Drives: 2014 Satin White Pearl BRZ
Left Turn Signal Not working but the Right does.
Something weird happened the other day, I was trying to turn left and my turn signal wasnt working properly ( it would go on and then turn off even though the Switch/Stalk was pushed down to engage the left turn signal). I Pulled off the road and tried my signals again and the same thing happened. Would go on and then off and stay off even though the switch/Stalk was engaged. When pushed up to engage the right turn signal, it works perfectly fine. I have a 2013 Brz. Only mods are the 2017 headlight swap and the valenti revo tail lights. Any Help or Advice would help!
I assume the bulbs all have their filaments still?
Sent from my SM-G975U using Tapatalk |
Yeah, they do. I figured it out and found out it was a bad relay. switched it out for a new one and it works perfectly now.
| Turn signal help- all lights work except turn signal-FIXED | BackFlip | Electronics | Audio | NAV | Infotainment | 6 | 10-11-2022 10:38 AM |
| Right side turn signal does not turn on | Feargt86 | Issues | Warranty | Recalls / TSB | 4 | 10-02-2018 01:10 PM |
| Left turn signal not working. | klassick | Issues | Warranty | Recalls / TSB | 15 | 09-24-2016 12:47 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 06:47 PM |
| front right signal not working. help | Mr_YUzU_FRS | Issues | Warranty | Recalls / TSB | 6 | 03-11-2015 05:47 AM |
