Old 10-12-2012, 11:39 PM   #1
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
BLITZ Damper ZZ-R Coilovers
New coilover kit i haven't seen before, spring rates are soft, very soft in the rear with front at 6k, rear at 4k.
BRZ ZC6
6.0k
150mm
ST
4.0k
200mm
ST
-55~0 front adjustment in mm
-60~-10 rear adjustment in mm
http://www.blitz.co.jp/new-product/2...012-0080EN.pdf
Old 10-13-2012, 08:41 AM   #2
wparsons
wparsons's Avatar
Might not be such a bad thing... stock rates are quite a bit softer than that still (fronts at least), and it doesn't feel soft stock. I don't think this car needs overly stiff springs, just slightly stiffer seems to work very well unless you're on R compound slicks.
flickr
Old 10-14-2012, 01:36 AM   #3
JoeBoxer
JoeBoxer's Avatar
Anybody have a source for these? I can get them from japan parts for about $1300. I'm thinking about these and the Whiteline adjustable sway bars, set the rear to medium and front to soft to start?
Old 10-14-2012, 04:36 PM   #4
empower-auto
Kouki-Monster
empower-auto's Avatar
final fantasy seven ... right when I thought I had suspension picked out - this drops.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-15-2012, 08:16 AM   #5
wparsons
wparsons's Avatar
These look like shorter travel too, might be a bad thing with the softer springs.
flickr
cdrazic93 (09-24-2014)
Old 10-15-2012, 11:53 PM   #6
Turn in Concepts
Turn in Concepts's Avatar
Spring rates are a bit wonky for the motion ratios at play. Would want at least an even rear spring rate with the front.
Turn in Concepts is offline   Reply With Quote
Old 03-15-2013, 11:52 AM   #7
CrazyWookiee
Sorry to bring up an old thread, but has anyone installed these or tried them out yet? Very limited information or review on them. Not even limited across the FR-S boards, but all boards. EVO, 370Z, etc.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 03-15-2013, 04:06 PM   #8
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Maybe that is reason enough to stay away from them.
Old 03-15-2013, 04:25 PM   #9
swift996
swift996's Avatar
I like the look, I wish the Eibachs were coated in black. I'm not a fan of chrome.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 03-15-2013, 04:38 PM   #10
CrazyWookiee
Yeah, but it feels more like no one has tried them. I'm sure if they were bad, there would be some negative reviews out there for sure.
Old 09-24-2014, 05:18 AM   #11
marlonthegreat
marlonthegreat's Avatar
still no reviews for these coilovers? Blitz now has a damping adjuster they call "DSC Four" akin to the Teid EDFC. Looks interesting
marlonthegreat is offline   Reply With Quote
Old 09-24-2014, 08:22 AM   #12
troek
troek's Avatar
Drives: 2012 Toyota 86
they're pretty popular over here. but they sell for cheap here, so that may be why.
troek is offline   Reply With Quote
Old 10-22-2015, 09:19 PM   #13
In1t
In1t's Avatar
Drives: Black Limited JDM BRZ
Hey, is anyone running these on track? Thinking about buying this set, would be great to hear some feedback from actual users.
P.S. I know rear is quite soft.
In1t is offline   Reply With Quote
Old 10-23-2015, 01:38 PM   #14
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
No one has tried them out in North America because they have had subpar distribution in the past few years.
I am looking to change this, stay tuned.
There's two versions:
ZZ-R 6/4 front/rear rates
ZZ-R Spec C 8/7 front/rear rates http://www.blitz.co.jp/products/susp...er_spec-c.html
Will be testing it out soon.
-alex
solidONE (10-24-2015)
Aluminum pulley not a damper, thats ok with alotta folk? gmookher BRZ First-Gen (2012+) — General Topics 28 09-13-2012 05:26 PM
Wheel Directory: Blitz BRW Profile 08 18x8.0 +45 / 18x8.0 +38 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-27-2012 03:34 PM
Hood Shock Carbon Fiber Damper Set? Mo707 Cosmetic Modification (Interior/Exterior/Lighting) 24 08-10-2012 02:31 AM
