Old 11-18-2012, 08:00 AM   #1
acro
Drives: GT-86
Halogen assembly to HID
In some countries the frs comes with either projector halogens or projector HID's does anyone know what would be needed to change the entire halogen lights to the HID headlights, what would the wiring be like and what extras might be necessary
acro is offline   Reply With Quote
Old 11-18-2012, 12:32 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Cheap way is a plug n play hid kit with bulbs, wiring, and the hid ballast. However the halogen projectors are not meant for this and this can blind those in front of you. There is something called a squirrel finder that should be bent down to stop the light from reflecting to far up. Otherwise get a retrofit kit with the proper projectors and mounting brackets for the oem look. The Retrofit Source sells a premade retrofit kit if that's the route you want to go
Halogen manual leveling works with edm/jdm HID headlights ? adprokid Cosmetic Modification (Interior/Exterior/Lighting) 0 07-03-2012 12:32 PM
HID Yellow Fog Lights and Rear Halogen Fog Light Lighting Red Cosmetic Modification (Interior/Exterior/Lighting) 35 06-29-2012 09:57 PM
Door Assembly Lefty Scion FR-S / Toyota 86 GT86 General Forum 2 06-22-2012 12:58 PM
BRZ and 86/FRS Assembly Line Moto-P Scion FR-S / Toyota 86 GT86 General Forum 6 06-14-2012 11:17 AM
6000k Halogen bulbs? CyberFormula Cosmetic Modification (Interior/Exterior/Lighting) 8 04-22-2012 03:41 AM
