Old 10-05-2026, 11:49 PM   #1
hotrod1442
Drives: 2013 FRS's (Hot Lava/GMetal Grey)
Installing a New ECU Question
I have a 2013 FR-S that has been tripping P000A, and P0016 codes, after replacing all the cam phasers (did them all to be on the safe side), timing chains/tensioners, oil control valves, and cam position sensors, I'm still getting the P000A. P0016 codes.
After doing some research on this it seems like the next step would be to replace the ECU.
My question is if I purchase a new OEM ECU, is it a direct "plug & play" deal, or does the new ECU need some programming to get up and running again?
hotrod1442 is offline   Reply With Quote
Old 10-06-2026, 10:38 AM   #2
smackrel
Full Throttle!
Drives: 17 CBSP Limited PP
At the very least, I'm pretty sure your keys will need to be programmed to it, but hopefully someone more in the know will have a definitive answer.
smackrel is offline   Reply With Quote
Old 10-07-2026, 05:01 AM   #3
callisto
Drives: 2019 Subaru BRZ
The exact part number printed on your ECU will, if bought from a dealer, come with the exact software you have now. You’ll still need to go through the ECU replacement immobilizer process, though. It may be lower risk for you to pay someone to do this for you.
callisto is offline   Reply With Quote
ECU flash ecu definition file? toyota_86 GR86 General Topics (2nd Gen 2022+ Toyota 86) 0 06-13-2023 05:54 AM
Replacing a Bricked damaged or faulty ECU with new or used ECU FRS BRZ GT 86 steve99 Software Tuning 110 03-12-2023 04:43 PM
Replacing BRZ ECU's with 86 ECU's krauterz Issues | Warranty | Recalls / TSB 4 04-08-2021 07:49 AM
Ecu swappable? Potentially locked ecu kill3rwill Software Tuning 3 03-02-2016 09:44 PM
BRZ 86 FRS ECU Information - ECU Type Flashing Learning Resetting steve99 Software Tuning 46 08-19-2015 07:13 PM
