Old 06-02-2026, 07:54 AM   #1
Koba
Drives: 2020 BRZ
Dash lights after cage install
Started to remove the interior for a cage, will be keeping stock instrument cluster.
I am sure that after removing all airbags and whatnot I will have a light or two popping up.
Do I just use resistors, or can all of the unwanted lights be ECUTEKed out?
I have a resistor for the driver's airbag and drivers seat, from when it was only a track car, but I would prefer to cut all of the unnecessary wiring out.
Thank you for your suggestions in advance!
Koba is offline   Reply With Quote
Old 06-05-2026, 06:11 AM   #2
Wally86
Be Kind
Wally86's Avatar
Drives: 2020 86
I don't track my car and haven't removed any airbags but I want to know the answer to this question too
[Insert clever signature here]
IG | WhiskyBlog | Photography
Wally86 is offline   Reply With Quote
Old 06-05-2026, 06:20 AM   #3
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
The airbags are not controlled via the ECU. There is a dedicated airbag computer in the car and the light in the dash is controlled with that. I have never taken out the instrument cluster so I don't actually know how the lights are controlled but if it's a bulb then I would say to remove the bulb. The other light in dash console area is controlled by the same kind of thing. Again, unplug it? To my knowledge, even using Techstream, it's not something you can disable or change.
You might even find and remove the SRS Airbag computer but I don't know where it is or what the impact of doing that would be.
RongTurnRacing is offline   Reply With Quote
Old 06-06-2026, 04:58 PM   #4
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
Take the airbag module out....car will run fine. Gauge Airbag light will always be on....if it's a track car only. Who cares?
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 06-06-2026, 05:55 PM   #5
Koba
Drives: 2020 BRZ
OCD
Old 06-09-2026, 05:21 PM   #6
Opie
Opie's Avatar
OCD
Small piece of electrical tape....
2023 GR Cup Car
Roll Cage Install - Remove Heater Box or Not smoltz Tracking / Autocross / HPDE / Drifting 7 02-16-2026 08:51 PM
Roll Cage Install - Dash Bar smoltz Tracking / Autocross / HPDE / Drifting 2 02-16-2026 08:49 PM
Dash lights full bright after head unit install Flash02 Electronics | Audio | NAV | Infotainment 0 04-08-2019 09:48 AM
FR-S dash rattle after Injen air intake install Tferritto Scion FR-S / Toyota 86 GT86 General Forum 2 06-29-2014 07:41 PM
Auto Power full cage photos? Custom cage prices? Anthony Tracking / Autocross / HPDE / Drifting 4 08-08-2013 11:52 AM
