the few cars I've tried, putting in the drop in filter results in this if the filter is being pinched or a bit thicker than normal. Might take a bit of elbow grease to pop it in properly.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 11-29-2012, 09:41 PM   #3
pr086
Drives: fast
i unlatched the hooks to try and look in there but it didn't seem to pull apart to give me access to the filter? is there something i need to do other than pop the 2 latches on top?
Old 11-29-2012, 09:47 PM   #4
CrazyWookiee
No, the clips are the only thing that hold the filter in. The half not facing the front has to be lifted up a bit (so that the tabs on the underside that go into a hole come up) and pulled backwards at the same time to release the filter.
Old 11-29-2012, 10:04 PM   #5
pr086
Drives: fast
Ok i repostioned the filter, any tips on fitting the box back together?
Old 11-29-2012, 10:34 PM   #6
pr086
Drives: fast
Best i could do was get it closed up and looking exactly the way it did ehen i started. Cant tell why its bulging like that
Old 11-29-2012, 11:39 PM   #7
Jlin
Drives: FRS
the air box is such a pain in the ass to put back together, it took me a long while trying to get it back together after putting in the TRD filter.
Be patient and wiggle it around until you get it right.
Worked for me
Jlin is offline   Reply With Quote
Old 11-30-2012, 06:45 AM   #8
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
It was a pain for me as well. To put it into perspective, it's harder to install the filter right than it is to remove the entire stock intake and install an aftermarket one. lol Too bad an aftermarket intake resulted in me having to go back to the stock intake because my car ran like S**T!
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 11-30-2012, 06:50 AM   #9
pr086
Drives: fast
I might give it a try again. How did you guys get it to seal up correctly? As far as i can tell i have the filter sitting correctly
Old 11-30-2012, 08:14 AM   #10
pr086
Drives: fast
Are a lot of people's boxes closed like this? Is there any danger in driving with it like it is in the first pic? I want to close it correctly but can't get it to.
Old 11-30-2012, 10:06 AM   #11
JoeBoxer
JoeBoxer's Avatar
I replaced the tube from the airbox to the throttle body, the airbox is a lot easier to get to and get resealed with that tube off. Kind of a pain but it is way easier once you have the tube out.
JoeBoxer is offline   Reply With Quote
Old 11-30-2012, 11:12 AM   #12
pr086
Drives: fast
just noticed this in a pic from a thread in the members journals section, his air box is like mine. have you guys checked yours yet? are they all like this from the factory?
Old 11-30-2012, 11:13 AM   #13
ProTekk
ProTekk's Avatar
Mine is the same way
Sent from my SGH-T999 using Tapatalk 2
ProTekk is offline   Reply With Quote
Old 11-30-2012, 11:40 AM   #14
pr086
Drives: fast
saw a few more like that from engine bay pics on here. i'm starting to think they're all like that and i should stop messing with it.
Check out this FR-S Redline360 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 08-06-2012 11:58 AM
Check out these wheels Redline360 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 07-26-2012 12:13 AM
Got to check out the FR-S... r4m3n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 75 03-02-2012 09:18 AM
Check in, eh? NorthFool CANADA 24 02-23-2012 07:32 AM
Check this out nogaroblues4 Electronics | Audio | NAV | Infotainment 6 02-20-2012 08:34 PM
