| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
Subaru Oil All Synthetic?
I just purchased a case of Subaru oil for my car's first oil change... Which will be done by me.
When I got home I realized they gave me the 0W-20 Synthetic oil... I called them back and asked if they gave me the wrong box, assuming I only need the normal conventional oil because the engine is still fairly new. They replied that that is the right oil to be used for the BRZ. Anyways, my question is...Are ALL Subaru engine oil by-default Synthetic? Thanks in advance!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#2 |
Drives: Asphalt FR-S
Not all but the vast majority of "Subaru oils" are synthetics. Your car comes from the factory with synthetic, not conventional.
10/01/2012 FR-S down for P0019 code. Received vehicle back from dealership with a new ECU 10/30/2012
#3 |
Drives: 92 NSX, 08 Accord
Why wouldn't you want synthetic for the first change? Are you doing a change with very minimal miles - like less than 1,000 - and are concerned about the so-called break-in oil? If so, I'd wait - or just change the filter if you want to be extra fussy.
1992 NSX Red/Blk 5 spd #0330
2005 Lotus Elise - (sold but reincarnated by BRZ) 2008 Honda Accord Cpe, Blk/Blk,V6,6 spd, Nav (sold) 2013 Subaru BRZ, Limited, 6 spd Auto, WR Blue |
#4 | |
Drives: '13 GBS Subaru BRZ
Using a synthetic is pretty much always better. It has a more constant molecular structure so it maintains its designed properties better and experiences less breakdown over time.
#5 |
Drives: BRZ and NA
Technically speaking nearly all oils marketed as "synthetic" are actually highly refined dinosaur oil. The only oils that I can think of that are truly synthetic are AmsOil and Redline.
The reason for this is that there was a court case where Mobil sued another manufacturer claiming that the other company's "synthetic"-marketed oil was highly refined dinosaur oil whereas MobilOne (at the time) was true synthetic, and much more expensive. The court ruled that the term 'synthetic' was a marketing term and could be used by highly-refined dinosaur oils. Dont sweat it. |
#6 |
Drives: 2013 BRZ SWP 6AT Ltd
Yep, every 2013+ Subaru runs synthetic at this point.
Impreza, Sport, XV, BRZ, Forester and Outback - 0W-20 Synthetic WRX/STi - 5W-30 Synthetic Tribeca - 5W-30 Conventional but Subaru reccomends Synthetic |
#7 |
FT86Club Vancouver
Perfect! Thank you everyone! <3:happy0180:
#8 | |
Drives: 2004 Subaru Forester 2.5XT
![]() When speaking of Amsoil, note that their OE and XL lines are made from Group III base stocks. Of course, what matters most is the complete package (base stocks and additives) and the oil's end performance. DaJoian - Can you check if the oil is API SM or SN? Just curious. -Dennis |
#9 | |
FT86Club Vancouver
#10 | |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
#11 | |
Drives: BRZ and NA
![]() http://www.bobistheoilguy.com/forums...=950368&page=1 But the results were the same. Group III oils can be called synthetic and a lot of companies started using Group III instead of PAOs in their synthetic oils. |
#12 |
#13 |
Cone basher
#14 |
Drives: SWP BRZ LTD
All 0-20 weight oil is synthetic.
| 0W-20 full synthetic oil for $3.49 a quart | terrypm | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 26 | 04-08-2014 04:51 PM |
| Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 5 | 12-29-2012 04:25 PM |
| %100 Full Sythentic VS Fully Synthetic | ProjectD | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 4 | 10-05-2012 01:28 PM |
| Subaru BRZ - RAW Subaru | Official Subaru Australia Ad | Hachiroku | BRZ Photos, Videos, Wallpapers, Gallery Forum | 15 | 07-20-2012 08:20 AM |
| Royal Purple Synthetic Motor Oil 0w20 for the FR-S/BRZ at Redline360 | Redline360 | Engine, Exhaust, Bolt-Ons | 3 | 07-08-2012 01:04 PM |
