Old 11-04-2012, 09:58 AM   #1
Foobar
SLO NO MO
Foobar's Avatar
Skene Design Front License Plate Mount
FYI,
For those that don't want to drill big holes in the bumper for the factory front mount license plate kit, and don't like the off-center look of the tow-hook solution, check out http://skenedesign.com/FPBracket/index.shtml
You still have to drill two small holes on the bottom surface of either the lip or the mustache, but they're small and out of sight.
I attached mine to the bottom of the mustache, and can either hang the plate down covering the mouth of the grill, slide it up to leave the mouth completely open, or adjust it somewhere in between for a clean look.
I'm in Vegas this week so I can't take any pictures as the car is in NY, but anyone interested, you want to get the Medium bracket size which fits perfectly. I can get pictures up next weekend for anyone that wants a visual.
Here are the pics:
Last edited by Foobar; 11-14-2012 at 02:31 PM. Reason: This thread is useless without pictures
Old 04-17-2013, 03:03 PM   #2
Turbowned
Turbowned's Avatar
That's a much smarter solution, thanks for posting!!
Old 04-17-2013, 03:26 PM   #3
MaximaZero
MaximaZero's Avatar
Is there anything on the back of the bracket to prevent it from scuffing the bumper when being pushed by the wind resistance driving or a tap by an idiot backing up?
MaximaZero is offline   Reply With Quote
Old 04-17-2013, 03:51 PM   #4
Foobar
SLO NO MO
Foobar's Avatar
No problem! I actually put this up in November but I don't think it got a lot of attention.
Yep, it comes with clear rubber feet that you stick on to the back of the brackets at the point you think it'll touch your car.
Old 04-17-2013, 07:32 PM   #5
996garage
996garage's Avatar
Drives: 03' NSX & 13' BRZ 6spd Ltd white
That Skene Design looks pretty nice. I like how it's so thin, but it's a bit pricey at $56 shipped.
It's basically mounted in the exact spot I mounted my custom one. I spent about $12 in parts to make mine.
I'm attaching a photo I have of the back of the license plate mount(which you'll never see). I used an old license plate for fitting purposes, until I get my real ones.
I bought the license plate backing from Pep Boys for $8.99, metal brackets from Home Depot for $1.29, and screws/washers for $1.75. I used very small screws and washers to join the "L" brackets to the license plate frame backing. Then I epoxy'd over the screws and brackets to make everything super secure. I layered some electrical tape onto the bent L brackets (not pictured) to help prevent against any scratching where the L bracket and the underside of the mustache meet.
996garage is offline   Reply With Quote
License Plate Mount Tilt Kit Kinzo Exterior Parts (Aero, Lighting, Etc.) 15 08-20-2013 04:05 PM
Now available!!! PTUNING Adjustable Front License Plate Holder w/ Tow Hook Mount Mrc@ptuning Exterior Parts - The Rest 24 03-14-2013 11:50 AM
Now available! PTUNING Adjustable Front License Plate Holder w/Tow Hook/ camera mount Mrc@ptuning Exterior Parts - The Rest 29 12-07-2012 02:37 PM
USA front license plate mounting? Slimline bracket mount.. Help across the world :P WTF Scion FR-S / Toyota 86 GT86 General Forum 32 08-23-2012 07:25 AM
BRZ Front License Plate Custom Mount sure74 Cosmetic Modification (Interior/Exterior/Lighting) 14 06-29-2012 10:17 PM
