Old 11-26-2012, 08:52 AM   #1
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Has anyone used Premium Auto Styling's roof wrap?
I'm thinking about wrapping my roof in gloss black. Premium Auto Styling has a pre-cut piece of vinyl for sale with the antenna hole cut out.
Has anyone used it? How was it going on? Was there a gap between the antenna and the roof (leaving the roof color exposed)?
http://www.premiumautostyling.com/20...vinyl-overlay/
Grimlock is offline   Reply With Quote
Old 11-26-2012, 02:35 PM   #2
itdansharpe
itdansharpe's Avatar
I haven't used this particular kit, but I can suggest using a light spraying of windex before applying the vinyl. This will give you time to adjust the vinyl and ensure a precise install.
I'm considering this as well.
New: 2014 6MT Asphalt Rota Titan 17x9, RS-3 V2, Skunk2 Pro-C, Eibach Sway Bars, Password:JDM Strut Tower Bar, Perrin MCB, StopTech Stainless Lines, Hawk HP+, Nameless 3" Exhaust, VG Sharkfin, FIVE:AD Spoiler, DDM Tuning HID's 5k, HID
Old: 2013 6AT Boosted Firestorm..
itdansharpe is offline   Reply With Quote
Old 11-26-2012, 04:37 PM   #3
scyzer
Drives: GTS 86
Windex on vinyl? Is that safe?
I know you're never supposed to use *windex* on tints - a quick google shows people saying to stay away from windex on vinyl.
scyzer is offline   Reply With Quote
Old 11-27-2012, 08:27 AM   #4
itdansharpe
I just confirmed with a friend of mine who runs a sign shop. I am wrong, it can be applied dry. My apologies.
Old 11-27-2012, 11:59 AM   #5
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Soapy water allows for the movement you desire. You just have to squeegee it out and let the bubbles work themselves out, though.
Old 11-27-2012, 12:01 PM   #6
itdansharpe
Not just the movement, sometimes it's helpful to re-apply the vinyl in certain areas, and being able to pull it up helps. There is 'window tint' safe spray, I wonder if that would be a good option. I think soap would take too long to dry under the vinyl.
Old 11-27-2012, 03:26 PM   #7
Jayde
Jayde's Avatar
Wouldn't be surprised if the lubricant for applying the film is the same as those used for clear bra to make the adhesive responsive and sticky. I'd look into a wrap on the roof too, but mine is already mostly clear braed.
Jayde is offline   Reply With Quote
Old 11-27-2012, 03:55 PM   #8
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
you're going to want to use soapy water, NOT windex. soapy water dries up. those lubricants such as windex or window cleaner will not dry or squeeze out. i have tried this already.
VSGTS14 is offline   Reply With Quote
Old 12-03-2012, 10:00 AM   #9
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I'm still wondering if there would be a gap around the antenna hole.
Old 12-03-2012, 02:30 PM   #10
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
The antenna is easy to remove. Then you don't need to worry about a gap around the antenna just have them give you a solid piece without a cutout.
Area86 is offline   Reply With Quote
Vinyl/Matte Roof Wrap Wesley Cosmetic Modification (Interior/Exterior/Lighting) 104 11-05-2016 08:18 PM
WRB Premium BRZ Auto. Transmission Available! ShoShin BRZ First-Gen (2012+) — General Topics 1 11-16-2012 07:25 PM
Silver BRZ Premium Auto, Dutchess County NY Jayde Dealer Cars 1 06-19-2012 10:30 AM
