Old 11-14-2012, 10:43 PM   #1
Shizzaw
Shizzaw's Avatar
Drives: Whiteout FR-S
Back in shop...
So I'm driving home the other night from work. I accelerate on the on-ramp to the freeway when I notice I've lost a lot of power so I floor it. The engine then gets very loud so I pull off the road and before I can even come to a complete stop, it dies. Initial suspicion from the dealer was bearing noise. But after flying in a Toyota guru, I'm told that there are parts on order via a voicemail on my phone. He didn't specify what parts were on order so I called to ask. Turns out it needs a new lower block, cam shafts, and a bunch of other odds and ends. This car only has 3790 miles on it. I was also an unfortunate victim of the CEL issue right after I bought it. Should I be asking for a new car here? California Lemon Law requires the same problem 3 times but if I ever tried to sell this down the road in a few years, anyone who looks at a carfax is gonna see some major engine work was done. I've also lost faith in this NEW car's reliability and when I commute 80 miles each way to work, reliability is something I require.
Shizzaw is offline   Reply With Quote
Old 11-16-2012, 08:34 PM   #2
eurospeed
Couple of questions:
How long was it in the shop for the CEL repair?
What was replaced/repaired/touched?
You may want to look into the lemon laws for CA. I would think the CEL repair plus the engine repair time will exceed the usual 30 day mark for a lemon.
In addition, I would be willing to bet there is a strong correlation between the CEL/idle issue and the engine failure. It sounds like a similar failure others have experienced here.
eurospeed is offline   Reply With Quote
Old 11-16-2012, 10:14 PM   #3
FirestormFRS
I'd bet they're replacing the entire long block (block and heads minus accessories). That's not always a bad thing though.
FirestormFRS is offline   Reply With Quote
Old 11-16-2012, 11:26 PM   #4
whataboutbob
AutoX-10/10ths every run
Sorry to hear that your problems are continuing.
I'd be asking for a new motor at this point myself.
:happy0180:
Build thread:Here
Old 11-17-2012, 09:25 AM   #5
jesperswe
Drives: GT86
Ouch, well you are not the first person to have an engine failure after CEL fix
Afaik the other cars which failed was due to techs not doing their job right.
jesperswe is offline   Reply With Quote
Old 11-17-2012, 09:38 AM   #6
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
Mechanical repairs will not show up on a car fax only your service history and it doesn't change the value
20valvewynn83 is offline   Reply With Quote
Old 11-17-2012, 09:39 AM   #7
gmookher
curious were you on the factory fill of motor oil at that mileage?
gmookher is offline   Reply With Quote
Old 11-17-2012, 05:08 PM   #8
Shizzaw
Shizzaw's Avatar
The initial CEL repair was a total of 28 days. They replaced an oil control valve, and ECU. The car has now been there for this repair for 11 days so far.
Yup. Got a call saying Toyota doesn't want to take a chance with repairs. They are replacing it completely.
Good to know.
Yes I was. But was told it was a full synthetic oil and shouldn't have had to change it until 5000 miles.
Old 11-17-2012, 08:44 PM   #9
FirestormFRS
Rest easy then, replacing the whole thing its a ton more reliable than rebuilding one that blows up. Todays engines are so very tight on tolerances and oil passages the slightest debris can block one and lock an engine up in a matter of miles.
Old 11-18-2012, 04:59 PM   #10
Shizzaw
Shizzaw's Avatar
Reading through the California Lemon Law, it appears that if a new vehicle has been disabled for more than 30 days and it's been reported to the manufacturer (I've reported both incidents to Scion Corporate) that I am legally allowed to file for this law. Do you guys recommend filing or just let them replace the engine??
Old 11-19-2012, 08:10 PM   #11
eurospeed
I would demand a new car, but that is my opinion and others may be content with an engine rebuild. There are far too many variables when replacing an engine in non factory conditions which could introduce new issues. The stuff people don't think of is the damage to the body, paint, dirt and FOD introduced in the engine and transmission, improper bolt torquing, misaligned splines, improperly adjusted belts, chains, damaged wiring, contamination in various fluids, less than careful mechanics, etc., etc.
Regarding your vehicle history, it may not necessarilly show up in Carfax, but if other buyers are as particular as I am, I always make it a point to get the service history for any used car I plan on purchasing. That would definitely show the details as to what was done to the car and I would walk if any major engine work was performed early in its life.
Old 11-20-2012, 03:53 PM   #12
Rob_g
Drives: 2010 4Runner Trail
Honestly, if I was buying a used FR-S or BRZ in a few years, I would probably refrain from the 2013 model year. That is assuming of course this whole CEL thing is a non-issue for 2014 model year and forward.
Rob
Rob_g is offline   Reply With Quote
Old 11-20-2012, 07:13 PM   #13
Shizzaw
Shizzaw's Avatar
Has anyone here ever claimed the lemon law? Am I required to hire a lawyer to serve them with papers or do I just speak to the dealership management about it? Or maybe go through my insurance??
Old 11-20-2012, 09:21 PM   #14
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
I almost did once. There are attorneys that deal specifically in lemon law cases. Ask the lawyer directly, but it's my understanding that they attempt to recover legal fees from the auto manufacturer and thus it should cost you nothing. Don't go at it alone if you don't have to.
Subie is offline   Reply With Quote
First Oil Change to the shop cantaloupe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-21-2012 03:41 PM
Car Back from body shop!!!! 20valvewynn83 Cosmetic Modification (Interior/Exterior/Lighting) 24 09-28-2012 08:51 PM
WGP is your shop for the BRZ/FRS Doug@WGP Engine, Exhaust, Bolt-Ons 0 08-24-2012 12:09 PM
EDI Performance Shop Car Ken@EDI Other Vehicles & General Automotive Discussions 0 08-07-2012 09:27 PM
Drove the 86GT and NC miata back to back on GT5 Hanzo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 39 01-07-2012 12:56 PM
