Old 10-16-2012, 10:37 AM   #1
Turn in Concepts
Turn in Concepts's Avatar
TIC BRZ 1st on KONI'S
TURN IN CONCEPTS 2013 SUBARU BRZ
Order Date:5/07/2012
Estimated Delivery:7/6/2012
Changed Estimated Delivery:9/14/2012
Arrival date: 9/17/2012
Purpose: Shop Car/ Daily
Purchased: Busam Subaru
Weight:
Motor: 2L
Power: 200hp/150tq
1/4 Mile: HAha
So the car finally came in! 4miles on the ODOM on pick up.
We all took it for a test spin then on the rack she went.
Turn in Concepts is offline   Reply With Quote
The Following 2 Users Say Thank You to Turn in Concepts For This Useful Post:
blu_ (10-17-2012), Spaceywilly (10-16-2012)
Old 10-16-2012, 10:38 AM   #2
Turn in Concepts
MODS
Installed Installed
Yet to be installed
Suspension:
Turn in ConceptsSteering Rack Bushings
Koni's
Racecomp Engineering Tarmac Springs
HVT Non Raising Camber Plates
Whiteline Rear Lower Control Arms
Front Camber Bolts
Whiteline Rear Subframe Bushings
Whiteline 22mm Front Adj Sway Bar
Whiteline Front Endlinks
Whiteline 18mm Rear Sway Bar
Kartboy Rear Endlinks
Whiteline Front Control Arm Bushings
MSI Rear Toe Arms
Drive-train:
Southbend Stage 3 Endurance Clutch Kit
Southbend Flywheel
TIC Group N Engine Mounts
Kartboy Rear Stay
Kartboy Trans Mount Insert
Kartboy Short shifter
Whiteline Rear Diff Mount Bushings
Brakes, Tires, Wheels:
18x9.5 Linea Corse Lemans - Silver w/ Polished Lip (5x100/e30/73)
Hankook RS3 255/35/18
Hawk Hp+ Front Pads
Hawk HPS Rear Pads
RBF600 Brake Fluid
Motive Autowerks Master Cylinder Brace
Engine & Exhaust:
Kartboy Crankshaft Pulley FA/FB
Aesthetics:
TIC Oil Fill Cap
Custom TIC WC Lathewerks Shift Knob[/COLOR]
Old 10-16-2012, 10:38 AM   #3
Turn in Concepts
PHOTOS
The Following User Says Thank You to Turn in Concepts For This Useful Post:
WheelDude.com (12-14-2012)
Old 10-16-2012, 12:51 PM   #4
djdnz
1337
Drives: 2013 BRZ WRB S/C
Excellent, glad to see you guys here.
djdnz is offline   Reply With Quote
Old 10-16-2012, 01:14 PM   #5
Yay! TIC and redheads....
- drew
Old 10-16-2012, 02:18 PM   #6
El_STiG
Lord Stig
El_STiG's Avatar
Drives: Hyundai Genesis Coupe 2.0T
sick wheels
El_STiG is offline   Reply With Quote
Old 10-16-2012, 05:59 PM   #7
Turn in Concepts
So we have been a little bit busy thus we are a little late to the ball game on our journal.
We have some mods that we have done so far that I will be doing a little updating on a little at a time then from here out updating with each future Mod.
Old 10-16-2012, 06:42 PM   #8
Turn in Concepts
Stock VS Rs3's
18x9.5 Linea Corse Lemans - Silver w/ Polished Li (5x100/e30)
We wanted something that would be a little aggresive for the BRZ yet work for us from a performance stand point so we went out on a limn on this one, wheel dude helped us out on getting these wheels.
Old 10-16-2012, 07:48 PM   #9
twincamRob
twincamRob's Avatar
Drives: 2013 FS FR-S
Putnam??
Originally Posted by Turn in Concepts View Post
If so
http://www.ft86club.com/forums/showthread.php?t=18110
Robbie S.
-13 FR-S
-12 H-D 48
Instagram: @twincamrob
twincamRob is offline   Reply With Quote
Old 10-16-2012, 09:42 PM   #10
chaotichoax
chaotichoax's Avatar
Drives: 2013 SWP BRZ
I'm excited to see what you guys do with it. What camber settings are you running with your wheel/tire set up? Any fender mods?
chaotichoax is offline   Reply With Quote
Old 10-17-2012, 02:48 AM   #11
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
any rubbing issues with taht setup guys? i'm looking into 18x9.5+40 with a 255/35 starspec and my buddy is telling me i should go to a +35 instead. car will be on coilovers..
Jive Turkey is offline   Reply With Quote
Old 10-17-2012, 09:07 AM   #12
Turn in Concepts
Originally Posted by ThiWhitaker View Post
Any fender mods?
We are running -2.7 camber front & -1.7 rear
There is some slight rubbing in the rear on VERY fast large bumps on the highway. The tabs on the fenders in the rear have been trimmed lightly. No modifications up front needed (with or without camber plates).
Old 10-17-2012, 10:55 AM   #13
Turn in Concepts
Exhaust
So far we have had two exhaust on the car other than stock. Both we have liked very much in one way or another.
Mach-V
The first exhaust that was installed was the Mach-V BRZ/FRS Muffler Delete Pipe
You can find our review on this exhaust HERE!
Nameless
After a few weeks our second exhaust came in. This is a Custom Nameless axle-back muffler delete.
Old 10-17-2012, 11:38 AM   #14
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Great looking wheels! How much do they weigh?
Jeff86 is offline   Reply With Quote
