View Poll Results: More bang for the buck, Supercharger or Turbo?
Supercharger 17 27.87%
Turbo 44 72.13%
Voters: 61. You may not vote on this poll
Old 11-01-2012, 10:09 AM   #1
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Call me a NOOB, Differences between Supercharger & Turbo?
Like I said, this is my first new car and it's the car that has gotten me into cars in the first place. Everything is new to me. Can someone please explain in English for a simple minded noob like me to understand?
Differences between Superchargers and Turbos?
Pros and Cons to each?
Which is a better bang for the buck?
VADER is offline   Reply With Quote
Old 11-01-2012, 10:43 AM   #2
Pete
Pete's Avatar
Drives: 22 BRZ
I am a noob myself, but I am leaning towards supercharging right now because it is easier to drive and gets boost as soon as you press the pedal. Supercharging will not get you big horsepower numbers though as most of the improvements come in the low and mid RPM range.
Turbos will get you a lot more horsepower at higher RPMs but will generally be more difficult and unpredictable to drive due to the boost kicking in once the exhaust gasses spool up the turbo.
That is my understanding at least, but I am far from being an authority on the subject. If you dig around a bit there is plenty of talk on this topic.
http://www.superchargersonline.com/i...age=page&id=35
Pete is offline   Reply With Quote
Old 11-01-2012, 10:45 AM   #3
2forme
Turbos aren't necessarily unpredictable and very easy to drive if you size the turbo correctly to the application.
Old 11-01-2012, 10:48 AM   #4
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
this. just look through the threads and you'll find the info you need.
FreshFRS is offline   Reply With Quote
Old 11-01-2012, 11:04 AM   #5
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
What is better for an automatic..?
Old 11-01-2012, 11:05 AM   #6
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
Supercharger:
Pro's:
great transient response
huge midrange power gains (centrifugal is more like a turbo)
Extremely linear power delivery
simple to setup and run.
Cons:
generally lower thermal efficiency (eaton TVS makes this negligible)
consuming power vs using exhaust energy
relatively heavy but in a smaller space
Turbo:
Pros:
low end torque (if sized properly)
high rpm power
little energy lost turning the turbo
Cons:
lack of transient response(lag)
mid range power is relatively less compared to SC
more complicated setup.
to sum up:
SC good for up to 350whp whilst being efficient (rough calc)
turbo better for higher horsepower and those who gotta have the most power (dyno queens).
best bang for the buck depends on what you want. SC is easier to setup even with an intercooler in the manifold it is 2 water line to a front mounted heat exchanger and a pump. then just tune and drive.
Old 11-01-2012, 11:08 AM   #7
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
Originally Posted by FreshFRS View Post
Supercharger:
Pro's:
Cons:
Turbo:
Pros:
high rpm power
Cons:
to sum up:
Hmm, so from what it sounds like the SC might be the way to go for someone like me. Simple, easy to setup, and probably won't cost as much..
Old 11-01-2012, 11:12 AM   #8
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
seems to be that way. but due to how the aftermarket is raping us its hard to say whats going to be cheaper.
Old 11-01-2012, 11:13 AM   #9
Tylub
Tylub's Avatar
Drives: Raven Black FR-S
FI is always a hard decision to choose, take your time and research a bit haha
instagram @Tylub
Mods: Tomei UELs, Tomei OP, Perrin Catted FP, ARK DT-S, Perrin LW Crank Pulley, Enkei RPF1, RSR Sporti, Supertek Intake Tube, Perrin CAI, Stoptech SS lines/brakes/slotted rotors, Cusco MCB brace/Strut Bar
Tylub is offline   Reply With Quote
Old 11-01-2012, 11:16 AM   #10
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Ok, I'll bite. You're a n00b.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 11-01-2012, 11:22 AM   #11
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
This will be my first car that I plan on modifying, and I'm leaning towards the supercharger. My main reasons are, I'm not looking for over 300WHP, I'll be doing the install myself so ease of set up is a big plus, and a supercharger offers that.
There are people that swear by turbos and that's fine. I'm sure either option you choose will put a smile on your face when you put the pedal down
Freeman is offline   Reply With Quote
Old 11-01-2012, 11:27 AM   #12
J2 Motorsports
J2 Motorsports's Avatar
Drives: 2006 Acura TL
In a supercharger, there is a belt that connects directly to the engine. It gets its power the same way that the water pump or alternator does. A turbocharger, on the other hand, gets its power from the exhaust stream.
If you were to balance both forced induction system, it goes into efficiency and cost. While on a turbo setup you can spike your boost on a controller, it will give you more PSI. however power does become addictive and if you go too much you can detonate. On a Supercharger the PSI comes from the diameter of the pulley.
J2 Motorsports is offline   Reply With Quote
Old 11-01-2012, 11:43 AM   #13
VADER
Regional Moderator
VADER's Avatar
Drives: VADER 86
I just want a little more HP then I already have. This will not be a racing machine haha. It's an automatic and I just want to see what would be better to give it that extra UMPH!
Old 11-01-2012, 11:44 AM   #14
J2 Motorsports
The car is fast already, so if you want to be safe and not sorry I would go SC. However all fan boys of boost love the WSSSSHHHHH sound after the turbo spool.
Speed and power is addicting.
Supercharger or Turbo ? #87 Forced Induction 192 01-25-2013 10:20 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
Noob to this. Style Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-09-2012 08:10 PM
Induction Poll - NA, Supercharger, or Turbo cloud9 Engine, Exhaust, Transmission 45 02-21-2012 12:41 PM
