Drives: fast
check your airboxes
is everyone's like this? you have to kneel down at the bumper to get this view. see how it looks like it isn't closed flush?
#2 |
Drives: Whiteout FR-S
No, your airbox is not closed tight.
I think they probably rushed to get your filter in either during PDI or when they were installing it. Just unlatch it, pull out the filter and check it isn't pinched or damaged. Chances are they either flipped the filter around, or the tabs on the bottom side of the plastic cap aren't in the proper holes. For the few cars I've tried, putting in the drop in filter results in this if the filter is being pinched or a bit thicker than normal. Might take a bit of elbow grease to pop it in properly. |
#3 |
Drives: fast
i unlatched the hooks to try and look in there but it didn't seem to pull apart to give me access to the filter? is there something i need to do other than pop the 2 latches on top?
#4 |
No, the clips are the only thing that hold the filter in. The half not facing the front has to be lifted up a bit (so that the tabs on the underside that go into a hole come up) and pulled backwards at the same time to release the filter.
#5 |
Drives: fast
Ok i repostioned the filter, any tips on fitting the box back together?
#6 |
Drives: fast
Best i could do was get it closed up and looking exactly the way it did ehen i started. Cant tell why its bulging like that
#7 | |
Drives: FRS
Be patient and wiggle it around until you get it right. Worked for me |
#8 |
Chronic Flashturbator
Drives: '13 Scion FR-S MT
It was a pain for me as well. To put it into perspective, it's harder to install the filter right than it is to remove the entire stock intake and install an aftermarket one. lol Too bad an aftermarket intake resulted in me having to go back to the stock intake because my car ran like S**T!
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
#9 |
Drives: fast
I might give it a try again. How did you guys get it to seal up correctly? As far as i can tell i have the filter sitting correctly
#10 |
Drives: fast
Are a lot of people's boxes closed like this? Is there any danger in driving with it like it is in the first pic? I want to close it correctly but can't get it to.
#11 |
I replaced the tube from the airbox to the throttle body, the airbox is a lot easier to get to and get resealed with that tube off. Kind of a pain but it is way easier once you have the tube out.
#12 |
Drives: fast
just noticed this in a pic from a thread in the members journals section, his air box is like mine. have you guys checked yours yet? are they all like this from the factory?
#14 |
Drives: fast
saw a few more like that from engine bay pics on here. i'm starting to think they're all like that and i should stop messing with it.
| Check out this FR-S | Redline360 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 08-06-2012 11:58 AM |
| Check out these wheels | Redline360 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 07-26-2012 12:13 AM |
| Got to check out the FR-S... | r4m3n | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 75 | 03-02-2012 09:18 AM |
| Check in, eh? | NorthFool | CANADA | 24 | 02-23-2012 07:32 AM |
| Check this out | nogaroblues4 | Electronics | Audio | NAV | Infotainment | 6 | 02-20-2012 08:34 PM |
