Old 10-25-2012, 01:59 PM   #1
clevrname
Drives: 2013 Firestorm FR-S 6MT
Break-In Period Info
I see a lot of people talking about properly breaking in their car and how they read to drive it. Figured this would be a good read for everyone, really explains how everything works and you can still have fun within those first 1000 miles
Hope everyone enjoys!
Break-In Period
The break in process for an engine or other mechanical part is not well understood by many performance enthusiasts. Some feel it is unnecessary with modern machining and production methods. Others advocate a severe break in process to get the maximum performance out of the engine. What is not well understood is that the break in process applies to all mechanical systems in the car.
The two schools of thought are usually summarized with over simplified axioms, like "the engineers who built it know best do it exactly like the owners manual says!" or "drive it like you stole it!".
It is important to realize that the original manufactures has a different motive and intent behind his break in recommendations than the auto enthusiast. The manufacturer is giving a series of recommendations aimed at the lowest common denominator customer with very conservative guidelines that make it nearly impossible for the new owner to damage the car. The Manufacturer is also attempting to minimize warranty issues and maximize reliability during that warranty period with little regard to absolute maximum performance.
The auto enthusiast is interested in an entirely different result and has a different intent in his break in strategy. In this case the objective is usually maximum over all lifetime for the engine (200k Miles), maximum efficiency and gas mileage, or maximum power output in exchange for a reasonable reduction in the engines ultimate life time. As in all similar situations there is no free lunch and you must trade one attribute for another when you choose your break in process.
The manufactures break in procedures usually will give very long engine life, near zero chance of injuring the engine mechanically, acceptable (rated) performance, acceptable oil consumption, and acceptable gasoline milage.
The high performance break in puts highest priority on maximum achievable power production with out physical damage to the engine. Very low oil consumption, and high compression due to good ring sealing, in exchange for some small but real risk of engine damage during break in, and the possibility of a slight reduction in the long term operational life time of the engine.
If you follow the factory recommendations "exactly" you will have an average car that does not need any warrantee claims during the factory warrantee period. The factory breakin recommendations are to protect "THEM" not you. They want to have the lowest possible claim rate under warrantee. They make those recommendations with the fact in mind that a small percentage of the automotive customer base are certifiable idiots and could break an iron ball with a rubber hammer.
Repeated tests and standard practice by high performance users (ie race teams, and even factory recommendations for certain cars) are for the intellegent use of high load during break in. You want to adhere to the max rpm limit with rare exceptions during the first couple hundred miles, and absolutely do not exceed it for extended periods of time during the first few miles. The morons that take a new car out and try to see how fast it will go and do a 140 mph pull in 5th gear for several minutes will kill any engine. Taking a quick blast up to red line to merge onto a highway after the car is warmed up will not harm any engine that does not have a manufacturers defect.
To get best possible ring seal you need to put the engine under high load (high cylinder pressures) for a brief period of time then let the engine breath a bit and cool down any hot spots.
Probably 90% of your engine and transmission break in occurs in the first 1- 2 hours of driving, but the Subaru engine will continue to loosen up and gain power for almost 10,000 miles.
Break in is controlled wear, you MUST create high loads to get the best possible ring seat, you can get probalby 90% of best possible by following factory recommendations. You can ruin an engine (make it an oil burner for life) by being overly gentle with it during the first couple thousand miles.
As the saying goes moderation in all things. The factory knows full well that almost no driver can avoid taking the car up near red line a few times during the first hours of the engines life! There recommendations are to keep the idiots from taking it to red line and holding it there for seconds or minutes at a stretch. That will also kill a new engine.
Seating the piston rings is an important part of the break in process. No matter how hard the manufacture tries the engines cylinders are never perfectly round when a new engine is assembled, and the piston rings likewise have microscopic high spots. Breakin is a process of controlled wear.
What is happening in side the engine on a microscopic level, is the surface of the cylinder wall looks like sandpaper. Lots of sharp peaks and deep grooves. The Grooves are put there intentionally during manufacture to hold oil during the early stage of break in. In the final hone process as they finish the cylinder wall surface, they try to produces what is called a "plateau finish".
That means they first, using a coarse stone, create a rough surface (microscopically) with deep scratches and sharp points. Then they make a specific number of passes with much finer stones to "knock off" the sharp points but still leave some of the deep "cross hatch" grooves.
