Old 10-07-2012, 07:28 AM   #1
takipokonai
takipokonai's Avatar
Drives: AE86 / GT86
BC coilover - how to setup
I just installed my BC coilovers and need some help setting them up.
I know what to set where but that´s about it.
how do i know how high the spring preload is?
also i drive the car on a daily basis but i go to track days and drift events once a month at least.
what would be the best setup?
would appreciate some help.
thanks
"Here was a car that was designed to do something I had forgotten about – taking the long way home."
takipokonai is offline   Reply With Quote
Old 10-07-2012, 08:09 AM   #2
scyzer
Drives: GTS 86
[ame="http://www.youtube.com/watch?v=HlqOA35NmAw"]BC Racing Coilover Spring Change and Preload Adjustment on Vimeo.mp4 - YouTube[/ame]
[ame="http://www.youtube.com/watch?v=UiiId9lsgno"]How to adjust BC Coilovers correctly - YouTube[/ame]
Those videos should help.
Also, I've ordered some BCs with Swift Spring upgrades. It seems that the fronts have less than 1 inch of drop adjustment available due to the length of the springs (which are the same length/internal diameter as the rears)
That is, unless they've already screwed the shock body in a bit?
Is that a picture of the front coilovers you've received? Seems like a lot more adjustment range than what I'm seeing.
scyzer is offline   Reply With Quote
Old 10-07-2012, 08:29 AM   #3
takipokonai
Drives: AE86 / GT86
ok that first video really helped so now i know how much it will change the preload.
yes the coilovers came as pictured but the spring was very loose, i tightened it up a good amount. i installed them as shown on the picture and the car was high as an SUV :P
i have about 2 cm (0,8 inches) left between the upper and lower nuts.
how many preload should be good for daily driving with track use of the car?
it seems very comfortable now.
Also how will changing the settings when adjusting the damper?
Old 10-07-2012, 08:50 AM   #4
scyzer
Drives: GTS 86
Not an expert on this, but my plan was to not touch the preload after setting it up and doing the rest with the damper adjustment.
Hrmm... here's how much adjustment I have on the fronts with about 5mm of preload dialed in.
*EDIT: original picture size was waaay too big
Old 10-07-2012, 02:27 PM   #5
takipokonai
Drives: AE86 / GT86
ok but on which numbers have you set up the preload? how much is good for trackday use? how much to use on daily road?
Old 10-07-2012, 03:44 PM   #6
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
damn now I know how to set up the coilovers properly lol oops.
thanks for the video
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Let's see your computer setup! Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 79 11-06-2022 11:43 AM
Winter setup cnk NY / NJ / CT / PA 72 12-13-2012 08:48 PM
Brz Drag Setup Tansey86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 09-12-2012 11:24 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
2 car setup...feasible? mankarn86 CANADA 3 03-30-2012 02:00 AM
