Old 10-10-2012, 01:35 PM   #1
Linseal
Linseal's Avatar
Drives: Argento MT Scion FR-S
Stock shift knob problems?
So shortly after I got the car I noticed that the shift knob would rotate while I was shifting. So I rotated it the other way and tightened it, the problem is when you do that the shaft pushes the shift pattern plate up. Has anyone else had this problem? I would really like to find a solution without changing out the stock knob, I like it
Linseal is offline   Reply With Quote
Old 10-10-2012, 01:38 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have your solution, take it to the dealer, and they'll get you a new OEM one that works
Old 10-10-2012, 01:38 PM   #3
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I have the same problem. Kind of annoying that the plate is loose.
And I'd hate to take it into a dealer for something dumb like that. Can't help my feelings, but I will avoid any dealer if I can.
Chimpo is offline   Reply With Quote
Old 10-10-2012, 01:39 PM   #4
mashal
DADA
mashal's Avatar
Drives: 2013
It will rotate over time, my stock did that and now my flossy one has rotated about 5 degrees , which I kinda like coz the numbers are now facing me
I-Tapatalk
mashal is offline   Reply With Quote
Old 10-10-2012, 01:45 PM   #5
wotter
Drives: Toyota GT86
Lol, I though I was the only one ^^
I forgot to mention it when I was at the dealer for the 1000KM check.
wotter is offline   Reply With Quote
Old 10-10-2012, 02:27 PM   #6
TRBO2NR
Speed Racer
TRBO2NR's Avatar
Drives: 94' Supra TT 6MT, 11' Subaru WRX
You could always try some thread tape or locktite to tighten the fitment and reduce the number of turns needed to keep it on? Just a thought...
1994 Toyota Supra TT 6spd - BPU+++
2011 Subaru WRX Premium Hatchback
2013 Scion FR-S 6MT Whiteout *SOLD
TRBO2NR is offline   Reply With Quote
Old 10-10-2012, 02:35 PM   #7
whaap
whaap's Avatar
How about every so often just take your hand and straighten it out?
whaap is offline   Reply With Quote
Old 10-10-2012, 03:59 PM   #8
denverizzles
that's why you get a shift knob with no numbers...i mean really, do you really need numbers to know what gear you are in?
denverizzles is offline   Reply With Quote
Old 10-10-2012, 04:50 PM   #9
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
What does that have to do with the knob coming loose? If you try to tighten it, it causes the top of the knob to push up and off. It is disconcerting having the knob turn in your hand when you are trying to find a gear.
I have a BRZ knob in my MR-S and it did the same thing. It is because the knob is not made with a proper stop at the top of the threads. They (Toyota and Subaru) are relying on the cap to stop the shift shaft but it is not stout enough. I solved the proplem by making a stop out of the threads from a m12 x 1.25 bolt and screwing it all the way in then putting the knob on and screwing it on. I had to take it off a couple times and adjust the insert so the shift pattern looked right but it does work. If I had a new FR-S or BRZ I would go to the dealer and get a new knob.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 10-10-2012, 05:12 PM   #10
mattles
Proud of FR Layout
mattles's Avatar
Drives: 2013 Scion FR-S 6MT
No but if anyone else ever drives the car, its nice.
Funny story, the ONE TIME I valeted my old turbo miata I had a different MAZDA OEM knob on there with the wrong pattern and the poor valet was going nuts on my transmission and clutch/throttle trying to find reverse. I had to walk back to the valet lot and show him where reverse was. Youd think it be easy to guess since the car only rolls backwards in reverse, and there are really only 4 spots where reverse could be.
--Matt // Flickr \\ Instagram
mattles is offline   Reply With Quote
Old 10-12-2012, 03:32 PM   #11
wheelman
Drives: 2013 Scion FRS
Cool shift knob
if you are not happy call the dealer and they will replace it for you.and you do not have to tighten the shit out of it.just make it tight enough not to spin around..whats the big deal have you ever had a stick before? damn does everyone on here just come to cry???? enjoy the ride man!!! you can got a spun aluminim one from toyota only 200.00 hahahahaha!!!
wheelman is offline   Reply With Quote
Old 10-12-2012, 04:44 PM   #12
Linseal
Linseal's Avatar
Yes, I've only ever owned manual cars and none of those knobs ever rotated on me mid-shift. I was just wondering if anyone else had the same problem and how they fixed it..... not really crying. But whatever you say.
Old 10-12-2012, 04:56 PM   #13
DarkSunrise
DarkSunrise's Avatar
Mine was one full turn loose when I got it. Tightened it 360 degrees and it's been fine ever since. Loc-tite could also work.
Old 10-12-2012, 10:46 PM   #14
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Got the same problem i ll see with my parts guy at work if i can get another on for free
Silverdub is offline   Reply With Quote
Stock shift knob weight pkny Cosmetic Modification (Interior/Exterior/Lighting) 5 07-30-2015 09:11 PM
Stock Shift Knob Weight ngabdala Cosmetic Modification (Interior/Exterior/Lighting) 6 09-05-2012 07:43 PM
MXP Titanium shift knob - in stock No Limit Motorsport Interior Parts (Incl. Lighting) 1 08-06-2012 03:37 PM
