Old 03-15-2026, 02:22 AM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Weird Noise When Shifting
I am having a weird noise every time I shift from 1st to 2nd to 3rd. Seems to be happening only when driving. In neutral or with the car off, the sound does not happen. It sounds like it's coming from the rear end and is only on up shift. Haven't heard it from downshift.
I have jacked up the car to see if there is anything hitting but it all looks clear. Only thing that has been changed late last year was axle replacement but that was done about 5-10k miles ago. No marks on the driveshaft that indicates it is hitting the shifter (would also feel it).
Below is the link to the sound which you can hear clearly the noise around 4 second mark and the 8 second mark.
https://streamable.com/rvyypd
Any ideas?
Bach415 is offline   Reply With Quote
Old 03-15-2026, 07:46 AM   #2
Ohio Enthusiast
Drives: 2018 BRZ
What's your milage and bushing mods? Might be worn out drivetrain bushing, particularly diff carrier. I'd inspect them all - transmission mounts, shifter carrier, driveshaft cradle, diff carrier, rear subframe bushings and all suspension bushings in the rear.
Ohio Enthusiast is online now   Reply With Quote
Old 03-15-2026, 12:18 PM   #3
Bach415
Bach415's Avatar
118k miles. Only roll center kit and the TRD quick shifter. I thought I put that in my op but I guess I was too sleepy while typing this. The quick shifter mount/rubber grommet that replaced the bushing looks good still when I checked. Maybe one of the rear diff bushings looks like it needs replacing but not immediately. A bit worn but not to a point where deteriorating.
2nd to 3rd gear weird over-rev jerk when shifting Biggumzzz Engine, Exhaust, Transmission 17 03-26-2021 01:49 AM
Weird Growling sound when high rpm shifting Blackedout86 Engine, Exhaust, Transmission 1 07-25-2020 09:28 AM
Slow RPM Buildup and weird shifting sound Blackedout86 Engine, Exhaust, Transmission 17 07-25-2020 08:27 AM
Weird shifting? Maybe? Please tell me I am wrong. treerexaudi Official Issues | Warranty | Recalls / TSB 27 04-02-2019 03:23 PM
shifting and down shifting feel Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2012 05:09 PM
