Old 10-21-2012, 01:21 PM   #1
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Tein H-Tech/AP Lower Control Arm Quicklook
Just wrapped up an install of Tein H-Tech springs and AP Lower Control Arms on @cobrabyte's BRZ. I asked him to come in here and post his review, so look forward to that. @post_break was also there to help being the "jackman". Overall the install went smooth. Took about 6 hours to get her all done. He took me for a ride after it was done. It was a compliant ride, not bouncy. My car with RCE Yellows is definitely stiffer. I look forward to seeing the car after the springs settle.
I was also evaluating the Panasonic Leica DG Summilux 25 1.4. Let's get to it.
The Agency Power Lower Control Arms. They also supply the hardware to attach the suspension bits to the arm. However you do need hex key sockets to install them.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-03 by VictorN07, on Flickr
I will say that they are beefy. Carved out of solid aluminium, they seem to be built to last. We didn't get weights, however compared to my Cusco arms, they are very heavy.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-04 by VictorN07, on Flickr
Due to a debacle with a storefront, these arms would have come laser engraved.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-02 by VictorN07, on Flickr
Pillowball is good. However they don't wrap it in rubber like the Cusco. I do like how the turnbuckle to adjust camber isn't tucked in the subframe like my Cusco arms. Remember to adjust the arm so the overall length is the same as the OEM arm as a starting point. Then adjust camber as desired.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-05 by VictorN07, on Flickr
His car is definitely drive-able
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-01 by VictorN07, on Flickr
I'm just imagining that Vorshlag Camber plate here
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-10 by VictorN07, on Flickr
What's missing?
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-11 by VictorN07, on Flickr
Tein H-Tech on the front OEM damper. 2.9K rate. They do not supply bump stops or dust covers. The instructions are also all in Japanese and a call to their USA office yields no English instructions. I'm glad I got the @Racecomp Engineering Yellow and Cusco arm install under my belt.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-06 by VictorN07, on Flickr
Tein H-Tech on the rear OEM damper. 4.8K rate. Again had to reuse the bump stop and dust cover. I still hate how the hat doesn't rotate; you have to get the alignment right or the strut won't bolt up to the arm.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-07 by VictorN07, on Flickr
@cobrabyte's BRZ finished.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-09 by VictorN07, on Flickr
Looks good. He is running 17x8 Enkei RPF01 plastidipped. Don't know the offset. Non OEM Camber bolts were used up front. He'll have to tell me what they were.
20121019-LeicaEval-Chris-Tein_HTech-AP_Arms-08 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
The Following User Says Thank You to F1point4 For This Useful Post:
cobrabyte (10-21-2012)
Old 10-21-2012, 01:24 PM   #2
F1point4
Photo Specialist
F1point4's Avatar
While the spring install was going down, @post_break was installing his newly used Perrin Lightweight pulley with @cobrabyte. The Leica is doing well
20121019-LeicaEval-Ryan-Perrin_Pulley-01 by VictorN07, on Flickr
[img]http://farm9.staticflickr.com/8475/8110534463_d29f9c5***_c.jpg[/img]
20121019-LeicaEval-Ryan-Perrin_Pulley-02 by VictorN07, on Flickr
20121019-LeicaEval-Ryan-Perrin_Pulley-03 by VictorN07, on Flickr
Not done with the Leica, but fun
20121019-LeicaEval-Ryan-Perrin_Pulley-04 by VictorN07, on Flickr
Old 10-21-2012, 01:31 PM   #3
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Thanks again for your help with this install. Loving the stiffer suspension. Definitely as low as I'd go on just springs.
Now... for them coilovers...
cobrabyte is offline   Reply With Quote
agency power, brz, h-tech, springs, tein
TEIN S-TECH AND H-TECH FOR 2013 FRS & BRZ IN STOCK!! genometuning Brakes, Suspension, Chassis 7 10-13-2013 09:49 PM
Racecomp Engineering Yellow Springs and Cusco Lower Control Arm Review F1point4 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 07-28-2013 12:22 AM
Rear lower control arm part # BRZranger Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-15-2013 12:33 AM
