Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 09-28-2012, 05:26 AM   #1
yomchi1989
n00b
Drives: Pfft... go by Kangaroo! STRAYA!
Question Help re: WORK wheels
Hey guys,
I am a n00b when it comes to all this "offset" business. Can someone please explain to me what the difference is with these:
18 X 7.5 [4-100, 4-114.3, 5-100, 5-114.3 / +38 +47 +53]
18 X 8.5 [5-100, 5-114.3 +30, +38, +47]
18 X 9.5 [5-100, 5-114.3 +12, +20, +30, +38]
18 X 10.5 [5-100, 5-114.3 +23]
yomchi1989 is offline   Reply With Quote
Old 09-28-2012, 05:45 AM   #2
Z86
Drives: 86 GTS Auto in Pegasus White
Check out Wheel 101 thread
http://www.ft86club.com/forums/showthread.php?t=3062
Z86 is offline   Reply With Quote
Old 09-28-2012, 06:02 AM   #3
yomchi1989
n00b
Originally Posted by Z86 View Post
Hey mate, I can't really see the link between that info. and helping me solve these digits lol. I know though that I want a "negative" offset (a little at the front, and more at the back).
Old 09-28-2012, 06:14 AM   #4
a.beck
Doing it wrong.
a.beck's Avatar
You absolutely do not want a negative offset on this car.
Read the post in the link that Z86 gave you. Read the whole thing. The information you seek is in there. There's not a shortcut if you want to actually know this stuff. The answer to your (rather vague) question about the differences between those wheel specs is more or less that whole long-ass post.
It'll be worth the time you invest reading it, honestly.
a.beck is offline   Reply With Quote
Old 09-28-2012, 06:42 AM   #5
Palmy
Palmy's Avatar
Drives: '12 86 GTS (AUDM)
Originally Posted by yomchi1989 View Post
Hey guys,
18 refers to the wheels diameter.
7.5 - 10.5 refers to the wheels width
4-100, 4-114.3, 5-100, 5-114.3 refer to the number of bolt holes and their spacing (you need 5-100)
+38, +47 etc etc is the off set, you need something from +38 to +50 depending on your wheel width, and how much "poke" you want.
Personally out of these wheel sizes I'd go with 18x8.5 5x100 +38
Palmy is offline   Reply With Quote
Old 09-28-2012, 08:12 AM   #6
Nardi330
Nardi330's Avatar
Drives: 86
Before deciding what width and offset u want for your wheels, u should think about what tyre size you want to run as it would directly effect handling.
I'd work out the tyre size first then determine what wheel width would fit the tyre then work out the offset to determine clearance (both suspension and guard).
If you are focusing on handling, u focus on tyre size but if you are focusing on look then you care more about wheel size then find a tyre that fits.
Nardi330 is offline   Reply With Quote
Old 09-28-2012, 08:16 AM   #7
yomchi1989
n00b
Cheers mate. I am thinking either the
18" Bridgestone Potenza S-04 Pole Position tyres
or
18" Michelin Pilot Super Sport tyres
Old 09-28-2012, 08:19 AM   #8
Nardi330
Nardi330's Avatar
Drives: 86
18" is the wheel diameter, how about width??
Do u want to run staggered or square? What handling style do u want to achieve? This will determine the tyre width then u think about wheel size.
Also do u prefer look or performance?
Old 09-28-2012, 08:38 AM   #9
Panman
Panman's Avatar
Drives: 86 GTS
I think he prefers to start a thread for every half question that pops into his head instead of doing any research.
Yomchi please do at least a little of your own research (or even just search) before starting yet another thread.
Everyone here is willing to help someone out but you are almost taking the piss now.
Panman is offline   Reply With Quote
Old 09-28-2012, 08:46 AM   #10
yomchi1989
n00b
Hi Nardi,
Thanks mate! The diameter is the only thing I am undecided on. I want to go a staggered look, similar to this:
http://www.google.com.au/imgres?q=wo...r:9,s:18,i:157
I would like the front to "poke" in a bit, and the rear to "poke" in a little bit more.
I would like both appearance and performance, but I guess they are performance tyres lol.
Old 09-28-2012, 08:48 AM   #11
yomchi1989
n00b
Panman, FYI, I have spent a few hours trying to find the answers to my questions online. Not to mention, I have emailed half a dozen suppliers... they either haven't responded, or give vague answers. On top of that, JDM concept recommended that I ask my questions on here.
Old 09-28-2012, 09:07 AM   #12
Nardi330
Nardi330's Avatar
Drives: 86
Hi Nardi,
If this is the look you want then the spec is 18x9.5+30 all round. Tyres I think was 225/40/18 front and 245/35/18 rear. Please double check with Leo @ JDM Concept.
Please note u will need some suspension modification to fit, particularly lowering and more negative camber. I'm sure Leo can find out for you.
Be warn tho this setup is quite aggressive. Personally I think this is a more look focused setup than performance focused, particularly if you are not planning to increase power.
Old 09-28-2012, 09:11 AM   #13
yomchi1989
n00b
Cheers, yeah, I don't want to drop it that low. I think a 1" drop would be more than suitable.
Old 09-28-2012, 09:14 AM   #14
yomchi1989
n00b
What do you have on your car?
These look better probably... a bit deeper at the rear and the car hasn't been dropped so much.
http://www.iputinwork.com/?paged=4
wheels
Work Vs. Drag wheels mickey177 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 68 05-30-2013 11:29 AM
help me decide which work wheels to order??!!! Saibot Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 05-29-2012 09:42 AM
Are 17" wheels too big? Might work 16's work a little better? rogerdalien Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 46 05-10-2012 10:09 PM
