Old 03-03-2021, 09:40 PM   #1
krauterz
Drives: 2013 Subaru BRZ
Replacing BRZ ECU's with 86 ECU's
Hey guys.
After some pretty wild water damage, I need to replace my electrics. I am aware that you pretty much have to replace everything at once from a donor car, however, my question is, can I replace my ecu's, dash etc from a 2013 BRZ to that of a 2013 GT86? are there any differences when it comes to these setups?
Thanks
krauterz is offline   Reply With Quote
Old 03-04-2021, 04:14 AM   #2
tomm.brz
Drives: brz 2017 hksv2
you should read everything on @steve99 ' signature as you ll find everything about it
The Following User Says Thank You to tomm.brz For This Useful Post:
krauterz (03-04-2021)
Old 03-04-2021, 04:35 AM   #3
steve99
Originally Posted by krauterz View Post
Hey guys.
Thanks
If car is key start dash is part of security set, if its push button its not
but its likely easier jist to replace everything from donor car that same as yours key start or push start as there is a bunch of different electronics in the push start to key start
Old 03-04-2021, 07:05 AM   #4
krauterz
Thanks mate
Old 04-08-2021, 07:49 AM   #5
krauterz
Sorry to bump an old post, just wanted to say thanks again to you both, my car is now running again after a plug and play switch over
The Following 3 Users Say Thank You to krauterz For This Useful Post:
Code Monkey (04-08-2021), Lantanafrs2 (04-08-2021), Tcoat (04-08-2021)
replacing BRZ key/fob brzcountsright BRZ First-Gen (2012+) — General Topics 12 03-13-2020 02:31 PM
Replacing brake kit becausethexo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 07-31-2019 07:03 PM
Replacing OEM tires. FRiSson New England 22 02-12-2016 11:43 AM
anyone have DIY for replacing OEM HU?? mbh1101 DIY (Do-It-Yourself) Guides 2 01-27-2013 12:18 PM
