Old 11-28-2012, 08:09 PM   #1
pr086
Drives: fast
Reverse is kind of hard to get into
It feels like i have to put a lot of pressure and kind of force it into reverse. Anyone else?
pr086 is offline   Reply With Quote
Old 11-28-2012, 08:11 PM   #2
Asphaltfrs1
Asphaltfrs1's Avatar
Drives: 2013 asphalt fr-s
Yes same here. I usually release the clutch then depress it again. Most of the time it becomes easier. Also I let it warm up.
Asphaltfrs1 is offline   Reply With Quote
Old 11-28-2012, 08:40 PM   #3
wheelhaus
wheelhaus's Avatar
Either let the car roll a bit or let the clutch out in neutral (as @Asphaltfrs1 mentioned) , I'm pretty sure the reverse gear does not have a synchro. Either of the above should respectively rotate the input shaft or the gear stack, which helps to line up the dog teeth and thus, engagement.
wheelhaus is offline   Reply With Quote
Old 11-28-2012, 08:46 PM   #4
SVThis
SVThis's Avatar
Drives: Scion FRS
Letting it warm a bit is about the only thing that really helps. I'm glad it's staying in the garage for winter. I will definitely change the fluid in the spring. This is one cold blooded tranny.
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 11-29-2012, 11:51 AM   #5
Don Ivey
Drives: '13 FR-S
Related to this, I just got my FR-S and the only complaint is 1st to 2nd, and 2nd to 3rd notchiness. I know others have complained about this, but just wondered if it goes away with break in. I have noticed rev matching helps, but I'm lazy and just want to shift (and I shift slowly). Other than that, can't wait to get to one thousand miles so I can let her scream.
Don Ivey
'13 FR-S (Hot Lava)
Don Ivey is offline   Reply With Quote
The Following User Says Thank You to Don Ivey For This Useful Post:
DanoFA20 (11-29-2012)
Old 11-29-2012, 12:09 PM   #6
Razz
Razz's Avatar
Drives: Fast
It's suppose to be notchy
Razz is offline   Reply With Quote
Old 11-29-2012, 07:09 PM   #7
mrlewistan
Driver of FR-S 1467
mrlewistan's Avatar
Drives: 2013 scion frs 001467
I have no issue with it. But I always give the car a few minutes to warm up when the engine/exhaust quiets down
mrlewistan is offline   Reply With Quote
Old 11-29-2012, 07:13 PM   #8
BuBlake
Chronic Flashturbator
BuBlake's Avatar
Drives: '13 Scion FR-S MT
Mine shifts into every gear, including reverse, smooth as can be, just for contrast. I shift into reverse at least once per day to back out of the garage. Only fluid I have changed is the motor oil(To Mobile 1 0w-20) and have 4700+ miles.
My previous car was a 350z with 6-spd manual, which others complained about as well and I didn't, so I may just be used to a relatively touchy transmission or have a high tolerance.
OFT Stg 2 UEL E85 - Borla UEL Header - Invidia Q300 - Invidia catless frontpipe - Fa20club CAI - Billet Power Blocks - Michelin PSS 245/35/18 all around on Motegi Racing SP10 18x8 +38 - Eibach Sportline springs - SPC LCA
BuBlake is offline   Reply With Quote
Old 11-29-2012, 07:34 PM   #9
LIKEABOSS
LIKEABOSS's Avatar
Drives: 2013 Boss 302 & 2013 FR-S
Have any blow 40 degree temps yet? When it's cold it's hard to shift into reverse.
LIKEABOSS is offline   Reply With Quote
Old 11-29-2012, 07:50 PM   #10
PabloN
PabloN's Avatar
Drives: 2013 Scion FR-S, M/T argento
Think there have been posts about this before in cold weather. Here in the Midwest it's been approaching freezing & reverse is just about impossible until the car warms up. I started putting it in reverse when I park in the garage and leaving it there when I start up in the morning. There may be a little more wear on the clutch this way, I don't know...
PabloN is offline   Reply With Quote
Old 11-29-2012, 08:07 PM   #11
BuBlake
BuBlake's Avatar
Car is stored in a garage... Where I live it might reach 40 in there at the peak of winter.
Old 11-29-2012, 08:45 PM   #12
SVThis
SVThis's Avatar
Drives: Scion FRS
Or you just may be lucky. I've owned a bunch of manual tranny cars and never had a problem getting into reverse when cold
Old 11-29-2012, 09:36 PM   #13
pr086
Drives: fast
putting the clutch in and out dosn't seem to help, and letting it roll is rarely an option. i just have to force it in
Old 11-29-2012, 09:48 PM   #14
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
Fortunately, slotting into reverse has not been an issue for myself.
Temperatures have dropped, and the overall notchiness is more present, but still not something for me to be bothered about.
Solid feeling / performing transmission, thus far.
Texas BRZ is offline   Reply With Quote
What kind of computer to use? skatery1989 Engine, Exhaust, Transmission 32 10-25-2012 02:45 PM
Rotiform BLQ Concave 3-pc DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 09-19-2012 01:23 PM
What kind of key we get in FRS? tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 7 05-20-2012 06:52 PM
What kind of car is this? switchlanez Other Vehicles & General Automotive Discussions 11 05-20-2012 04:33 PM
I'm kind of afraid... VenomRush Scion FR-S / Toyota 86 GT86 General Forum 106 09-14-2010 01:53 AM
