Old 09-24-2012, 04:54 AM   #1
APS86
Drives: GTS86 Manual
advice needs re 0W-20 oil brand
HI all,
Ow-20 oil is a little difficult to come by in Australia - 2 options I can get are:
Mobil 1 Engine Oil 0W20 Advanced fuel economy or
0W20 SAE Royal Purple Motor Oil
I need it for my first oil change and I don't know anything about the royal purple oil so wold value peoples opinion
cheers and thanks in advance
APS86 is offline   Reply With Quote
Old 09-24-2012, 08:03 AM   #2
sierra
Drives: Skoda Yeti DSG diesel 4x4
Amsoil in another brand but I don't know if we can get it in Oz?
Amsoil vs Mobil 1
Amsoil vs. Royal Purple
Here's the thread with loads of info .
http://www.insightcentral.net/forums...hetic-oil.html
sierra is offline   Reply With Quote
Old 09-24-2012, 10:12 AM   #3
lordtakuban
lordtakuban's Avatar
Drives: 2013 FRS - Whiteout
Amsoil is good stuff. I would not buy either Mobil 1 or Royal Purple. See if you can get Redline ester based synthetic if you can't get Amsoil or Motul.
2013 FRS - Whiteout - Slightly modified
2001 MR2 Spyder - Super White - Heavily modified
lordtakuban is offline   Reply With Quote
Old 09-24-2012, 10:22 AM   #4
diirk
diirk's Avatar
Drives: 4Runner
I wouldn't hesitate to buy Royal Purple or Mobil 1. I've used both and never had any concerns. And I was using the Royal Purple in a very rough race environment. Redline as mentioned is also good as is Motul.
The big thing to watch for with synthetics is to avoid mixing them. Any time I switched from one synthetic to another, I always ran a regular dino oil in between. Different synthetics have different additives and may not always work well together. There is no issue with mixing a synthetic with a dino oil in case the situation ever arises.
diirk
waiting on a Neptune Premium MT
diirk is offline   Reply With Quote
Old 09-24-2012, 06:08 PM   #5
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Amsoil vs Mobil 1
I just want to clarify for the sake of other people, those first two links are NOT independent tests, they are run by Amsoil themselves.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 09-24-2012, 06:44 PM   #6
dsgerbc
Drives: BRZ(sold), STI
At least until the warranty runs out I'd use the one that complies with manufacturer requirements. Is RP now properly certified?
dsgerbc is offline   Reply With Quote
Old 09-24-2012, 09:14 PM   #7
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I don't know why so many people poo poo Mobil 1. If top class racing teams can use it (some even straight from the retail bottles), and top quality car manufacturers factory fill and recommend it, then I don't see how it could be so bad. I remember when Mitsubishi Ralliart switched to Mobil 1 for their WRC car and were shocked at how much power they gained. They said it would have cost them several thousands of dollars just to try and gain that much performance elsewhere. It has been proven in just about every way you can prove a product - millions of miles in the harshest conditions. Even when I took apart my own engine after 100k of hard use with Mobil 1, the mechanics said it was the cleanest looking engine they had seen. And I've tried other oils, including the new Pennzoil Ultra, but none of them feel as smooth or give me as much power. And it's available everywhere for a good price. Plus, they have friendly and knowledgeable customer service.
So yeah, you can swear by Amsoil or Royal Purple or Redline all you want but I've never seen any top racing teams use it. And sure, the big oil companies pay but if they really could get a noticeable improvement over the competition, then surely you would still see some bigger racing teams go for it. And I'm certainly not going to special order it and pay extra every time I need to change the oil...
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 3 Users Say Thank You to Bristecom For This Useful Post:
KGFRS86 (09-27-2012), Wes (09-25-2012), zoomzoomers (10-05-2012)
Old 09-24-2012, 10:00 PM   #8
sierra
The only negative i've heard about Mobil 1 are the reports of high oil consumption in subaru boxer engines. That might not apply to ours?
Old 09-24-2012, 10:07 PM   #9
diirk
diirk's Avatar
Drives: 4Runner
So yeah, you can swear by Amsoil or Royal Purple or Redline all you want but I've never seen any top racing teams use it....
Actually, I know race teams that have used all three. Not saying they're better or worse then Mobile 1, but they have a race background also.
diirk
Old 09-24-2012, 11:39 PM   #10
SXE10
SXE10's Avatar
Drives: Altezza RS200-Z 6MT
Originally Posted by diirk View Post
The big thing to watch for with synthetics is to avoid mixing them. Different synthetics have different additives and may not always work well together.
If the oils have an API or ILSAC rating then they are fine to mix/run back to back. You'll need to be running an oil with either of these ratings if your car is under warranty anyway.
For the OP, a few more retail options.
http://www.caltex.com.au/PRODUCTSAND...n.aspx?ID=1832
http://www.fuchs.com.au/categories.asp?cID=9&c=25467
You realise most oil companies down under do 0w-20 but only supply it in bulk to the trade.
SXE10 is offline   Reply With Quote
Old 09-25-2012, 12:05 AM   #11
cnk
Drives: '13 DGM BRZ Limited
I ran Mobil1 on my WRX for over 8 years without any consumption issues. It was modified and putting down 292whp/255wtq the entire time.
cnk is offline   Reply With Quote
Old 09-25-2012, 01:12 AM   #12
serial gixxer
So for all you guys running mobil 1, are you using 0w20 or 0w30?
serial gixxer is offline   Reply With Quote
Old 09-25-2012, 01:45 AM   #13
Bristecom
Bristecom's Avatar
Just use 0W-20 like the manual says. The only thing 0W-30 will give you is less power and lower fuel economy. Unless you are planning to race or track it on a very hot day and want to give it a little extra protection. But then you'd probably want to go with a real racing oil like this: http://www.mobil1racingstore.com/mo1ra0wsin1.html
Toyota + Subaru =
The Following User Says Thank You to Bristecom For This Useful Post:
serial gixxer (09-25-2012)
Old 09-25-2012, 04:05 AM   #14
APS86
interesting discussion - just found another 0w-20 oild I can get my hands on:
but again it says a racing oil
should you not use in your day to day driver???
Need some help/advice buying my first BRZ/FRS RYU Southern California 8 08-30-2012 03:00 PM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 01:17 AM
Need advice.. Help.. tintumz22 Scion FR-S / Toyota 86 GT86 General Forum 9 08-13-2012 09:57 PM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 06:39 PM
FR-S or BRZ? Need some advice Davie Dynamite Scion FR-S / Toyota 86 GT86 General Forum 60 07-13-2012 11:47 PM
