Old 09-23-2012, 12:46 PM   #1
sitandspin
Drives: Raven FRS
sciatica seat issues
so I recently picked up my auto FRS and the seat is comfortable enough, but I am noticing some right leg numbness issues which i believe are from pressure on the sciatic nerve. after 5 minutes of driving the spot where my hamstring and glute attach gets sore/numb and the longer I drive the lower it travels down my leg.
it seems to me that it is caused by my knees being substantially higher than my hips, and since the seat doesn't tilt I can't adjust this. I am afraid I will have to get a little wedge of foam or something, but I don't want to be THAT guy with a seat cushion.
Any suggestions?
sitandspin is offline   Reply With Quote
Old 09-23-2012, 12:54 PM   #2
jmaryt
Drives: 2012 honda civic ex
yeah! you are getting older! your body don't contort like it used to!
get the cushion,and screw what any body thinks!
jmaryt is offline   Reply With Quote
The Following User Says Thank You to jmaryt For This Useful Post:
Guff (09-26-2012)
Old 09-23-2012, 12:58 PM   #3
sitandspin
Drives: Raven FRS
getting older? eeeegh i'm only 26! haha
The Following User Says Thank You to sitandspin For This Useful Post:
Guff (09-26-2012)
Old 09-23-2012, 01:01 PM   #4
jmaryt
ok! that's kewl! i wouldn't worry about it! your comfort is foremost! if ya can't be comfortable in the car! then you are driving the wrong car! i say do what's necessary to allow you to keep the car and enjoy it!
Old 09-23-2012, 01:12 PM   #5
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I hear you. I am reaching geezer status but discomfort isn't as bad.
I drove 3 hours on Friday and had some discomfort but it didn't get numb.
I found myself constantly rearranging my legs.
I did come to the same conclusion that the seating lacks a tilt feature.
You might just have to be that guy unfortunately.
I'm sure the frame could be modified to be tilted but as you are likely aware it's not a simple affair.
Good luck.
CircuitJerk is offline   Reply With Quote
Old 09-23-2012, 01:36 PM   #6
Those Meddling Kids
Drives: 2013 SWP BRZ limited
I bet you could get some slightly longer bolts and wedge some washers under the brackets.
Those Meddling Kids is offline   Reply With Quote
Old 09-23-2012, 02:37 PM   #7
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Im in the same boat, but luckily my leg only gets numb after a few hours of driving, not minutes.
Using cruise control can increase drive time, but it still annoys me. I wish there was a way to angle the seat.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-23-2012, 02:56 PM   #8
sitandspin
Drives: Raven FRS
i've never had this happen before, in any car or chair or anything. very bothersome. i might try to get longer bolts and washers, that sounds like a good idea.
Old 09-23-2012, 03:06 PM   #9
bakerr6
Drives: 2013 raven black fr-s
If you are taller, you will have more stress on your legs, since they will be angled more. I plan on adding a cushion down the line, but as for right now, I just deal with it
bakerr6 is offline   Reply With Quote
Old 09-23-2012, 03:21 PM   #10
sitandspin
Drives: Raven FRS
i'm only 5'6", but a thick powerlifter 190
Old 09-23-2012, 03:28 PM   #11
Lonewolf
Lonewolf's Avatar
Drives: Moped
If it makes you feel any better, this happens to my left leg when I am in my DD civic for more than 30 minutes, so for many it's just the price of getting older....(in early 30's now)
When I was younger, this never happened to me...
Old 09-23-2012, 04:16 PM   #12
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Im only 23
Parting out HERE
Old 09-23-2012, 06:19 PM   #13
ahausheer
Re-member
Drives: Toyota camry
Get the dam foam thing. These types of problems should not be aggravated as it will only beget more problems. Honestly you should not rule out getting a new seat or finding devices to alter your seating position, forget what others think. Also, from my own experience, sometimes you need a week or more of trying a device/position to really determine what works, ie, it might not be super comfortable at first but eventually the sciatica will calm down. Just keep trying different things. Stretching helps a lot, if you do it every day.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 09-23-2012, 06:56 PM   #14
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
I've actually started stretching and working out again and it hasn't been bothering me as much as it had been. That or Im just breaking in the seat cushion
But I am looking at getting different seats at some point.
Parting out HERE
Seat belt issues skoodge Scion FR-S / Toyota 86 GT86 General Forum 55 08-04-2014 03:41 PM
Sit in the rear seat for me ;) (with photos of people in back seat) D4ng3r Scion FR-S / Toyota 86 GT86 General Forum 125 11-14-2013 06:59 AM
Another seat rail option! Nagisa Auto Seat Rails vividracing Cosmetic Modification (Interior/Exterior/Lighting) 11 02-28-2013 04:15 PM
car seat in the rear seat? 4032pauln Scion FR-S / Toyota 86 GT86 General Forum 20 09-05-2012 08:34 PM
CG Lock - Seat Belt Retainer to Hold You Firmly in Seat Jimbo Miscellaneous 0 07-23-2012 01:27 AM
