Old 09-23-2012, 11:09 PM   #1
nightfire
Drives: 2013 SWP BRZ Limited manual
Question How to Change Shiftknobs?
I just bought one of the BLOX tear drop shaped shift knobs. How do I take off the stock one, just a simple screw on screw off? Also I was assuming this style would retain the stock reverse lock out but I never actually check it out, anyone one about this?
nightfire is offline   Reply With Quote
Old 09-24-2012, 12:16 AM   #2
CrazyWookiee
Drives: Whiteout FR-S
To take the shift knob off you just unscrew. From what I've seen the BLOX should be okay with the stock reverse lockout.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
Old 09-24-2012, 12:35 AM   #3
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
You start by searching, not by making repeat threads.
chulooz is offline   Reply With Quote
Old 09-24-2012, 02:54 AM   #4
Mitch
form follows function
Drives: RIP '13 BRZ
I like how that you'd have to know the answer to be able to know it's already been answered, yet would spend as much time to answer "search for it" rather than just answer the question. It's a very "screw off, why don't you" vibe you add to the forum.
As to the OP, the knob is a simple screw on/off. I don't know if that particular knob is designed to accommodate the lift ring for reverse. Hopefully someone with experience with that knob will chime in.
Mitch is offline   Reply With Quote
Old 09-24-2012, 01:41 PM   #5
chulooz
Registered you sir
chulooz's Avatar
You do not need to know the answer to a question in order to find out if its been asked
Something something teach a man to fish something something something
And yeah the thing will fit.
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
When should i do an oil change? Ayaz2589 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 112 03-15-2013 01:25 PM
3,000 mi oil-change prest1ge Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 38 10-29-2012 07:13 PM
Took my car in for an oil change... joshua BRZ First-Gen (2012+) — General Topics 25 08-04-2012 09:32 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
