Old 10-16-2012, 10:33 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Buddy Club Racing Spec Coilovers - SpeedFactory Style - Good Photos and Video.
Just wanted to drop these here. We sat down and took some time with the couple sets we have on hand to take some quality photos for you guys.
This Buddy Club Racing Spec coilover for the Scion FRS and Subaru BRZ is a JDM spec unit. The intended use of this coilover is for someone who does a few track days a year and some autocrossing. It will also work out well for a daily driver who wants to improve the handling of the FRS/BRZ.
Spring Rate:
Front 9K
Rear 7K
Video Review:
[ame="http://www.youtube.com/watch?v=8Nl3OTup9nM"]Buddy Club Racin Spec Coilover for the Scion FRS and Subaru BRZ - YouTube[/ame]
Photos:
Racing Spec Damper Kit is a high performance sports suspension kit designed by engineers using a vast quantity of data that Buddy Club has accumulated in the past 15 years using its high performance aluminum damper (ie. spec 30.1 Racing Damper) on various racing cars and tuned cars, focused more on the proper damper size, spring rate, dampening, stroke length for customer's use in winding roads and race tracks. The car specific pillow-ball upper mount design, proper spring rate, 15 level damper adjustment, and height adjustment capabilities accommodates driver's requests.
15 Level Adjustment
The 15 level adjustment corresponds to variety of racing stages, from Touge mountain roads to circuits. Adjustment is easy with its click adjusting dial. The dial is located on the upper shaft for regular dampers or on the lower shaft for inverted dampers. This damper is also designed for town use; hence, dampening setting ranges from hard to soft.
Single tube type shell case
Unlike visual based cartridge damper, adoption of the single tube shell case enables the use of wishbone type 46 and strut type 36. This leaves an extra space for larger pistons. Also this change allows for better heat dissipation, which prevents performance deterioration from hard runs. Special steel and anti-friction components are used to minimize friction.
Specialized Pillow-Upper Mount
Application of the upper pillow upper mount allows you to have greater handling response, by minimizing upper chassis movement. Caster adjustment allows the correction of camber for further tuning ability. Caster adjustment plates are not included on all applications.
Spring seat / lock seat
Each single full rotation equals 2mm drop. The adjusting locking seat allows for spring stress to adjust with out the necessity to change suspension position.
Original spring
Tremendous enhancement in durability resulted from a high quality surface processing. Constant testing resulted in a perfect spring rate for each application.
Racing Spec Dampers inherited the same great quality of the P-1 racing damper. Each Racing Spec Damper is made with special components and are tested and produced with out compromise. Each damper are assembled by skilled engineers to provide the best quality possible.
FT-86 SpeedFactory is offline
Old 10-17-2012, 06:36 AM   #2
_F-R-S_
Drives: 13 whiteout scion frs
whats the best autox coilover.. plus everyday driver?
_F-R-S_ is offline
Old 10-17-2012, 09:04 AM   #3
FT-86 SpeedFactory
KW V3. But the price tag is quite a bit higher as well.
Old 10-17-2012, 09:57 AM   #4
dale.m
Captain Slow
dale.m's Avatar
Drives: 2013 Firestorm FR-S
Thanks for the write up! I've been wondering about these for awhile now. MSRP?
Flying and Driving.
dale.m is offline
Old 10-17-2012, 06:34 PM   #5
FT-86 SpeedFactory
Dale, MSRP on these is $1799. Thank you for the positive post. It's good to see that people are enjoying these threads.
Old 10-17-2012, 09:19 PM   #6
ModBargains
ModBargains's Avatar
Drives: FRS, M3
I had the Buddy Clubs on my Honda Fit and it's definitely a great budget coilover system - I'm pretty sure it's going to be same case for the FRS / BRZ chassis.
-Frank
ModBargains is offline
Old 10-17-2012, 11:22 PM   #7
DOTman05
Drives: Evo 8
Price?
DOTman05 is offline
Old 10-17-2012, 11:39 PM   #8
FT-86 SpeedFactory
MSRP is up above.
Old 10-29-2012, 08:25 AM   #9
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Do I want these or KW v3s?
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline
Old 10-29-2012, 02:13 PM   #10
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
These are way stiffer than KW's, depends on how much you value ride quality. Personally i'd take the KW's.
JoeBoxer is offline
Old 10-30-2012, 07:28 AM   #11
DriftEightSix
Pegasus White
Drives: 86
I do like my ride quality and I feel in stock form I really baby it over speed bumps and stuff so I don't want it to get much worse which i think heaps stiff would do... so KWv3 it is.
Sorry for hi jacking.
Old 10-30-2012, 10:54 AM   #12
FT-86 SpeedFactory
No problem on the hi-jacking. KW V3 are a great coil as well.
Old 10-30-2012, 01:46 PM   #13
Boosted
Boosted's Avatar
Drives: 13 brz, 06 STI
I just ordered a pair and am excited to try them out. Had some friends use these on their track/DD cars and loved them.
-Alex
2013 BRZ Limited build: http://www.ft86club.com/forums/showt...d=1#post586737
2006 STI- lots of go fast goodies 551whp/491 Tq on 93(weekend car)
1988 CRX si- b16A1 (Sold)
RIP 2003 WRX
Boosted is offline
Old 11-14-2012, 10:54 AM   #14
FT-86 SpeedFactory
-Alex
Thank you! Holler if you need any help.
Wheel Directory: Buddy Club P1 Racing 17x7.5 +50 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-10-2013 01:24 PM
First set of Buddy Club Racing Spec coilovers! jdmitr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-28-2013 05:59 AM
Buddy Club Racing Spec coilovers, anyone install them yet? Mark Slide Squad Suspension | Chassis | Brakes -- Sponsored by 949 Racing 20 06-28-2013 02:17 AM
***Invidia N1 FRS / BRZ SALE*** Videos and Photos - FT-86 SpeedFactory does it again! FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 33 10-24-2012 10:11 PM
***FORTUNE AUTO COILOVERS*** FT-86 SpeedFactory **EXPERTS** FT-86 SpeedFactory Brakes, Suspension, Chassis 32 09-21-2012 10:42 PM