The end result if done properly, is a moderately smooth surface with lots of flat topped peaks ( the plateau) interspersed with deep scratches that can hold an oil film. (the surface would feel quite smooth to the touch, but on a scale of millionths of an inch is quite rough)
Likewise the Piston rings have a microscopically rough finish as well.
In the first couple hours of engine time is the ideal time to push the rings hard against the plateau finish in the cylinder wall, so that they both "wear in to each other"properly.
It is essentially a period of controlled wear which allows the piston rings to "grind themselves down to a perfect match" for the cylinder wall. This process rapidly wears down a few millionths of an inch of the cylinder wall surface and quickly takes the "bite" out of the cylinder wall surface. If you look at an engine cylinder wall after it has run a while, you will see that the rings have polished (worn) the cylinder wall to a near mirror finish.
If this happens before the rings have ground themselves into proper shape for a perfect seal, it will never happen as the cylinder wall becomes too slick to change the shape of the piston rings much, and the deep scratchs which hold oil during this wearing in process and protect the engine from over heating small areas of the piston rings and cylinder wall disappear.
As you can see, the process is in fact a pretty brutal process on a microscopic level and that is why the periods of high loading should only be maintained for a couple seconds at a time. (about the time it takes you to blast up an on ramp)
After that few seconds of high load, the deep scratches in the cylinder wall fill up with microscopic dust from the wearing in process and hot spots form because they can no longer hold adequate oil film. After a few miles of driving, the oil will wash all this crap out of the cross hatch and then it can do its job again at the next high load blast up an on ramp.
If you do it too hard too fast, you will pack crap in the deep scratches so hard they cannot self clean. This is commonly called "glazing" the cylinder walls. You have ruined their surface for proper break in at this point. Long duration high loads early in the engines life, will also create small areas of the cylinder wall that get heated to very high temps and then rapidly cooled by the cooling system. This forms a hard spot in the wall that will never wear at the same rate as the rest of the cylinder. If that happens you have a high spot that will last the life of the engine. High loads that last too long can also over heat the rings and make them lose their spring tension which provides the initial seal to the cylinder wall. That and the high spot issue I mentioned above, along with a couple other things can make the engine burn oil for its entire operational life time.
If you only drive the car easily at low engine rpm you defeat the entire process of engine breakin. When an engine is manufactured and assembled they carefully create a surface on the cylinder wall that is smooth but not too smooth. It has a crosshatch pattern of deeper scratches in its surface which are intended to hold an oil film. Likewise the piston rings are smooth to the eye but are also rough at a microscopic level.
When the engine runs the piston rings are forced against the cylinder wall by the pressures in the the cylinder as high combustion pressure push outward on the rear of the ring. The spring pressure of the piston ring is not adequate to create a tight seal and this "pressure capture" is essential to achiving a good ring seal.
If you only lightly load the engine as you break it in, you never force the piston ring hard against the freshly prepared crosshatch pattern in the cylinder and as a result the piston ring simply slides over the top of the high spots on the cylinder wall and piston ring, and the two surfaces polish each other smooth with no significant wear taking place. This eventually destroys the cross hatch pattern so the cylinder loses its ability to hold an oil film on the surface.
If this is the case (lightly loaded engine during break in) you will never get a good ring seal with the piston wall because you have prevented the breakin wear required to lap the two surfaces into a close full surface contact.
The proper way to break in an engine is to apply brief periods of high load to force the rings hard against the fresh cylinder surface while it still has the cross hatch pattern. This high pressure creates high wear on the high spots that are holding the surface of the ring and piston wall apart and they quickly "wear in" (break in) as these microscopic high spots get polished out. The presence of the cross hatch pattern holds a thin layer or oil on the cylinder surface which keeps this planned wear from going too far and prevents excessive metal to metal contact as long as the high load only lasts a short period of time.
Then you drive the car easily for a short period to allow the areas that just got polished down to cool off, and to re-establish the thin oil film in the cross hatch.
If done properly you will wear the high spots off both the cylinder wall and the piston ring, and end up with a smooth gap free sealing surface which applys pressure to the entire surface of the piston ring. This gives you a good pressure seal and a smooth sliding fit that needs very little oil to run with low friction and wear.
You need to apply load to the engine in the first few hours of its life to allow this to happen. If you drive the car too easy or too hard you will either create a seal that has gaps that never wore down before the cross hatch was worn off (very light break in), or you will over heat the piston ring and cylinder wall and damage them due to over load (very hard break in such as continuous high rpm operation before break in is complete).
