Old 10-12-2012, 04:44 PM   #1
jadewbj
jadewbj's Avatar
Drives: 2013 Whiteout Scion FRS
Got my Alignment done at Revworks
One of the most pain in the ass things of having a lowered car is finding somewhere to get an alignment. Normal tire places will basically tell you no way you are getting on their machine.
Luckily for me Revworks is around the corner from my house and they do performance alignments on cars all the time.
Here is my before and after setup. They did a mild performance setup that would allow for good daily driving. Look how screwed up my alignment was after the Tein install. If you wondered if it is important to do an alignment after a suspension install this should answer it for you. I would have had no tires if I kept driving like this.
jadewbj is offline   Reply With Quote
Old 10-12-2012, 04:50 PM   #2
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Wow, toe was way out after the install, camber looks good after the alignment but still more toe in the rear than i would prefer.
JoeBoxer is offline   Reply With Quote
Old 10-12-2012, 04:53 PM   #3
jadewbj
jadewbj's Avatar
Hopefully with some arms we can get it better later.
Old 10-12-2012, 04:57 PM   #4
JoeBoxer
JoeBoxer's Avatar
I need to get mine installed myself so i can get my camber corrected, i have more camber in the right rear with only a .8" drop
Old 10-12-2012, 05:03 PM   #5
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Was looking at all the left-over toe on the rear but now I see that you didn't do control arms yet.
I went with the TEINs, too, and ordered the AP control arms so definitely hoping to scrub that toe out. Otherwise, gonna be scrubbing rubber instead!
cobrabyte is offline   Reply With Quote
Old 10-12-2012, 05:06 PM   #6
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
I get my BRZ done there then Enjuku had to go and do theirs and now you...
JK :P Revworks does good stuff, been sending referrals their way to all of my friends.
Ill be back for an update to mine later this month hopefully.
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 10-12-2012, 06:39 PM   #7
jeebus
Drives: 2015 Mustang GT (on order)
I don't know what you guys are talking about, that's a perfectly fine amount of rear toe in.
jeebus is offline   Reply With Quote
Old 10-13-2012, 10:25 PM   #8
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
My toe was out of whack like that, made it very twitchy and unnerving to drive. I'd go back and zero that out.
How did you get -2 camber in the front?
Do you plan to get control arms or the whiteline camber bushings?
F1point4 is offline   Reply With Quote
Old 10-15-2012, 09:50 AM   #9
jadewbj
jadewbj's Avatar
This was a mild performance alignment according to them. They said that the car is basically the same as setting up an S2K and used that as a baseline.
I have tein flex coilovers with camber plates in the front.
Old 10-15-2012, 11:42 PM   #10
Turn in Concepts
Turn in Concepts's Avatar
The car is nothing like an S2000 in terms of suspension setup or geometry.
What we have found for track use is to get about neg 3* camber in the front and neg 2* in the rear with 0 toe front and .15 to .2 total degrees in rear. Any less than that and the car gets loose at high speed.
Turn in Concepts is offline   Reply With Quote
Old 10-16-2012, 12:35 AM   #11
Racecomp Engineering
AGREED ! -2.0 camber is the sweet spot in the rear for sure and yes when able to run close to -3.0...WOW WOW WOW. Getting caster up around 6.6ish makes for a "turning" car !
Myles
Old 10-16-2012, 11:49 PM   #12
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
^These guys know their stuff, I would heed those numbers and advice well
Circuit Motorsports is offline   Reply With Quote
Old 10-17-2012, 09:57 AM   #13
jadewbj
jadewbj's Avatar
I am checking with them to see what they say. I am no suspension guru and went with the vendors recommendation.
Old 10-17-2012, 10:18 AM   #14
Rev Works
Rev Works's Avatar
Drives: 2013 STi
We understand that this car is not an S2000, we were simply using it as a base point to set OE alignment specs. This particular customer said he wanted a mild performance alignment mostly used for daily driving. We do agree though that for track use the numbers listed by the other vendors, would be good specs as well.
Thank you for the write up Buddy, and to the other vendors for your input!
Rev Works is offline   Reply With Quote
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
RTR Wheel Alignment simpleisbest Tracking / Autocross / HPDE / Drifting 61 11-07-2012 07:48 PM
DIY alignment dsgerbc Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-17-2012 11:41 AM
where to get alignment? FML Hawaii 2 08-08-2012 01:36 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
