Drives: BRZ Limited
What kind of computer to use?
What kind of computer are some of you using with ECU-teck to monitor your car?
Grip>Slip
Anything that will run windows should work. I'm personally running it in a VM on a MacBook Pro. It works fine, although flashing new maps is slower than if i were to user a non-virtual xp or win7 box.
Drives: '13 DGM BRZ Limited
Picked up a Asus X401a laptop from Best Buy for $299. I upgraded the HD to a SSD and the memory to 8GB for another $200. You don't have to do the upgrades, but I didn't want a mechanical HD in the car just in case I hit any bumps. Works just fine for what it is.
Pull my finger...
Drives: Silver Scion Slushbox
I picked up a refurb Lenovo ThinkPad T400 with XPSP3 that will only be used for the sole purpose of flashing the car. I will be swapping out the HD for an SSD at some point.
No way would I ever consider a daily use laptop for that sort of thing. |
Drives: 2003 Subaru Outback
Dell XPS - Paul Walker Limited Edition.
| The Following 5 Users Say Thank You to Tansey86 For This Useful Post: | Bg8780 (10-25-2012), number1Tango (10-25-2012), OrbitalEllipses (10-24-2012), Synack (10-24-2012), xpicer (10-25-2012) |
Drives: 2013 Scion Frs(Scarlet)
i literally just ordered a laptop as well for my car..i got the alienware m14 since my job offered a great discount on dells and i get 18months financing...plus i got it in red to match the car and have FRS engraved on the front cover lol. i know other companies offer more hardware for a better price, but u cant beat 18 months financing..im going to order an ssd like cnk too..dell was charging $550 which is crazy
Drives: 86 ZN6
also got Dell XP3 with i7 and SSD for car stuff
macbook pro for other stuff |
Drives: Whiteout FR-S
Have you guys seen the Chromebook for $249? Would that work?
Drives: Thunder Silver 86 GTS
Is this for logging purposes and if so does that mean you have to have it hooked up while running to record a log? I thought you just hooked up while in your garage and it just took it from the ECU
#10 |
Yessir when logging data u should be running the car while being hooked up to a laptop...2nd gear and 3rd gear pulls from like 3k-7k rpm i think is good for job.
#11 |
Ive seen this but i think it runs its own type of OS. Not sure if ecutek will be work with it or if u might encounter issues
#13 |
I Love custom Turbo kits
Drives: Limited BRZ
Chromebook runs Chrome OS and there is no way to virtualize windows so no, it won't work.
#14 |
Is it hard to run the ecutek cable from the ECU to the cabin or do you somehow have the laptop in the engine bay? (assuming this is while driving and not on a dyno)
| Let's see your computer setup! | Hanakuso | Off-Topic Lounge [WARNING: NO POLITICS] | 79 | 11-06-2022 12:43 PM |
| Computer for my Frs help | Hawaiian | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 09-28-2012 05:51 PM |
| Valve Timing/Computer | miss paula | Issues | Warranty | Recalls / TSB | 3 | 09-20-2012 04:27 PM |
| Gaming Computer (High end) | WolfsFang | Miscellaneous | 6 | 09-09-2012 09:42 AM |