This wearing in process as the rings conform to the exact shape of the cylinder and the cylinders wearing in to a true round surface is the process of "seating the rings".
Engine braking during the break in creates high vacuum in the cylinder that helps draw up oil and hold it on the cylinder wall. If done in moderation it is good to do.
The reason to vary engine rpm is that the components in the engine are not completely rigid and do stretch under load, so the shape of the cylinder wall changes with engine load as does the length of the total stroke as the rods stretch at high rpm and all the bearing clearences are squeezed down at high rpm.
If you do not vary engine rpm the piston rings will never reach the very top of their travel in a gradual manner and create a smooth surface at the very maximum reach of their travel. It is not as big of a deal as it was years ago but the effect is real and does make a difference in engine performance.
This is a balancing act between sufficient engine load to fully seat the rings and achieve maximum compression, and minimum oil consumption due to excellent ring seal.
As shown below aircraft engine designers recommend a variation of a high load break in as they try to achieve maximum reliability and maximum take off power in their engines.
From Lycoming Aircraft recommendations for engine break in
"A new, remanufactured, or overhauled engine should receive the same start, warm-up, and preflight checks as any other engine. There are some aircraft owners and pilots who would prefer to use low power settings for cruise during the break-in period. This is not recommended. A good break-in requires that the piston rings expand sufficiently to seat with the cylinder walls during the engine break-in period. This seating of the ring with the cylinder wall will only occur when pressures inside the cylinder are great enough to cause expansion of the piston rings. Pressures in the cylinder only become great enough for a good break-in when power settings above 65% are used.
Full power for takeoff and climb during the break-in period is not harmful; it is beneficial, although engine temperatures should be monitored closely to insure that overheating does not occur. Cruise power settings above 65%, and preferably in the 70% to 75% of rated power range should be used to achieve a good engine break-in."
http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/maintenancePublications/serviceBulletins.html
http://www.cessna.org/benefits/articles/breakin.html
http://www.aera.org/consumer/engbrkin.pdf
http://www.tcmlink.com/fiddefault.aspx?cgroup=MATTITUCK&cpagename=BREAKIN
If your interested in paying for it you can always get this SAE paper:
"Effect of Break-In and Operating Conditions on Piston Ring and Cylinder Bore Wear in Spark-Ignition Engines"
It is important to understand that you are breaking in more than just the engine. You are also breaking in the gears, seating and seasoning the clutch if it is new, heat cycling the brakes if they are new. Every bearing surface in the car, and even components like suspension bushings take a set and settle into their long term running position in the first few hours/days/weeks of use. Some changes also occur due to heat cycles. Tires firm up and stabilize as they go through their first few heat cycles, and become much more resistant to abuse if properly treated during those first few heat cycles.
Carrol Smith in his Tune to win book comments on how many racers kill their rear ends before they even race them by not breaking in the gears. The problem is the gear failure will not occur until many miles after the fact.
I suspect this is one of the elements in the transmission failures some folks are having. They cause micro fractures on the gears during the early break in period by beating on the car before it is well broken in, and then Poof the gears shatter while they are going to the grocery store with the 2 year old in the back seat.
For the gears you also need to give them brief periods of high load, followed by several minutes of low load operation so the gears can cool down, to a uniform temp. If you don't the tight points on the gear teeth will be over heated which destroys the strength properties designed into them and leaving you open to later random failure.
Source:
http://wiki.nasioc.com/wiki/Break-in_engine
2013 Firestorm 6MT
2005 Corolla XRS
clevrname is offline   Reply With Quote
The Following 12 Users Say Thank You to clevrname For This Useful Post:
Bristecom (09-06-2016), chulooz (10-26-2012), cuddefred (10-25-2012), developer (10-25-2012), einzlr (10-25-2012), flippy (04-13-2022), ftc~brz (10-26-2012), Metabrz (10-26-2012), rapidcars (10-25-2012), sierra (10-26-2012), soros151 (10-25-2012), Surok (10-26-2012)
Old 10-25-2012, 07:10 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
Nice write up. I like that you include the hows and whys. Also perfect timing for me as i pick up my 86 tomorrow
1974 TA22 Celica
2013 86 GT
Old 10-25-2012, 08:34 PM   #3
2forme
I thought I would note. I followed the manufacturer suggested break in and have one of (if not the) highest dynoing NA 86's... not to discredit your post, but I guess I'm an exception. Also interesting is that I haven't had any issues with the car at all. Not even an idle dip. Good write up though.
