Old 11-01-2012, 10:31 AM   #1
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
Spraying your Tail lights
Hey guys
Just a quick question for those who have sprayed their tail lights (red, or whatever).
What process did you undertake? What products? etc.
I know of someone who has tried to get his tails sprayed, but unfortunately they cracked due to a thinner to clean the plastic before paint.
I'm looking to get this done instead of waiting for the perfect tails to be released. I just want them to be red lol.
Thanks
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 11-01-2012, 10:36 AM   #2
i_4got
i_4got's Avatar
Drives: Whiteout FR-S
Originally Posted by RZ86 View Post
Hey guys
Thanks
If you mask off the areas carefully, you can actually spray your lights without taking them off your car. @ipothas did it in his car journal: http://www.ft86club.com/forums/showthread.php?t=19280
I understand VHT makes a good product. That's probably what I'm going to use.
Edit: oh, and I don't think it's necessary to clean the lights with any harsh chemicals. Just give it a good wash with some soap and water, maybe some Windex.
i_4got is offline   Reply With Quote
Old 11-01-2012, 11:36 AM   #3
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
Hello, there is a great Search feature on these forums and a wonderful DIY Section located here:
http://www.ft86club.com/forums/forumdisplay.php?f=43
To answer your question, ninjasaurusrex has created a wonderful DIY guide that might answer some of your questions:
http://www.ft86club.com/forums/showthread.php?t=20831
And also on the same topic, you may also be interested in blacking out the light housing written by user sw20kosh:
http://www.ft86club.com/forums/showthread.php?t=12312
Just wanted to warn you about using Windex on your paint. It will wear out your paint over time and also slowly eat away any layer of wax/sealants/clearcoat you may have on. I'm sure using it once or twice will have no effect long term. Soap and water will be perfect, but if you want to use a cleaner try to use something that is made for cars and also not ammonia based.
EDIT: Hmm.. looks like my information on Windex is old and they are no longer Ammonia based. You should still avoid using it on your paint.
Here is their FAQ: http://www.windex.com/en-US/Pages/Faq.aspx
Can I use Windex® on my vehicle windows?
Yes, but it is best to clean automobile windows with Windex® cleaners when the surface is cool and out of direct sunlight whenever possible. You can use it on glass, chrome, stainless steel, plastic, and vinyl surfaces. You should avoid painted surfaces. On tinted windows, test in an inconspicuous spot first, since there are different qualities of tint.
Books is offline   Reply With Quote
Old 11-01-2012, 11:39 AM   #4
i_4got
i_4got's Avatar
I meant only use Windex on the headlights and taillights, not the body of the car itself lol. Unless Windex is too harsh for the lights as well?
Old 11-01-2012, 11:43 AM   #5
Books
Books's Avatar
I think you're correct, I don't think it'll damage the tail lights. But definitely don't let it touch your paint!
Old 11-01-2012, 11:53 AM   #6
diirk
diirk's Avatar
Drives: 4Runner
Hey guys
Thanks
VHT makes a Red Nite Shades paint also. Might work well depending on what you're trying to do.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 11-01-2012, 09:49 PM   #7
RZ86
RZ86's Avatar
Yeah I'm aware of the VHT product, but I'm not really after the matte finish. Maybe using a clear after using VHT could give me the gloss I'm after.
At the moment my tails are wrapped in red vinyl, but this has caused them to crack down the bottom of the light. I'll need new tails at some point lol.
I am aware of the search button, but I've seen quite a few 86/FRS/BRZs with glossy red tails, and no info how to get it (or nothing that I've found).
Old 11-01-2012, 11:17 PM   #8
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
I've prepared and painted mine red with the intentions of going for an oem glossy redout look. I used red vht and tried using a can of clear coat. It initially looked great but the hot summer caused the clear coat to fade. After the coat faded the surface started to get rough with sediment embedded making it feel like sandpaper and matted.
I finally had enough of it and wetsanded and clay barred it to remove all the rough specks. I took it to a friend who gave it a coat of automotive clear coat. You can see the difference in the attached photos.
In summary you can paint it yourself but don't skimp on the clear coat and get it professionally done. Or save yourself some time and have them coat it with a blend of candy red clear coat. It should be less than about a hundred bucks if you ask around or free if you have an awesome friend. :happy0180:
Enigmus is offline   Reply With Quote
Old 11-01-2012, 11:27 PM   #9
i_4got
i_4got's Avatar
What the... did they bubble up like that while they were drying? Does anyone know why? Is it because of the heat or something?
Old 11-01-2012, 11:29 PM   #10
Enigmus
Enigmus's Avatar
those were before they were polished and waxed thoroughly. i'll wait til the next car wash before i take some better pics
Old 11-02-2012, 06:22 PM   #11
DC-FRS
Mixed black and clear and sprayed mine. It turned out amazing. I can post pics later if anybody wants to see.
DC-FRS is offline   Reply With Quote
Old 11-02-2012, 06:29 PM   #12
i_4got
i_4got's Avatar
Yes please. Did you spray a few coats of black and then glossed it with clear?
Old 11-03-2012, 11:44 AM   #13
DC-FRS
You actually take black paint, mix it with clear so it lightens it, then just do a coat, if its not as dark as you want, spray another coat, and so on. I'll put up pics later today, it got too dark last night.
TYC tail lights doggy Cosmetic Modification (Interior/Exterior/Lighting) 90 02-13-2014 02:03 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
after market tail lights xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 01-14-2013 11:00 AM
opening tail lights? JollyJON Cosmetic Modification (Interior/Exterior/Lighting) 34 07-23-2012 04:35 PM
