Old 10-09-2012, 10:06 AM   #1
mjsivee
Drives: Scion FR-S
Lighted Up Exclamation Point
A lighted up exclamation mark came on on my car today, and the engine started making a large clicking sound. I currently have about 2,750 miles on the car. What does this mean?
I installed a cold air intake and a crank pulley a month ago. Should I install my oem crank pulley and air intake before I bring my car in the dealer. Any help would be greatly appreciated.
mjsivee is offline   Reply With Quote
Old 10-09-2012, 10:17 AM   #2
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
That's not the check engine light. Tire Pressure warning maybe?
rapidcars is offline   Reply With Quote
Old 10-09-2012, 10:18 AM   #3
cnk
Drives: '13 DGM BRZ Limited
Look it up in your owner's manual. According to the BRZ manual, an exclamation is for the brake system and recommends checking the brake fluid level or ensuring that the parking brake is completely released. It does mention that the exclamation is only used in Canada though as the US models say the word "brake" so not sure if the FR-S is different.
cnk is offline   Reply With Quote
Old 10-09-2012, 10:58 AM   #4
mjsivee
Drives: Scion FR-S
I checked my brake fluid and my tire pressure and everything and it was perfectly fine. If it is a tire pressure problem do you think I still have to go through the trouble of reinstalling my crank pulley and air intake. It's not like they would check that If it is a tire problem right?
Old 10-09-2012, 11:14 AM   #5
dsgerbc
Drives: BRZ(sold), STI
Not sure it's 100% the same in a Scion, but there are only two exclamation signals in a USDM BRZ. TPMS (! inside a tire profile) and an electric steering warning (! next to a steering wheel pic). My TPMS light came on the other day. It was cold and one tire pressure dipped below 30psi.
dsgerbc is offline   Reply With Quote
Old 10-09-2012, 11:16 AM   #6
Spd229
Spd229's Avatar
Drives: Ultramarine FR-S AT
http://www.scion.com/images/cars/frs...frs_ipTPMS.jpg
using this as reference. That's your TPMS warning light.
The recent cooler weather would also cause this light to go off. I've been ignoring mine for a while now as once I've driven enough the tires heat up and the pressure goes back into a reasonable range so that the warning light goes off. As winter gets closer I'll probably top them off a little.
Spd229 is offline   Reply With Quote
Old 10-09-2012, 12:01 PM   #7
frsfreak
Drives: 2014 Scion FR-S Ultramarine Mono
I had this light a few weeks ago. I looked it up in the manual and it turned out to be low tire pressure. Just top off your tires and it should go away.
frsfreak is offline   Reply With Quote
Old 10-09-2012, 12:54 PM   #8
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
My wife once called me because the TPMS light cam on and she didn't know what it meant. She described the light as "An angry fishbowl" LOL
The Following 4 Users Say Thank You to neutron256 For This Useful Post:
86-tundra (12-04-2013), Smudgeous (10-22-2012), Sportsguy83 (12-04-2013), Xanatos (10-09-2012)
Old 12-04-2013, 11:54 AM   #9
Liquidsnake
Drives: "I drives like a Porsche"
That is awesome.
Liquidsnake is offline   Reply With Quote
Old 12-04-2013, 12:38 PM   #10
Tromatic
The FR-S/BRZ would be about two grand less if they just gave up on creating and printing the owners manual!
Tromatic is offline   Reply With Quote
Old 12-04-2013, 12:57 PM   #11
FR-S Matt
TPMS, check your tire pressure on all 4 and add air as needed and continue to monitor to see if you have a slow leak. Find the tire that's the lowest and you found your problem.
Stock tires should be ~35 PSI. Certain aftermarket ones work better with a bit more air around 37 or 38 PSI. If you're in the 32-38 range, you should be okay.
Old 12-04-2013, 02:33 PM   #12
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
The TPMS light comes on when air pressure is low to the point of causing safety issues. If you ever see it you haven't been filling it up often enough, period.
You can still have low pressure that's going to cause uneven wear or low MPGs and no TPMS light on.
DoomsdayJesus is offline   Reply With Quote
Old 12-04-2013, 02:48 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I like how a thread from a year ago is being brought back for no reason other than to laugh at a comment, but anyhow...
Or rather, it doesn't work very well.
I've had my Work Wheels (no TPMS) on the car for almost a month now.
I would say, half the time the car drives with no warning. 25% of the time, the light comes up almost immediately after starting the car. 25% of the time, the light stays off then flashes approx. 10-15 minutes into a drive.
I'd rather have some option to delete/disable this system, it's a worthless POS.
-alex
Old 12-04-2013, 04:32 PM   #14
DoomsdayJesus
-alex
I didn't notice the thread necromancy, lol.
Also, with different wheels/tires you may need different sensors, I forget exactly how it works but I remember reading about some issues over at tire rack. They're not cheap sensors to replace.
What did you mean by work wheels? I know there are ways to get the stock sensors into new wheels and get them recognized by the TPMS system, either that or installing new sensors.
What is the point of this car? dem00n Scion FR-S / Toyota 86 GT86 General Forum 88 10-09-2012 03:31 AM
If only someone made a lighted shiftknob TIE Pilot Cosmetic Modification (Interior/Exterior/Lighting) 11 09-20-2012 03:12 AM
BRZ at Point Mugu, CA ashtray BRZ Photos, Videos, Wallpapers, Gallery Forum 5 07-01-2012 06:52 PM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
What is the point/appeal in drifting? swift996 Other Vehicles & General Automotive Discussions 8 04-27-2012 11:38 AM
