Old 09-28-2012, 03:14 AM   #1
winsometang
Drives: Scion F-RS 2013 Asphalt MT
perrin pulley vs warranty?
i just bought the perrin lightweight crank pulley. ive heard that it may be bad for the engine and may even void the warranty? is this true?
winsometang is offline   Reply With Quote
Old 09-28-2012, 03:32 AM   #2
DSTL
Drives: 2013 BRZ Limited 6MT
http://www.google.com/search?q=will+...ctory+warranty
800-SUBARU3 they will say:
"Installing an aftermarket product onto your Subaru will not negate any warranties.* However, if an aftermarket product causes any issues with your Subaru, the repairs may not be covered under warranty."
That is the official Subaru canned response verbatim.
This could be debated eternally as a hypothetical. Only one way to find out for sure.
Saw you are FR-S, don't have their # but same story...
DSTL is offline   Reply With Quote
Old 09-28-2012, 04:12 AM   #3
Ravenlokk
Ravenlokk's Avatar
Drives: 2013 Raven FR-S
Mods don't void warranty. The technician ultimately makes that call when doing the warranty work on your vehicle. As has been stated many times on this forum, if the mod is in any way related to the warranty claim they can use it as cause to void the warranty. For example, if you blow your engine, and have a pulley they can refuse warranty service.
Ravenlokk is offline   Reply With Quote
Old 09-28-2012, 10:44 AM   #4
whitejdm
Drives: BRZ prem.
This was clarified some years ago, the dealership has to prove that the specific modification caused the specific failure.
whitejdm is offline   Reply With Quote
Old 09-28-2012, 10:50 AM   #5
Jeff86
Jeff86's Avatar
Drives: 86 (FR-S)
Dealers try to deny warranty service all the time. I had to prove that a problem my wife's TSX was having was covered under warranty by presenting the dealership with documentation from their own company headquarters.
Edit: That said, I would certainly reverse this particular mod before I let the dealership see the car. I haven't done this mod because there is no vibration damper on this pulley and there is on the factory design. Too easy to argue that it caused a problem... and honestly, it could cause crankshaft issues.
Jeff86 is offline   Reply With Quote
Old 09-28-2012, 11:44 AM   #6
fasteddy
Thay could sure use it as an excuse to deny a warranty claim on the engine. I would take it off before you take it in for anything like that.
Pat
fasteddy is offline   Reply With Quote
Old 09-28-2012, 12:44 PM   #7
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
It's always a good idea to put the car back to stock before you try to take it in for warranty work to avoid the dealership disputing it. I have not seen or heard of any issues caused by a decent quality aftermarket crank pulley on a Subaru so I would not be worried about it.
-Zach
RallySport Direct is offline   Reply With Quote
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Perrin Pulley and Exhaust Simmons Engine, Exhaust, Transmission 13 09-26-2012 12:39 PM
FS: Perrin lightweight pulley (Vancouver BC) stanm Canada Classifieds 0 09-15-2012 08:04 AM
Perrin/Brand 'Y' Crank Pulley ? rikdrt1 Engine, Exhaust, Transmission 1 09-10-2012 04:39 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