Old 10-25-2012, 09:36 PM   #4
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
This needs to be stuck....
CircuitJerk is offline   Reply With Quote
Old 10-26-2012, 12:04 AM   #5
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
I drive normal for break in for the most part. I have no problem taking it up to red line. But within reason. I don't nail on it hard all the time. Just some short controlled bursts, mostly under lighter loads.
Nice write-up. I thought i was the only one "dumb" enough to drive a little frisky during that first 1000 miles. One guy locally just ran his car through 4th gear several times to seat the rings. Whatever works I guess.
Coheed is offline   Reply With Quote
Old 10-26-2012, 12:14 AM   #6
whaap
whaap's Avatar
I guess I'm supposed to give credibility to some unknown person who writes an intelligent looking theory on a Subaru forum and give no credibility to the people (assuming they're engineers) who write the owners manual on break-in procedures for my car.
I followed the owners manual. I'm at roughly 2,500 miles now and I'm having no mechanical issues at all.
whaap is offline   Reply With Quote
Old 10-26-2012, 12:35 AM   #7
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
You know engineers are busy building, so it must be someone else doing the writing (with corporate influence). The manual is not god.
Nice work!
chulooz is offline   Reply With Quote
Old 10-26-2012, 12:52 AM   #8
whaap
whaap's Avatar
Nice work!
It's true, the manual is not god but it's written by someone who knows a hell of a lot more about the car than I do. I'll take their word over some unknown person posting on a car forum.
Old 10-26-2012, 01:14 AM   #9
cuddefred
Drives: Black 86 GT
But the manufacturer also wants to save money so they urge on the side of ultra caution - just like they do with the ECU etc., so they have a vested interest in making it so no-one pushes their cars to the limits. Modern engines do not need running in like they used to.
cuddefred is offline   Reply With Quote
Old 10-26-2012, 01:47 AM   #10
jpit
Drives: Subaru BRZ
This debate has been going on for decades and will continue for decades. There will never be an answer because it would take a controlled study and that is never going to happen.
jpit is offline   Reply With Quote
Old 10-26-2012, 02:10 AM   #11
cuddefred
Drives: Black 86 GT
Good point - and in an industry worth hundreds of billions of dollars you would have thought that the manufacturers would have done this. The fact that different manufacturers say different things suggests that they are all erring on the side of caution. I would never advocate flogging a car to death in the first 1000 miles or so, but it won't hurt it to occasionally hit the max revs.
It is the same with servicing - in different countries there are different service schedules for the same engine - go figure!!!
Old 10-26-2012, 02:16 AM   #12
Akired86
Akired86's Avatar
Drives: 2013 Scion FR-S Asphalt
Come on people, lets be real here. This is 2013 FR-S, BRZ, break in period? That for old technology engine, this is 2013 modern engine has already been broken in before they even get to the dealership. Personally change my oil at 1000 miles to see if in fact there any metal piece in the oil or sit at the bottom of the oil pan, I come to find nothing, nothing in the oil or the oil filter.
Akired86 is offline   Reply With Quote
Old 10-26-2012, 03:04 AM   #13
Le86
Drives: Asphalt FR-S
Nice write up but where are you getting this information from? Your sources aren't very credible. One link doesn't work, another site has been moved and the PDF is recommendation for re manufactured, not new engines. Tolerance and clearances will be different between the 2.
Not trying to discredit your post but but I haven't seen any solid evidence of any of your claims. Again, I say this with all due respect, not trying to attack your post.
PS- "Wikis" are not credible sources, unfortunately.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
Le86 is offline   Reply With Quote
Old 10-26-2012, 03:54 AM   #14
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
dont Subaru hit redline at the factory :/
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
rev the engine to 5000 rpm before break in period midnitz Scion FR-S / Toyota 86 GT86 General Forum 48 11-03-2013 10:24 AM
Within break-in period, but long road trip? Rossman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-20-2012 02:09 PM
Break-in Period and Octane level MattM232 Scion FR-S / Toyota 86 GT86 General Forum 10 06-05-2012 11:00 PM
Engine break in period - how necessary is this? WhippleDip Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 05-16-2012 03:38 PM
Break-In Period UriarteMD Scion FR-S / Toyota 86 GT86 General Forum 10 03-29-2012 03:26 AM
