Old 09-13-2022, 05:01 PM   #1
BackFlip
Drives: 2017 Subi BRZ
Turn signal help- all lights work except turn signal-FIXED
Seeing if anyone can help.
ALL the lights work except the turn signals.
Headlights Low and High beams- work
Headlight Boomerang light- work
tail lights- work
Brake lights- work
Hazard Lights- work
Dome light- works
Ive checked all fuses-good, relays-good(even replaced relay under dash just in case), replaced Blinker Switch
All stock 2018 Subaru BRZ 50th Anniversary. No aftermarket lights.
BackFlip is offline   Reply With Quote
Old 09-13-2022, 05:16 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You're testing this with the car running, or at least in ign. on, right?
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block
DarkPira7e is online now   Reply With Quote
Old 09-13-2022, 07:49 PM   #3
BackFlip
Correct with ignition on, also with car running
Old 10-11-2022, 01:59 AM   #4
BackFlip
FIXED- What I did.
-Checked fuses-good.
-“Turn Signal Flasher Assembly” replaced with known good one- blinkers still not working.
-“Combination Switch” replaced with known good one- blinkers still not working
-Wires running from fuses were HOT with ignition “ON”.
-Continuity present on all grounds.
EVERYTHING checked out good! What was left to check that was part of the blinkers??? The “MAIN BODY ECU”(circled in GREEN) in the AllData pic. Which controls the “TURNL” and the “TURNR”(circled in BLUE) in AllData pic.
Changed it out. NOW EVERYTHING WORKS LIKE IT SHOULD!!
Pic of part changed out with part#.
Hope this helps someone else out.
The Following User Says Thank You to BackFlip For This Useful Post:
DarkPira7e (10-11-2022)
Old 10-11-2022, 02:01 AM   #5
BackFlip
Part and location
Old 10-11-2022, 02:04 AM   #6
BackFlip
FYI I got the part from “Mani Valen” on Facebook. He has a bunch of FRS/BRZ/86 part outs.
Old 10-11-2022, 10:38 AM   #7
Compelica
Compelica's Avatar
Drives: 86 GT
Possibly explains why the main body ECU has to be replaced when it comes to certain lights not working as it should:
https://www.ft86club.com/forums/show...0&postcount=30
The BIU (body computer) has a series of diodes inside on the door switch grounding to isolate the two door triggers. This so that the window drop feature when door is opened on one side or another can operate independently and not drop both windows when one door is opened. Now diodes are a tricky things designed for a very specific electrical loads and do heat up and blow if they are loaded with more devices like adding lamps, or using LED with dedicated diodes within it too.
The diodes in the BIU aren’t replaceable and are part of the circuit board so if you blow diodes on the BIU, you’re pretty much going to need to replace it. Upon replacement, you also need to reprogram it as it retains the codes for the ignition key chip transponder as well as ECU handshake, and radio key for remote key fob. (Spelled very expensive trip to the dealer).
So if you’re installing an aftermarket addition, such as alarm triggers, auxiliary power ports, or to the interior lamp or anything on a BIU circuit, it’s best to just run new set of wires separately, and isolated from BIU circuits.
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
The Following User Says Thank You to Compelica For This Useful Post:
bcj (10-11-2022)
Problem with turn signal lights coolaron Cosmetic Modification (Interior/Exterior/Lighting) 2 05-18-2015 12:11 AM
Turn signal lights whip Cosmetic Modification (Interior/Exterior/Lighting) 13 02-26-2015 10:45 PM
Is there another way to keep the turn signal lights on? DeadStar7 Scion FR-S / Toyota 86 GT86 General Forum 10 06-29-2014 10:43 PM
WTB FR-S Turn Signal Lights retrosmiths Want-To-Buy Requests 2 01-08-2014 02:13 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
