Old 10-18-2012, 07:47 PM   #1
BerkTechnology
Drives: Scion FRS
Dyno'ed an FRS with 104 octane in the tank!
Was doing some testing a few weeks back on a Dynojet. Tank was damn near empty by the time we were all done so we dumped a gallon of Sunoco GT Plus into the tank (rated @ 104 octane RM2).
Guess how much power we made?
ZERO!!!
Maybe a tuner can chime in but it seems like this ECU uses a torque limiter and is locked down pretty good from the factory. Not easy to make power on this car without a reflash. Any truth to my suspicions?
PS - I'm in Cali and all we get is 91 oct (RM2).
BerkTechnology is offline   Reply With Quote
Old 10-18-2012, 07:58 PM   #2
CBR600RR
Drives: Raven Black
I would say: yes, that is true
Old 10-18-2012, 07:59 PM   #3
MKIV
MKIV's Avatar
Drives: 4 tires mounted to 4 wheels
Octane don't make power. It makes the flash point higher. The only reason why you loose power with lower octane is that the ECU pulls timing due to knock. If you get no knock with a given fuel, increasing octane from there will not yield you more power.
MKIV is offline   Reply With Quote
The Following 5 Users Say Thank You to MKIV For This Useful Post:
b.e (10-18-2012), Chewie4299 (10-20-2012), czar07 (10-21-2012), dabocx (10-18-2012), Guff (10-19-2012)
Old 10-18-2012, 08:08 PM   #4
xjohnx
Grip>Slip
xjohnx's Avatar
ZERO!!!
why does this surprise you??
The Following 2 Users Say Thank You to xjohnx For This Useful Post:
Chewie4299 (10-20-2012), Guff (10-19-2012)
Old 10-18-2012, 08:25 PM   #5
dsmx17
4g63>rotards
Drives: 98'GSX 11'Tundra 10'Wrangler
If anything, i'd expect it to lose power without adding timing while running 104 octane.
dsmx17 is offline   Reply With Quote
Old 10-18-2012, 08:27 PM   #6
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
I know with my mustang running 93 produces more horsepower thanks to CVVT. Dynos proved it. Too bad the 86 doesn't produce more power with a higher octane.
post_break is offline   Reply With Quote
Old 10-18-2012, 08:36 PM   #7
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Did you, out of curiosity, pull the battery ground? Only asking because I did this on the dyno and made 11whp more though I was low on the pulls done before this.
TomR
ABQautoxer is offline   Reply With Quote
Old 10-18-2012, 08:56 PM   #8
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Yea im starting to think our ecu's are very sensitive and whenever something is done to the car that effects timing, air fuel etc the ecu has to be reset...
brichard0625 is offline   Reply With Quote
Old 10-18-2012, 09:20 PM   #9
einzlr
Drives: several
einzlr is offline   Reply With Quote
Old 10-18-2012, 09:26 PM   #10
2forme
I've talked to John about this. He mentioned that race gas didn't do squat as well.
It's surprising given the gains on E85.
Old 10-18-2012, 09:31 PM   #11
Buhryant
Buhryant's Avatar
Drives: Whiteout Scion FR-S
What the fuck. That is mind blowing
peace ez breezy
Buhryant is offline   Reply With Quote
Old 10-18-2012, 09:53 PM   #12
brichard0625
yea didnt do anything :/....maybe a 3hp-4hp gain..even if it made 11whp its about $50+ for 5 gallons e-85 is the best alternative right now i think.
The Following User Says Thank You to brichard0625 For This Useful Post:
2forme (10-18-2012)
Old 10-18-2012, 10:06 PM   #13
TheRipler
Reap the BReeZe
Drives: 04 LandShark STi
You won't make gains with E85 and no tune. Straight 104 is just too much of a jump. If there was enough timing advance available to run 104, there would be motors dropping left and right on pump gas.
You could mix that 1gal of 104 with 5-6gal of 91, and see a bump on the OEM tune. I've seen it on other Subarus, BMWs, Porches, etc running 93, so I'm sure it would help with California gas.
TheRipler is offline   Reply With Quote
Old 10-18-2012, 10:08 PM   #14
2forme
I understand this, but he was tuning 104....
Gas mileage for first tank terrypm Scion FR-S / Toyota 86 GT86 General Forum 28 01-23-2017 02:10 AM
incase the dealer doesn't put 93 in the tank... pr086 Scion FR-S / Toyota 86 GT86 General Forum 18 10-10-2012 03:02 PM
How many miles per tank on E85 Innova Engine, Exhaust, Transmission 2 09-21-2012 10:02 PM
Pushing a tank of gas to the limit. RoryTate CANADA 36 09-09-2012 10:22 PM
Strange sound coming from gas tank? nocurfew Engine, Exhaust, Transmission 6 07-31-2012 02:37 PM
