Drives: Whiteout FR-S
BLITZ Damper ZZ-R Coilovers
New coilover kit i haven't seen before, spring rates are soft, very soft in the rear with front at 6k, rear at 4k.
BRZ ZC6 -55~0 front adjustment in mm6.0k 150mm ST 4.0k 200mm ST -60~-10 rear adjustment in mm http://www.blitz.co.jp/new-product/2...012-0080EN.pdf ![]() |
Might not be such a bad thing... stock rates are quite a bit softer than that still (fronts at least), and it doesn't feel soft stock. I don't think this car needs overly stiff springs, just slightly stiffer seems to work very well unless you're on R compound slicks.
Anybody have a source for these? I can get them from japan parts for about $1300. I'm thinking about these and the Whiteline adjustable sway bars, set the rear to medium and front to soft to start?
Kouki-Monster
final fantasy seven ... right when I thought I had suspension picked out - this drops.
Rich Anderson
EMPOWER AUTO |
These look like shorter travel too, might be a bad thing with the softer springs.
| The Following User Says Thank You to wparsons For This Useful Post: | cdrazic93 (09-24-2014) |
Spring rates are a bit wonky for the motion ratios at play. Would want at least an even rear spring rate with the front.
Sorry to bring up an old thread, but has anyone installed these or tried them out yet? Very limited information or review on them. Not even limited across the FR-S boards, but all boards. EVO, 370Z, etc.
Because compromise ®
Drives: Red Herring
I like the look, I wish the Eibachs were coated in black. I'm not a fan of chrome.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#10 |
Yeah, but it feels more like no one has tried them. I'm sure if they were bad, there would be some negative reviews out there for sure.
#11 |
still no reviews for these coilovers? Blitz now has a damping adjuster they call "DSC Four" akin to the Teid EDFC. Looks interesting
#13 |
Drives: Black Limited JDM BRZ
Hey, is anyone running these on track? Thinking about buying this set, would be great to hear some feedback from actual users.
P.S. I know rear is quite soft. |
#14 | |||
Drives: 2005 Toyota Camry
I am looking to change this, stay tuned. Quote:
ZZ-R 6/4 front/rear rates ZZ-R Spec C 8/7 front/rear rates http://www.blitz.co.jp/products/susp...er_spec-c.html Will be testing it out soon. -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | solidONE (10-24-2015) |
| Aluminum pulley not a damper, thats ok with alotta folk? | gmookher | BRZ First-Gen (2012+) — General Topics | 28 | 09-13-2012 05:26 PM |
| Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 | quik1987 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 08-27-2012 03:34 PM |
| Hood Shock Carbon Fiber Damper Set? | Mo707 | Cosmetic Modification (Interior/Exterior/Lighting) | 24 | 08-10-2012 02:31 AM |
