Old 09-03-2012, 07:01 AM   #1
pdreams
Need for Roll Centre Adjuster
Hi,
For those who have lowered their cars either through short springs or coilovers, have you all seen the need for the use of a roll centre adjuster?
Or do the geometry not change so much that it is hardly noticeable?
Appreciate your reply.
Cheers
pdreams is offline   Reply With Quote
Old 09-05-2012, 04:12 AM   #2
Duo
Drives: 86 pending move
Originally Posted by Moto-P View Post
From a previous talk I had with CE, Tada of Toyota, his recommendation for suspension lowering of -20mm+/-15mm for dynamic alignment of the arms, I went on the lower height end of the spectrum just for kicks.
LOL! Well teasing wasn't my intentions as much as I was just way too thrilled at already curing something that ever so slightly bugged me about the FRS, which is the somewhat harsh city ride, and that politics-legal-PD-induced monster truck ride height....LOL Good thing Tada-san was clever enough to work around it by specifying arms and rods that work over wide range of height, and secure dynamic travel that is consistent through motions. He even touched on the fact that the FRS/BRZ/86 suspension arms are ideal at 20mm drop!!
You'll probably want them for anything more than a 20mm drop.
Motorsports: Because basketball, baseball, and football only require one ball.
Duo is offline   Reply With Quote
The Following User Says Thank You to Duo For This Useful Post:
Plumbus (01-08-2021)
Old 09-05-2012, 07:46 AM   #3
Racecomp Engineering
Here's what I posted in another thread:
Yes I concur with what Duo quoted Tada-san as saying.
20mm is a good spot....any lower and the RCA kit will be helpful. Not "required" but a noticeable improvement. For those who auto-x and it's not allowed by classing it's fine to go lower than that with firm springs.
For those on springs that lower more than 20mm, especially springs that are very soft in the front like just about everyone else out there besides our RCE Yellows, the RCA kit will be more necessary.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 09-05-2012, 08:16 AM   #4
pdreams
Thanks Duo and Andrew,
I was starting to lose hope on this thread, over a hundred views and no reply.
Good to know 20mm drop is sort of a norm.
Again, well done to Racecomp. I know I will be shipping my coilovers w you guys come Christmas.
Old 09-05-2012, 09:04 AM   #5
Thanks, glad to help.
Just to be clear for all, you can safely go past a 20-25mm drop with coilovers more so than with lowering springs due to the firmer rates (plus the fact the coilovers will have more travel when going that low but that's a different issue). But even with coilovers you will see a noticeable benefit when you add the RCA kit at that point. It'll just be mo' better.
- Andrew
Ro_Ja (09-05-2012)
Old 09-05-2012, 02:45 PM   #6
BRZranger
Does the roll center adapter affect alignment and corner weights?
BRZranger is offline   Reply With Quote
Old 09-05-2012, 02:58 PM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Alignment, yes. Corner weight, no. You're changing the ball-joint in the lower control arm and the outer tie rod ends. So the strut is essentially untouched. But because you're going to have so much unbolted, and will be messing with the tie rods, you'll want an alignment after to get everything back to where it should be.
The Following User Says Thank You to Draco-REX For This Useful Post:
BRZranger (09-09-2012)
Old 09-19-2012, 02:14 PM   #8
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Do they any adjuster kits yet?
karma003 is offline   Reply With Quote
Old 09-19-2012, 05:16 PM   #9
renzo1982
Drives: White FRS
- Andrew
Do you know if anyone has the RCA available? Or if anyone is in the process of making them?
renzo1982 is offline   Reply With Quote
Old 09-19-2012, 05:41 PM   #10
jamal
jamal's Avatar
Drives: Legacy GT
Whiteline is likely working on a kit.
RCE has some fancy control arms in the works that I'm sure will offer roll center correction.
jamal is offline   Reply With Quote
Old 09-19-2012, 06:01 PM   #11
^ that.
No ETAs yet.
Old 09-24-2012, 06:18 AM   #12
BRZranger
^ that.
No ETAs yet.
Any inside info? About to bite the bullet on Cusco or GTSpec...
Old 09-24-2012, 12:23 PM   #13
We've got pictures of the prototypes in our Build thread.
As far as I know cusco and GTSPEC are only making rear lcas, we're talking about fronts.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
BRZranger (09-25-2012), karma003 (09-25-2012)
Old 09-25-2012, 12:20 PM   #14
BRZranger
- Andrew
I almost waited for nothing! Any confirmation on roll center correction options?
Roll cage (Stealth Inc.) Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 12-16-2013 12:51 PM
Toyota Customer Service Centre Response Mikesta AUSTRALIA 3 08-01-2012 11:10 PM
Roll stiffness: Springs vs anti-roll bars? Captain Snooze Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 07-24-2012 06:44 PM
is it necessary to change anti-roll bar? yuli8466 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 06-25-2012 11:58 AM
