Old 11-15-2012, 06:20 PM   #1
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
What do you want for your frs/brz?
What do you guys want to be built for your frs/brz? I'm trying to work with a shop and they need ideas and suggestions on what to fabricate. This can be anything from a single nut to an armrest, to anything else you guys might want to be put into production. I'm trying to go for something that other people have not yet produced.
Andrew360 is offline   Reply With Quote
Old 11-15-2012, 06:25 PM   #2
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Not yet produced? A toilet seat, maybe?
GTB/ZR-1 is offline   Reply With Quote
The Following User Says Thank You to GTB/ZR-1 For This Useful Post:
PERRIN_Chris (11-16-2012)
Old 11-15-2012, 06:27 PM   #3
SubarooMike
SubarooMike's Avatar
Drives: Subaroooo
I just want A brz.....
SubarooMike is offline   Reply With Quote
Old 11-15-2012, 06:33 PM   #4
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Probably not possible from a small company but some decent looking tailights would be great.
JoeBoxer is offline   Reply With Quote
Old 11-15-2012, 06:49 PM   #5
Norkoastal
Never on Time Always Late
Norkoastal's Avatar
Drives: #silenced crickets
I'd say simple stuff would include:
visors with lighting, under dash lighting, door sill lighting
3rd brake delete kit with low pro replacement.
Rear center console storage (over existing "hump")
Trunk organizer
Sunglasses overhead storage
Radar detector storage cubby
armrest kit - stage 1 cheap simple/removable, - stage two hinge design, stage 3 sliding with magnetic catches.
instrument cluster pods for gauges (over MPH section)
Rear speaker brackets for larger speakers
Rear upper seat with speaker opening
CO>CA Cartel
Norkoastal is offline   Reply With Quote
The Following 2 Users Say Thank You to Norkoastal For This Useful Post:
Dispect (11-15-2012), JoeBoxer (11-15-2012)
Old 11-15-2012, 07:50 PM   #6
Maik L
Maik L's Avatar
Drives: Gt86
what I want now is a armrest with matching design - maybe a slider
Maik L is offline   Reply With Quote
Old 11-15-2012, 07:55 PM   #7
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
A good 3rd brake light kit.
Old 11-15-2012, 08:15 PM   #8
russv
First 86
russv's Avatar
Drives: Scion FRS Argento Automatic
For the lower fog light.
Life is short...NO BORING CARS
russv is offline   Reply With Quote
The Following User Says Thank You to russv For This Useful Post:
dem00n (11-15-2012)
Old 11-15-2012, 08:21 PM   #9
DanoFA20
Shift Down
DanoFA20's Avatar
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
RCE Suspension, stoptech rotors /pads, Nice Perrin or Invidia cat back exhaust a STG 1 ecu tune. bigger sway bars upper strut brace .
Works Miester S1R 17x8 225/40 tires.
that'll do pig that'll do :happy0180:
DanoFA20 is offline   Reply With Quote
Old 11-15-2012, 08:45 PM   #10
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
What're you able to produce at the moment?
Things that I would be interested in:
A no drilling needed armrest that opens up to the cup holder area.
A decent phone holder option.
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
KGFRS86 (11-15-2012)
Old 11-15-2012, 09:06 PM   #11
Coconuts
are delicious
Coconuts's Avatar
Drives: 1998 Acura NSX
FR-S Concept rear bumper and taillights please.
Coconuts is offline   Reply With Quote
The Following 2 Users Say Thank You to Coconuts For This Useful Post:
Freeman (11-15-2012), MarkMash (11-16-2012)
Old 11-15-2012, 10:24 PM   #12
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
Couldn't this be accomplished with a strong double side tape(3M) instead of the screws?
Cade01 is offline   Reply With Quote
Old 11-15-2012, 10:51 PM   #13
Freeman
Freeman's Avatar
Possible, but I was thinking of one side hinged so you could flip it open and use the storage area under neath. No idea if this is even possible though. Not sure if there are existing bolt holes close by to use as a mounting point.
Freeman,
Ultramarine FR-S Auto
Thank all the posts!!!!
Old 11-15-2012, 11:35 PM   #14
Cade01
Cade01's Avatar
Freeman,
You could have a hinged lid even if you used an adhesive to mount it, it would just have to be strong.
